Projects Peugeot 301 roadster pickup?
Discussion in 'Traditional Hot Rods' started by Mateusz, Jun 2, 2018.
  1. trey32
    trey32
    Very Kool, keep going
  2. Ya know when I go to a show, I`m drawn to builds like this . Keep up the cool work and pictures
    chryslerfan55 and czuch like this.
  3. woodbutcher
    woodbutcher
    :D This looks like fun.I`ll saddle up and go along for the ride.
    Good luck.Have fun.Be safe.
    Leo
  4. rustednutz
    rustednutz
    from tulsa, ok
    Very interesting project. I'll follow along as well.
  5. Mateusz
    Mateusz
    Wider frame is much better! IMG_20180611_190912.jpg IMG_20180611_193830.jpg IMG_20180611_193839.jpg
    Now Time to make all gussets, engine mounts etc. I'm also thinking how to lower rear suspension.
  6. drtrcrV-8
    drtrcrV-8
    "Z" the frame in front of the spring mounts?
  7. Mateusz
    Mateusz
    I like the look of the oryginal frame. Maybe I'll make mountings higher or mount normal leaf springs (frame should be longer)
    chryslerfan55 and millersgarage like this.
  8. rgdavid
    rgdavid
    Any way to mount spring inside the rails ?
    Rienforce with plates on sides and top ?
  9. Mateusz
    Mateusz
    That's good idea but i think i need more. Maybe should try to straighten springs somehow.
  10. czuch
    czuch
    from vail az
    Your ex-ol lady wrapped up in the plastic sheet has to get lost.
    All kidding aside, That's a real nice project and I like the hood sides.
    chryslerfan55 and Mateusz like this.
  11. Mateusz
    Mateusz
    Haha ex-ol lady.
    I really dont like these Hood sides anyway.
  12. rwrj
    rwrj
    from SW Ga
    What if you moved the anchor for the springs back? That would lower the rear and lengthen the wheelbase by a few inches. I drew a quick before and after sketch.
  13. Mateusz
    Mateusz
    Interesting idea but i'm affraid that wheel base Will be too long. Maybe I'll make some mounts inside the Rails with another angle.
  14. rwrj
    rwrj
    from SW Ga
    How much drop do you need? I'll bet you could remove half of the leaves. Truck suspensions are usually pretty stiff. Or, what if you remove the spring pack, flipped each leaf over, and re***embled it upside down?
  15. Mateusz
    Mateusz
    I want to lower it about 4 inch or more.
  16. Bandit Billy
    Bandit Billy
    Clever!
  17. Mateusz
    Mateusz
    More next week.
    chryslerfan55, kidcampbell71 and bct like this.
  18. rwrj
    rwrj
    from SW Ga
    You could reverse the eye on that lower leaf pretty easily. Looks like about an inch right there.
  19. Atwater Mike
    Atwater Mike
    Good thinking, @rwrj. I believe one could remove some as well...And/Or pound them 'flatter' on that anvil that's bigger than my Peter Wright!
    Man, that's a 'Railroad Anvil'...(I saw one like that in the old locomotive repair shop/Roundhouse in San Jose, CA. years ago. A thing of awe and beauty!)
  20. czuch
    czuch
    from vail az
    Real men have anvil envy.
    I have vice envy. I just got a real nice 6" Wilton.
  21. Mateusz
    Mateusz
    Making them flatter is the Best idea i think. We will See. Thanks for advices.
  22. nunattax
    nunattax
    wont reversing it lower it 1 inch x 2 =2 inch .tai think moving the springs inboard the frame will have the effect of stiffening the ride while moving outboard will soften the ride.law of the lever and that .take the spring pack apart remove leaves 6,4 and 2.blast it with a fine grit ,light coat of paint and grease between leaves.removig leaves should lower it and soften the ride.then if its too soft or too low you can put some leaves back in.adjustable suspension if you like..
    czuch, chryslerfan55 and Mateusz like this.
  23. Mateusz
    Mateusz
    Inboard stiffening and Outboard soften?
  24. Mateusz
    Mateusz
  25. robber grin
    robber grin
    This should be fun to watch...
    Go man
  26. willymakeit
    willymakeit
    I’m in That front suspension has me thinking? Which is always expensive for me.
  27. Mr48chev
    This should be interesting as the 34 Peugeot 301 was no slouch in the looks department to begin with. Peaugot 301 1934.jpeg
  28. Mateusz
    Mateusz
    Its more like this
    nunattax, czuch and chryslerfan55 like this.
  29. fiftyv8
    fiftyv8
    from CO & WA
    Just remove a couple of the shorter leaves out of the rear springs and see how it sits.
    You may not need to do much else with a little luck...
    If that don't work, you can cold set the leaves that you are using with a big hammer and an anvil setup correctly or a press.
    Mateusz likes this.
  30. czuch
    czuch
    from vail az
    I like the vents in the sides of the hood even more after those pics.
