Technical Does this scare everyone? -SBC casting fix
Discussion in 'The Hokey Ass Message Board' started by xnology, May 25, 2018.
  1. xnology
    xnology
    from Idaho
    So I picked up another 327 for cheap. Cheap enough that if it’s toast, I am still okay.
    This is what I’ve not seen before:
    The casting/stamp is a ‘64-67 327 250hp or 300hp
    Date code is J145
    I’ve read (online) that GM did some casting number modifications for factory replacement engines. Is this correct or do I have another vintage boat anchor?
    From the suffix on the pad, HCR , it’s a ‘66 327 275hp 4bbl Rochester carb
    Intake number is 3844457
    Power pack heads.
  2. Maybe it was some Corvette guys attempt at matching numbers?
    302GMC, prewarcars4me and xnology like this.
  3. tubman
    tubman
    There's no VIN derivative stamped on the pad, so maybe it is a replacement blocks. They did some crazy things at the engine plants, but I don't think anything that crazy. Corvette guys would know.
    xnology likes this.
  4. xnology
    xnology
    from Idaho
    If I only knew some corvette guys.
  5. SHHHHH they are a**** us
    fourspd2quad likes this.
  6. timwhit
    timwhit
    I've had only one replacement block in my life. It was a 283 that I had in my last car. It had a complete casting number and was listed as a replacement block. If I just wanted a 327 (which I really like) I guess I wouldn't care about the number unless it caused some problem with ***le/registration.
  7. daliant
    daliant
    Somebody wanted themselves a corvette motor and damn it come hell or high water they were going to have one!
  8. fourspd2quad
    fourspd2quad
    LOL.....If only Corvette guys didn't drive Corvettes.
    Unkl Ian likes this.
  9. Bandit Billy
    Bandit Billy
    Broach marks look wrong. They had a swirl to them, these are straight. I'd say re-stamp. But what do I know?
  10. big duece
    big duece
    from kansas
    If your not restoring one of those trophy case vettes, casting# shouldn't be to important. I would be concerned about have the block checked for cracks and if the deck height has any room left to work with.
  11. Mr48chev
    Yep, it's either a solid 327 block or it's s**** iron. When you get one like that the numbers don't mean much except to the **** dude who just has to have a Corvette block in his 55 Chevy.
    If the block checks out build it and if someone notices and comments do the "hell I don't know it came that way" thing.
    Hnstray likes this.
  12. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Every small block ever came from a vette. Just ask the seller.
    zzford and scotty t like this.
  13. gimpyshotrods
    gimpyshotrods
    10 out of every 5 SBC's ever made started life in a Corvette.
  14. s55mercury66
    s55mercury66
    from SW Wyoming
    The broach marks look right, the decks get swirl marks when resurfaced, or cleaned with any tool that leaves circular marks.
    Fordors likes this.
  15. 56sedandelivery
    56sedandelivery
    I plan on putting a car/truck engine into my Corvette; just so the world is balanced. I am Butch/56sedandelivery.
    lewk, chevy57dude, VANDENPLAS and 5 others like this.
  16. Deuces
    Deuces
    I have nothing against truck engines.... The 350 blocks I bought from s**** yards had 4-bolt mains and a forged steel crank.......
    pitman likes this.
  17. JOECOOL
    JOECOOL
    I love Corvettes ,just not the guys who drive them.
    zzford, TagMan, Deuces and 2 others like this.
  18. Johnny Gee
    Johnny Gee
    from Downey, Ca
  19. luckythirteenagogo
    luckythirteenagogo
    from Selma, NC
    Didn't you know, they all came from corvettes, and are worth huge money! That is only if you are the guy trying to sell it.
    Sent from my SM-G920V using The H.A.M.B. mobile app
    zzford likes this.
  20. theHIGHLANDER
    theHIGHLANDER
    I'm a little confused about the 3 letter pad ID, 'HCR' vs just CR. 3 digit codes began around 1970 as far as I recall and by what I find in Hollander manuals.
    That said, it may indeed be a warranty or dealer replacement unit. Big blocks were usually 'CE' which designated such a thing. I don't know how the H got in there. Perhaps the code is actually HC with the R used to indicate an OEM service or replacement engine. Did you find a list with early 3 character letter codes? It's been a while since I looked stuff like this up, maybe I'm full of **** on the 2 vs 3 letter thing. Been known to happen...
  21. xnology
    xnology
    from Idaho
  22. 1946caddy
    1946caddy
    from washington
    Look for the guys who hold their little finger in the air when drinking their beer. :confused:
  23. nugget32
    nugget32
    On a couple of new short blocks I bought in the 60s the pad on the p*** side in front if the head was blank. I guess if a dealer installed It they stamped it.
  24. Mr48chev
    True on both counts. If you were to go through the old Hot Rod magazines from about 1956 to 1963 most every rod with a small block in it had a "Corvette" engine in it. The local Chev garage only sold about three special order Corvettes a year but all though the 60's at least they stocked at least three sets of Corvette valve covers on the shelves at all times plus several 30-30 cams. I helped several buddies install those 30 buck Corvette valve covers on their Chevies in the mid 60's . Will work for beer worked even in High school.
    nugget32 likes this.
  25. partsdawg
    partsdawg
    from Minnesota
    Doesn’t scare me. Never cared about casting numbers, especially on a engine that’s going to be rebuilt. It’s a 327.
  26. henryj1951
    henryj1951
    from USA
    M***ey Ferguson combine.....
    scotty t likes this.
  27. 30tudor
    30tudor
    or Checker cabs
  28. rudestude
    rudestude
    What's scary is the question....it's a 327 ...if your not building a number's correct car than what's there to be scared of as long as the block is not broken you can make it what ever you want...now days I don't think that any 327 that's in good condition or rebuild able is a boat anchor .... I have one now that I'm going to be building it's out of a 57 Chev that was drag raced years ago and and is full of go fast stuff and it's heads are stamped right and left....well is that looking at the engine from the front or from the drivers seat?????oh no I'm scared now if I get them mixed up......oh hell I'm just screwing with ya ...it's late and I'm tired....but really if you don't need correct numbers than I wouldn't worry it.....and my heads really are stamped R&L and no I am not a Corvette guy.....
    Sent from my QTASUN1 using The H.A.M.B. mobile app
  29. Oilguy
    Oilguy
    I have an HCR. It came out of a 66 Impala wagon w/PG. Check the NaztyZ28 site.
