Projects The Thomas Rocket Car Restoration
Discussion in 'The Hokey Ass Message Board' started by mramc1, Jun 7, 2018.
  1. mramc1
    mramc1
    I haven't posted in a while as I have been busy and didn't know how all the picture hosting was going to pan out. This is my first post using the direct uploading so I hope it works okay. Anyway this is build thread for the Thomas Rocket Car, or Car of Tomorrow as it was originally called, designed and built by Charles Thomas in Batavia, NY from 1936-1938.
    Here is the car as it appeared in 1941. The car is a completely hand fabricated 2-door sedan. It has unibody construction, 4 wheel independent suspension, dual master cylinders, four fender skirts, a periscope on the roof, hydraulic brakes, and a full belly pan. The design for this car was the thesis of Charles Thomas for his graduation from the GM Ins***ute in 1935. The engine was a '36 Ford flathead with Ford 3 speed. The front suspension is custom independent swing arm using coil springs, the ends of a '36 Ford axle, some sort of pieced together hydraulics and '36 drums. The rearend is also independent created from a '36 banjo, custom half shafts, and swing arms with coil springs.
    Here are a couple of news stories on the car work has begun in the last two years.
    http://www.thebatavian.com/taxonomy/term/10033
    I have been doing all the underside metal repair on the car at my home shop. Eventually the car will be restored and donated to the city of Batavia, NY to be on display for all to see.
    To say this car was rusty in an understatement. I have had to replace the entire belly pan, trunk floor and wheel wells, floor, rockers, lower quarters, and lower doors.
    Here is the day it arrived.
    I started with the trunk floor and worked my way forward.
    I have also do***ented the full metal work on Instagram at #thomasrocketcar and on my YouTube page. Here is the playlist.
    tb33anda3rd, slim38, AHotRod and 16 others like this.
  2. Chappy444
    Chappy444
    Thank you for saving this car.
    Chappy
    Hnstray and chryslerfan55 like this.
  3. 302GMC
    302GMC
    from Idaho
    Wow … looks like the inspiration for the Saab 92 … wonder if Special Interest Autos knew about this one.
  4. mramc1
    mramc1
    I have a ton of pictures and will put some of them in an album called Thomas Rocket Car under my username. Here is the trunk as I started.
    I started by framing the rear pan and trunk area in angle.
    Next came the sides of the trunk area that hold the fuel tank. All bead rolling matches original lines on the car.
    Next I moved on to the rear firewall area and made some bracing.
    Starting to cut rust out.
    Here is look at the underside. The rearend is '36 banjo, custom half shafts, wide 5 drums with handmade hydraulics, swing arms that mount into floor and GM shocks. Remember this car was built in '36 to '38 before Ford was using hydraulic brakes!
    YouTube Rocket Car playlist.
    https://www.youtube.com/playlist?list=PL5fFr_sm74j9gz-leSaX9Alw90zV4TV8D
  5. mramc1
    mramc1
    After reinforcing the spring tower I was able to remove the rear wheel well. Not too much left.
    My friend Chad helped do the bead rolling on a manual old Eastwood unit.
    Framing the well with some angle made on a Harbor Freight brake and old Eastwood shrinker/stretcher.
    Tops of the well in 18 ga.
    And welded in.
    Here is the replication of the angle iron bracing.
    Throw on a little primer and it looks mint!
    Then onto the driver's side.
  6. tubman
    tubman
    Wow! Big job, but it looks like you're certainly up to it.:cool:
    Hnstray likes this.
  7. mramc1
    mramc1
    With the rear end dialed in I moved onto the trunk firewall. Here is the first panel out of the bead roller.
    Moving onto the p***enger rocker and some door bracing.
    And then onto the driver's side.
    With the rockers done it was time to hack out the floor!
    Uh oh. No turning back now!
    More to come...
  8. pitman
    pitman
    Yee Gods, master of TinFlea infestations!
    Incroyable! Pardone my Francais pauvre.
    Stogy and brad2v like this.
  9. doug j
    doug j
    Real cool car,I like the look.great work!
  10. Squablow
    Squablow
    Great metalwork so far and neat story about an historically interesting custom build. Looking forward to seeing more.
    Stogy and chryslerfan55 like this.
  11. Bugguts
    Bugguts
    Wow! When you said rusty, you meant RUST!
    Very cool that your bringing it back from the dust. Good job!
  12. Neat car!
    Some pretty great metal fab. Read the history on it cool car !
  13. Stogy
    Stogy
    Cool stuff...That was right at the same time the Phantom Corsair was debuting and it shares similarities...Great job your doing @mramc1...a look forward to your progressing adventure.
  14. Hnstray
    Hnstray
    from Quincy, IL
    Great back story and wonderful photos. Thanks so much for posting. Subscribed for future updatse!
    Ray
  15. BJR
    BJR
    It sure looks like the right person got this car. You are doing a wonderful job, please keep posting.
    chryslerfan55 and Atwater Mike like this.
  16. frank spittle
    frank spittle
    Way ahead of it's time.
    Stogy and Atwater Mike like this.
  17. Atwater Mike
    Atwater Mike
    Hambsters stand honored. This is a feat that just wouldn't have happened if not in the right hands. But it's happening. Right. And...Quick!
    Stogy likes this.
  18. bobbytnm
    bobbytnm
    Holy cow! what an interesting project. Thanks for taking time to do***ent the process. You're doing a great job
    Bobby
  19. mramc1
    mramc1
    Began the floor/bellypan reconstruction with a new 1 x 3" spine. You can see how the floor was designed to mimic an airplane wing.
    Corner supports for the torque tube tunnel.
    Here I am starting the main inner rails. Originally all sheet metal channel I am replacing everything with square tubing. I think it will be stronger, easier to work with.
    Starting to frame out the driver's side structure.
    Here you can see the structure for the torque tube tunnel.
    Here are the bead rolled panels for the torque tube tunnel.
  20. 62rebel
    62rebel
    To undertake handbuilding a car unibody from scratch in 1935 is incredible IMHO. Your restoration of it is amazing.
    Stogy likes this.
  21. oldandkrusty
    oldandkrusty
    Josh, I'm speechless! The work you and the guys are doing is just friggin' awesome. Keep on hammering, my friend.
    John
  22. flt-blk
    flt-blk
    from IL
  23. goatboy
    goatboy
    from kansas
    wow glad youre doin it !!!! I woulda let that one stay in da junkyard !!! lol
    good luck, looks like you have a ton of talent to pull it off, will watch
  24. Stogy
    Stogy
    I would like to alert everyone who works on old cars...
    This is not to alarm but just be aware that some of the stuff they used may have contained asbestos...when I saw this pic thats the first thing I thought...now I could be wrong...
    Asbestos isn't nessesarily a threat but when its upset and broken apart the danger exists.
    It was also used in vintage brake shoes and probably clutch discs...
    It can and should be treated and safely removed and should be replaced with another type of material if possible.
    It is truly dangerous and if it is and is still in your shop I think they wet it down and wrap it in heavy plastic and seal/encapsulate it to dispose of.
    This is in respect to you and the membership as I want you all to live long and free of terrible things caused by love of an old car....
    One other thing is if you don't know what it is ***ume it may have rather than not...it may save your life.
    @mramc1 I did watch your video and you identified this as a heat shield only...again we must be very careful of things we encounter. I was glad to see you at least wearing a dust mask and some other protective equipment. That thing was built like a plane you are correct.
  25. cederholm
    cederholm
    Amazing work!
  26. HOTRODPRIMER
    HOTRODPRIMER
    Extremely nice work on saving a unique piece of automotive history. HRP
    nochop and chryslerfan55 like this.
  27. mramc1
    mramc1
    It's not actually exhaust. It's a rear seat heater to duct air from an exhaust heat exchanger to under the rear seat. The checkerboard pattern in little strips of copper wrapped around asbestos wrapped around wire mesh. So yes, the air being piped into the rear of the car probably contained asbestos fibers.
    chryslerfan55, Stogy and flatford39 like this.
  28. mramc1
    mramc1
    Thanks for pointing this out. I didn't mention it to not muddy the waters, but I guess it is important. So I didn't have the white stuff tested, but I am almost sure that being built in 1936, before an knowledge of asbestos being bad for you, that that stuff was probably "hot." I work where they have an asbestos remediation program so I treated the insulation as it was asbestos. I watered it down really well, removed it with as little disturbance as possible, wore gloves, throw away clothes, a respirator, and double bagged it all in asbestos bags which were disposed of properly.
    This was all done before any grinding was done to make the stuff friable. Thanks for bringing it up though as some people are probably unaware that there can be unforeseen dangers while working in the old car hobby.
  29. woodbutcher
    woodbutcher
    :D Very nice.I`ll saddle up and go along for the ride.
    Good luck.Have fun.Be safe.
    Leo
