Technical Bolt Pattern Help
Discussion in 'Traditional Customs' started by LIVFRD, May 30, 2018.
  1. LIVFRD
    LIVFRD
    Ok, this might be a silly noob question and I realize I run the risk of embarr***ing myself, but...
    I ordered the 1948-1956 Ford Half Ton Deluxe Disc Brake Kit, 5 x 4-1/2 Inch kit from Speedway motors and a set of Allied Wheel 61B Series from Jegs. Everything was carefully ordered to be spec'd at 5 x 4 1/2 pattern.
    Rims came yesterday, went to put them on and it appears that the rotors that came with the disc conversion set have a bolt pattern just tighter than the spec'd 5 x 4 1/2". I have to measure it, but it's almost like 5 x 3/8", if I had to guess. I have an old adapter plate to change the lug pattern to 5 x 4-1/2 and that fits on the new rims fine. Is there something basic I'm missing here, like an adjustment on the lugs or something?
    Thanks,
    Eric
  2. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Are you measuring correctly? Center of one lug to the outside of an opposite lug is correct, or rather close enough.
  3. prewarcars4me
    prewarcars4me
    from Bhc, AZ
  4. Chappy444
    Chappy444
  5. LIVFRD
    LIVFRD
    I'll check again tonight. Thing is, it's so painfully close it's like a manufacturing error or something, thats why I was wondering about adjustability.
  6. LIVFRD
    LIVFRD
    That was one of my first thoughts too, but if it was 5 x 4.75, then the star would be wider, this is clearly tighter to the center. Great call on the template, bet I could pick one up at a local parts store tonight. Thanks!
  7. Chappy444
    Chappy444
    tighter in relation to the rim bolt pattern? maybe they sent the wrong rim?
  8. LIVFRD
    LIVFRD
    No, tighter to the center of the rim. Picture a line coming straight out of the center of the dust cap and going straight through the center of the lug, the lugs are all rubbing on the inside of the hole as though they are too close to the dust cap (but just a hair). I actually was able to get an old rim to fit on the rotor, but I couldn't get the lug nuts on.
  9. Gasolinefed
    Gasolinefed
    from OR
    measure bolth the wheel and the rotor and which ever is out of spec ***ume the company sent you the wrong/defective parts and get on the horn to replace or refund and buy elsewhere..
    if its speedway probably from someone else..
  10. Chappy444
    Chappy444
    wonder if they sent you a metric something or other... box got labeled wrong, wrong part in the right box....
    9 times out of 10 when i am dealing with an "almost fits" issue i find a metric part in the mix somewhere...lol
    http://wheellugpattern.com/Metric_Inch_Chart.htm
    Hnstray and ClayMart like this.
  11. lothiandon1940
    lothiandon1940
    LIVFRD likes this.
  12. RMR&C
    RMR&C
    from NW Montana
    Can you post a pic?
    My guess would be it's more of that lovely offshore manufacturing where "close enough" tolerances make it out the door regularly......
  13. LIVFRD
    LIVFRD
    My gut tells me you're probably right. I'll try to post a pic later tonight. Thanks!
  14. Sheep Dip
    Sheep Dip
    from Central Ca
    Mazda, Audi, Mercedes and VW all used a 5 x 112 mm (4.409") bolt pattern.
  15. LIVFRD
    LIVFRD
    Oh ****** hell... Mazda, thats got to be it! That whole Ford/Mazda partnership.
    lothiandon1940 likes this.
  16. okiedokie
    okiedokie
    from Ok
    That wheel has both 5 on 4 1/2 and 4 3/4. Sure you are using the correct holes.
    prewarcars4me likes this.
  17. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Betting this is it.
  18. LIVFRD
    LIVFRD
    You’re spot on.
    Wow, looks like I went and embarr***ed myself after all.
    Thanks for the help all
    prewarcars4me and lothiandon1940 like this.
  19. lothiandon1940
    lothiandon1940
    ........................Hey, We've all been there.:)
    Hnstray, prewarcars4me and LIVFRD like this.
  20. LM14
    LM14
    from Iowa
    At least you are man enough to admit it. We've all been there at one time or another.
    SPark
    LIVFRD likes this.
  21. LIVFRD
    LIVFRD
    Thanks. No shame in making mistakes, just gotta learn from them when you do! (Even the really obvious ones...)
