New Banger block in the works.
Discussion in 'The Hokey Ass Message Board' started by 58custom, Aug 11, 2011.
  1. Crazydaddyo
    Crazydaddyo
  2. 427designer
    427designer
    from Ohio
    The one in the machine now is almost finished. Yours is next!
    Tod
    dwollam and Dannerr like this.
  3. town sedan
    town sedan
    Go Tod! Go!
    -Dave
  4. 427designer
    427designer
    from Ohio
    Here are some castings we just did. The dual plug heads are brand new. The dual plug had a sand wash issue as you can see, which will be eliminated by mold wash on the next attempt.
  5. Crazydaddyo
    Crazydaddyo
    That looks great, but how are the blocks coming?
  6. 427designer
    427designer
    from Ohio
    Snyder work in the way right now. We got screwed over by foundries so bad it isn't even funny. probably a year behind on his stuff. I am fitting time in on the first aluminum block when I can. It is almost ready to be sleeved.
    Tod
  7. Crazydaddyo
    Crazydaddyo
    Last thing you told me was that you had cut the bores wrong for the sleeves you had. you got new sleeves and a new cutter to solve the machining issue and all you had to do was re-cut the bores. That was April.
    Patiently waiting.
  8. 427designer
    427designer
    from Ohio
    You're deposit money will be returned asap.
    Tod
    Beanscoot likes this.
  9. cederholm
    cederholm
    Beautiful workmanship!
    ~ Carl
    427designer likes this.
  10. FastLivin
    FastLivin
    Nice work Tod. That dual plug head is bad***
  11. 427designer
    427designer
    from Ohio
    The B head water jacket sent off for 3D printing quote.
  12. GuyW
    GuyW
    As a new banger owner, I'm avidly watching this thread!
    Kiwi 4d, Outback and 427designer like this.
  13. lsr490
    lsr490
    Me too
  14. dmdeaton
    dmdeaton
    Todd
    The intake in the pic a few posts above, is that a stock updraft for Snyder's, or a 2 barrel downdraft? Hard to tell without seeing the flange. I am looking for a swept up manifold to fit between my drive shaft header pipes.
  15. 427designer
    427designer
    from Ohio
    That is a downdraft.
    Tod
  16. 34Phil
    34Phil
  17. 427designer
    427designer
    from Ohio
    First 2 cores for the new B heads.
  18. 427designer
    427designer
    from Ohio
    New batch of Thomas heads.
  19. lsr490
    lsr490
    Sure would be nice as a "B" :)
  20. 427designer
    427designer
    from Ohio
    B heads are next.
    Tod
    GuyW likes this.
  21. I hope the "B" heads are still going to be cast iron with the letter "C"on top.
    Charlie Stephens
  22. 427designer
    427designer
    from Ohio
    They will be.
    Tod
    dwollam likes this.
  23. 427designer
    427designer
    from Ohio
    Got 2 molds for the new B heads 20190403_123021.jpg 20190403_123101.jpg and test fit the jacket cores today. Hope to cast 2 in aluminum within a week.
    Tod
  24. dmdeaton
    dmdeaton
    Lookin good Tod
    What’s the compression on these?
  25. 427designer
    427designer
    from Ohio
    Around 6:1
    Tod
    Outback and warhorseracing like this.
  26. Vernon2
    Vernon2
    any up dates???
  27. nunattax
    nunattax
    a twin plug option would be good
  28. Tin Lizzie
    Tin Lizzie
    from Ohio
    Do you have any Winfield heads available Tod ?
  29. 427designer
    427designer
    from Ohio
    No. I have about 15 to make right now.
    Tod
  30. 427designer
    427designer
    from Ohio
    I have a different twin plug head.
    Tod
