Projects Prep roof for sound deadening
Discussion in 'The Hokey Ass Message Board' started by RockinRivi, Jun 7, 2018.
  1. RockinRivi
    RockinRivi
    Trying to take this 50 year old cardboard sound/heat barrier off is harder than I thought. I plan to use some sort of Dynomat Peel & Stick of sorts. How clean do u guys suggest I get this?
    That bare metal area wasn’t too hard. But that area was already kinda coming off on its own. Now that I am getting to the area that didn’t have issues it’s a bit harder to s**** off.
    I’m kinda leaning towards leaving whatever wants to stay in place alone. Then slapping my stuff on over it. Or is that a bad idea?
    65 Riv Build
    http://forums.aaca.org/topic/228549-my-65-another-build-to-follow/
  2. Engine man
    Engine man
    from Wisconsin
    I would use one of these $5 cup brushes from Harbor Freight.
    JeffB2 likes this.
  3. RockinRivi
    RockinRivi
  4. hoodwinx454
    hoodwinx454
    You could also try a heat gun to help soften the adhesive and s****e it off. I can’t see your pic
  5. s55mercury66
    s55mercury66
    from SW Wyoming
  6. southcross2631
    southcross2631
    I used a cup brush on my Morris Minor to remove the sound deadener. It makes a mess and is real dirty so wear a dust mask and goggles.
    Stogy and Just Gary like this.
  7. hotrodharry2
    hotrodharry2
    from Michigan
    I wouldn’t use another Harbor Freight wire brush! The wires come off and become imbedded in your jeans, go through your shirt. I buy a better brand & I know from personal experience. Better brands are worth the extra bucks. Good Luck
    56don and anothercarguy like this.
  8. Engine man
    Engine man
    from Wisconsin
    Whenever you use a wire brush or a grinder for that matter, you need to wear proper safety gear including a face shield, leather gloves, long sleeves like a leather welding jacket and a leather apron is good. $50 cup brushes throw wires too. What I like about the cheap brush is that the wires are very fine and don't have as much momentum as heavier wire.
  9. Just Gary
    Just Gary
    X2!!!
    Stogy likes this.
  10. southcross2631
    southcross2631
    Don't believe that ******** about the more expensive brushes don't throw the wire strands. They all do.
    Make sure you wear a face shield . It is not fun pulling wire out of your face. Ask me how I know , it was from a 25 dollar cup brush.
    mgtstumpy and Lone Star Mopar like this.
  11. j walking
    j walking
    after you clean it save your money. Don't by dynomat. go to Lowe's and but the silver duct wrap. For $40 you can do your whole car. We use it al the time. You'll feel like your in a cooler! Cool in summer and warm in winter. We use vinyl top glue to put on. Give it a try.
  12. gimpyshotrods
    gimpyshotrods
    My Dynamat has been on the underside of my roof for over 6-years. It has not peeled off, in any way, in any place.
    I have never seen building supply store products do that.
    All wire brushes throw wires. The cheap ones just throw more, and faster.
    mgtstumpy and LM14 like this.
  13. JeffB2
    JeffB2
    from Phoenix,AZ
    This has been on the underside of my roof for 5 years in 120 degree Phoenix heat no issues at all. Right next to this is the aluminum seam tape get it too about $3 and the little wood roller used for wallpaper seams. Before I applied it I wiped the surface down with Brake-Kleen and painted it with Rustoleum aluminum paint with a brush. 1p&s.jpg
    RockinRivi, tb33anda3rd and alanp561 like this.
  14. RockinRivi
    RockinRivi
    Still not sure how to work this pic thing.
    Thanks for all the help guys. Here is the end results:
    I used a paint s****er & slowly chipped away the old stuff until it all came off. I tried a heat gun & it did seem to help.
    First pic is at the half way point.
    Once all s****ed I cleaned & sprayed it with Rustoleum. Then I used leftover Dynamat from a previous project.
    Thx again for all the help
    65 Riv Build
    mgtstumpy likes this.
  15. bobss396
    bobss396
    I used a DA sander on mine with a 36 grit pad and it worked well.
    RockinRivi likes this.
