My Fiat Topolino is a Flip Top now
Discussion in 'The Hokey Ass Message Board' started by fiat gasser, Nov 26, 2009.
  1. fiat gasser
    fiat gasser
    Car went straight. And felt good.
    Sent from my SM-G900V using The H.A.M.B. mobile app
    WDobos, loudbang and swade41 like this.
  2. LeadSledMerc
    LeadSledMerc
    Looks great!!! What were your ET and MPH?
  3. fiat gasser
    fiat gasser
    Not good for first p***. I pulled up under tower before burnout box and the car popped and shut off. Got it running did the burnout and staged. Launched good went straight about almost half track I could feel the back tires skating side to side slightly so I got out of it and instantly it started popping and not wanting to run. Got it on the return road and it quit running. It was flooded, got it going but would not stay fired. Back at the pits I took a close look at the carb and at idle the secondaries where leaking into the carb. Causing the flooding problem. The day before I ran it in the pits and around the track property with no issues. Then the Gremlin raised his ugly head when I leased expected it.[emoji1]
    It was my first time ever on a dragstrip so I didn't try to set the world on fire. Need to ease my way into this. The Fiat is extremely narrow and short and no since wrecking it right out of the box. Went 9 seconds in the 1/8th mile. Mainly because I got out of it so early. Better days yet to come once bugs are worked out.
    WDobos, TFoch and loudbang like this.
  4. milwscruffy
    milwscruffy
    Never fails, bummer....
    fiat gasser and loudbang like this.
  5. LeadSledMerc
    LeadSledMerc
    Yep, take your time, and get used to things. Have fun, and be safe. Looks awesome!!!
  6. loudbang
    Came out real nice for someone who has never been down a dragstrip LOL. :rolleyes:
  7. fiat gasser
    fiat gasser
    Where you there?
  8. loudbang
    No just been following your thread from the begining.
    1927graham and fiat gasser like this.
  9. fiat gasser
    fiat gasser
    Thank you very much.
  10. fiat gasser
    fiat gasser
    There where many times I could have given up, but you guys kept me going.
    mad mikey, milwscruffy and loudbang like this.
  11. fiat gasser
    fiat gasser
    WDobos, OahuEli, mad mikey and 4 others like this.
  12. fiat gasser
    fiat gasser
    WDobos, mad mikey, 1927graham and 4 others like this.
  13. TFoch
    TFoch
    Very cool! It's come a long way, you should be proud! It's got to be a blast to drive.
    Tom
    loudbang and fiat gasser like this.
  14. fiat gasser
    fiat gasser
    Yes it sure is. Thank you
  15. fiat gasser
    fiat gasser
    The headlights, hi low beam, taillights, brake lights and directional's all wired in. IMG_20180702_122403_469.jpeg IMG_20180702_122403_463.jpeg IMG_20180702_122403_457.jpeg IMG_20180702_122403_476.jpeg
    WDobos, mad mikey, TFoch and 2 others like this.
  16. fiat gasser
    fiat gasser
    WDobos, mad mikey, TFoch and 3 others like this.
  17. 1971BB427
    1971BB427
    from Oregon
    Had that same carb issue recently on my car. Rear carb pouring gas out around the throttle shaft. Pulled the rear carb and the float was stuck on the secondaries. Washed the needle out with carb cleaner and reinstalled it. Runs like new again.
  18. swade41
    swade41
    from Buffalo,NY
    Hey Bob, I heard you may have had an incident at the Gold Cup ?
  19. fiat gasser
    fiat gasser
    Yes, I sure did. Suicide doors are cool till one pops open at about 80mph. Last p*** of the weekend and I launched it harder than previous p***es. My guess is the car was twisting just enough to pop the latch. I had just shifted to high gear and it flew upen faster than you could blink. Made a spring loaded safety latch so it doesn't happen again. Luckily the rear fender kept the door from hitting the body. Creased the fender and caved the door in. I have been able to straighten the do so it functions and I am making a set of radiused rear fenders.
  20. 1971BB427
    1971BB427
    from Oregon
    My Austin also has suicide doors and I have dead bolt safety catches I installed inside to prevent them from opening at the drags under hard launches. Everyone with suicide doors and drag races should have a dead bolt inside to save the doors and body.
    mad mikey, fiat gasser and loudbang like this.
  21. TFoch
    TFoch
    Now that's what I call a "Door Slammer"! Glad you didn't do too much damage.
  22. fiat gasser
    fiat gasser
    Here is mine. Spring loaded pin that goes into door. Drilled a 3 and1/2" hole in the lexan incase the event someone needs to get me out of the car, they can pull it back to open the door. 20180815_123828.jpeg
    mad mikey, loudbang, swade41 and 3 others like this.
  23. OahuEli
    OahuEli
    from Hawaii
    I bet that was a "Skid Marks in the Skivvies" moment.:eek::D
    TFoch, loudbang and fiat gasser like this.
  24. fiat gasser
    fiat gasser
    Upon closer inspection, no marks where found. Also no leakage from same area. Lol once it opened there was nothing I could do, just slowed down. When I pulled off the track an official came over to close the door, but it would only close a little more than half way. Made back to the pits and took the inner door panel off and pushed out the dents with my foot until the door worked again. 20180729_190143.jpeg
  25. swade41
    swade41
    from Buffalo,NY
    Sorry to see it, maybe bear claw latches would help ?
  26. loudbang
    Dam that ****s. :(
    TFoch and mad mikey like this.
  27. fiat gasser
    fiat gasser
    It has the bear claw latches
  28. swade41
    swade41
    from Buffalo,NY
    No kidding, I thought with the double latching they do it would be impossible to pop open.
  29. fiat gasser
    fiat gasser
    I thought so too.
  30. fiat gasser
    fiat gasser
