Projects 1956 Pontiac Gasser 389 swap (Finally Running)
Discussion in 'Traditional Hot Rods' started by wvenfield, Oct 29, 2014.
  1. wvenfield
    wvenfield
    They will be trimmed and capped with easy disconnects. Hopefully get the full exhaust done this week.
    1947knuck and loudbang like this.
  2. wvenfield
    wvenfield
    Does anyone make a 4 inch header flange? It would be easier than making one for the main header. No more complaints about the dirt roads. IMG_20180530_160243.jpg
  3. wvenfield
    wvenfield
    Southcross2631 or anyone else.......how did you go about securing the Augers?
  4. wvenfield
    wvenfield
  5. wvenfield
    wvenfield
    Not big progress but something is better than nothing.
    1947knuck, catdad49, brut4s and 5 others like this.
  6. bchctybob
    bchctybob
    Try SPD for your collector flanges/caps. They don't show 4" collector flanges in the catalog but they might have them or be able to make some if you give them a call. I've bought from them before, their stuff is nice and not horribly expensive.
    Hedman used to make them but that was long ago. At my shop I made my own when needed; 1/4"x5 1/2" plate, a plasma cutter, a drill press and an hour or so and you've got it - any shape or any number of bolt holes.
    http://spdexhaust.com/Exhaust-FlangesB.html
  7. wvenfield
    wvenfield
    Thanks......I will check them out. We can make them also but we get distracted and it takes longer than it should. LOL
    1947knuck, hendelec and loudbang like this.
  8. Runnin shine
    Runnin shine
    31hotrodguy and wvenfield like this.
  9. wvenfield
    wvenfield
    Slow but it's progress at least. Got the exhaust largely done. Augers installed. Started on the front shock mounts.
    bchctybob, that place does have 4 inch flanges. Not actual header ones so we will have to make the blocking plate but still quicker. Thanks.
    1947knuck, catdad49, Todd553 and 2 others like this.
  10. wvenfield
    wvenfield
    Finally a little more work done. Old Pontiac parts are not all that easy to come by.
    Hopefully will have it working shortly.
  11. I seem to remember selling some guy some rusty & crusty 56 Pontiac pedals & brackets. They look much better now.
    Chavezk21, loudbang and 31hotrodguy like this.
  12. wvenfield
    wvenfield
    Yes they do and I am still greatly appreciative.
  13. wvenfield
    wvenfield
    Long after I figured I would have been done and 63 years after it was initially done, I have three pedals.
  14. wvenfield
    wvenfield
    Big deal for me. :D Throttle linkage almost done. IMG_20190322_141355.jpg
  15. pontiac
    pontiac
    Looks great, awesome work.
    loudbang and wvenfield like this.
  16. bchctybob
    bchctybob
    Lookin' good, glad to see it progressing nicely.
    I ran across a nice '55 Pontiac with a 389/Hydro in it yesterday, made me wonder how yours was coming along. Dig those Tri-five Pontiacs.
  17. wvenfield
    wvenfield
    Initial mock up for the under floor brake master cylinder linkage.
  18. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Nice. Have you considered adding an extra lever arm for each rod?
    saltflats likes this.
  19. wvenfield
    wvenfield
    I'm hoping this works as this is taking far longer than I figured the way it is. :D
    31hotrodguy and 1947knuck like this.
  20. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I'm not saying to redo the geometry. Just give the pivot bolt a chance of surviving the force placed upon it so it won't bend or worse yet fail. I'll use these shock brackets as an example to show how there wouldn't be any more side force.
  21. bchctybob
    bchctybob
    I didn't quite get what Johnny Gee was saying at first but he's suggesting that you make the levers double-shear with a Heim in between. Those single sided rod ends may not be up to the task for clutch or brake pedal loads.
    Like this...........
  22. wvenfield
    wvenfield
    Thanks, right. I'm going to look at it. The clutch will be factory outside of one bracket.
  23. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I don't spoke so well but I like you for ********* it out. :D
    31hotrodguy, bchctybob and loudbang like this.
  24. wvenfield
    wvenfield
    I understood. :D
  25. wvenfield
    wvenfield
    Still looking at reinforcing joints but I have the M/C installed . Will cut hole in floor for access. (Boot will go on after paint and all)
  26. bchctybob
    bchctybob
    Sorry man............ Still Buds?
  27. wvenfield
    wvenfield
    Wow, nothing since April. I have appx 2.5 weeks open and trying to at least get it running. I got a radiator (anyone need a real nice 56 radiator with shroud?)
    Got the seats initially mocked up. Used the factory floor brackets. Hole cut for M/C. 60 some years of grime off the fuel tank.
    IMG_20190924_151929.jpg IMG_20190925_103419.jpg IMG_20190925_103437.jpg IMG_20190925_150522.jpg IMG_20190925_160540.jpg
  28. Good to see your back working on the Tin Injun,
  29. Snowman454007
    Snowman454007
    from Austin, TX
    Sir what radiator did you get? I need to get one for my 56. Mine is the factory original and it has a leak. Was thinking of getting a 56 GMC radiator as it cooled a 56 Pontiac engine.
    Sent from my SM-N950U using The H.A.M.B. mobile app
  30. wvenfield
    wvenfield
    I am not going anywhere close to factory. It's an aluminum high flow radiator. How bad is the leak? Many can be fixed or as I noted, I have my original that I would sell.
    The GMC should have the inlet and outlet in the right places but I have no idea how well it would fit.
