Event Coverage Welcome to the 2018 Meltdown Drags
Discussion in 'The Hokey Ass Message Board' started by Okiedoker, Oct 12, 2017.
  1. powrshftr
    powrshftr
    Gammz likes this.
  2. powrshftr
    powrshftr
    Came home early from work tonight.Gonna get a couple hours rest,then going to finish up the clutch/brake installation,and get the steering column and wheel back in the car.
    Motor might come out tomorrow if we get lucky.
    Stay tuned.[emoji6]
    Scott
    chryslerfan55, Tickety Boo and Gammz like this.
  3. Okiedoker
    Okiedoker
    from Wisconsin
    I feel like we have heard this before...
    Scott didn't your Dad drive the truck one year while you were strapped to the trailer to work on wiring while cruising down I-80?
  4. powrshftr
    powrshftr
  5. wrenchbender
    wrenchbender
    Yeah all that work to have james fix it in the pits in 5 minutes lmfao
  6. powrshftr
    powrshftr
    We’ll be able to put James to work for a few minutes this year if he’s bored,too.lol!
    That Man has been all kinds of good to us over the years.
    I’d be lost without you guys.
    No,seriously....I don’t own a GPS,so I’d literally be lost.[emoji23]
    Scott
    55belairx2, chryslerfan55 and Gammz like this.
  7. powrshftr
    powrshftr
    Ok...no time to talk.I’m actually working on a race car this morning.[emoji41]
    Tickety Boo likes this.
  8. Tickety Boo
    Tickety Boo
    from Wisconsin
    All right :) Started Tickety Boo 1st time this this year he is hungry for a chunk of horse meat. :D
  9. powrshftr
    powrshftr
  10. powrshftr
    powrshftr
    But that’s gonna be tough when this is the only part of the horse you ever get to see:
    Scott
  11. Tickety Boo
    Tickety Boo
    from Wisconsin
    Ah! Now you got Tickety Boo weeping antifreeze, drooling like a Black Lab looking at prime quarters.
    Now I gotta put a new water neck on, always something. :rolleyes:
  12. saltflats
    saltflats
    from Missouri
    With any luck I should have this one running this weekend.
  13. wrenchbender
    wrenchbender
    Well I'm finally gonna get to install the hemi tonight only ten days late and thousands of dollars short lol it's a good possibility it will run as well but I'm not counting on it yet lol
  14. powrshftr
    powrshftr
  15. wrenchbender
    wrenchbender
    Oh hell no scott I was gonna install this thing last night but I'm now dealing with the fact of the starter and flywheel ring gear don't match 392 has 172 tooth ring gear and 331-354 has 146 so I'm digging through the starter pile trying to find the correct starter drive As gene Winfield says "everyday is a school day" and this thing is schooling me for sure I can tell you this much I will be a hemi genius after I get this thing together lol
  16. saltflats
    saltflats
    from Missouri
    So would that be a genius on what not to do?
  17. wrenchbender
    wrenchbender
    James you are correct lol I do not have the correct starter but I will have a new correct ring gear this afternoon so a ring gear swap and then I "should " be able to install it lol here's hoping anyway
    chryslerfan55, powrshftr and loudbang like this.
  18. saltflats
    saltflats
    from Missouri
    I have a 354 flywheel and starter if you need.
  19. wrenchbender
    wrenchbender
    Thanks for the help james but I have a new starter ring gear on the way it will be here bout 1:00 believe it or not I was able to find one at Orielly for 29 bucks and it was at the warehouse who woulda thought that would happen lol
  20. Those flat tops are in the pump gas engine we’ve been running since 2014. The 14.5:1 pistons are in the new engine.
  21. powrshftr
    powrshftr
  22. 0NE BAD 51 MERC
    0NE BAD 51 MERC
    Jackson, Hope your Orielly 's is more knowledgeable than the ones up here. Best of luck:) Larry
  23. wrenchbender
    wrenchbender
    Larry I fortunately have two guys within the 7 stores in the area that are very good fortunately one of them was working this morning and the ring gear is on flywheel is mounted with clutch and I just moved the car in so I can stab it in here goes nothin lol
  24. saltflats
    saltflats
    from Missouri
  25. wrenchbender
    wrenchbender
    Like prego. It's in there now all I lack is finishing up lol
  26. wrenchbender
    wrenchbender
    James it must be a good day yours runs and mine is on the downhill side I can say I do know everything else fits so all should be good it will be Monday before I can start it as I am waiting for a couple more parts to finish up
  27. Gammz
    Gammz
    from Lincoln Ne
    I don’t care who you are a blown Hemi in a front engine is kool as F@@K!!! Great job!!!
  28. saltflats
    saltflats
    from Missouri
    Wasn't put together to go to the burger stand. ;)
  29. Gammz
    Gammz
    from Lincoln Ne
  30. saltflats
    saltflats
    from Missouri
    **** man I had to bum a ride for fuel, wire and a relay.
    Damn thing is soundin like it could go or blow. :D
