How far can you mill a Mopar flathead!
Discussion in 'The Hokey Ass Message Board' started by krooser, May 2, 2006.
  1. krooser
    krooser
    Looking to get about 14 to 1 compression outta my '48 218 Plymouth sixbanger. How far can you SAFELY mill the stock head? thanks....
  2. kenagain
    kenagain
    from so cal
    why so much lower end will go first unless you are running alcohol
    ken
  3. Bugman
    Bugman
    Find a spare head and saw it in half :D I've got a head I want to mill apart, but can't find anyone who will let me play on their mill :(
    Although I'm sure you know already, milling the head that far will cause more shrouding of the valves which may negate any affects the compression may gain you. now if you mill it, and offset it to the valve side of the block slightly, you may have something....
  4. krooser
    krooser
    Geez...I was KIDDING!?!?!?! But I still need to know.....
  5. krooser
    krooser
  6. FEDER
    FEDER
    kROOSER
    First I would ultra soud the head surface for thickness. I would ***ume they a awfully thick.
    Then i would put a piston in the hole measure it from the deck surface.
    You will find You probably have room to deck the block first. Then cc the piston with the (500) down method.
    Then cc the head - add the thickness of Your head gasket. Figure you compression.
    The only thing that will limit You excessivly milling the head would be valvelift. So you will have to clay the valves to check valve to head clearance. So You should have the cam Your going to use installed.
    You can unshroud valves easy. Just try and keep as much quench area as possible. And alcohol WONT make your bottom end last any longer. FEDER
  7. krooser
    krooser
    Thanks...I'm not really getting too involved with this thing..I'm fixing one hole and maybe doing bearings.
    I figured as long as the head is off, I could mill it a bit for a little more compression.
  8. DrJ
    DrJ
    I know someone who said he milled the head on a Packard so much he had to double washer the spark plugs to keep the valves from closing up the plug gaps.
    Another consideration if the plugs happen to be above the valves.
  9. blown49
    blown49
    Remove the head and gasket. Clean head and deck surfaces. Put clay on the valves and pistons. Reinstall head with no gasket, snug down bolts & leave plugs in. Rotate crank 4 revolutions. Remove head and measure clay thickness. Find thinest piece of clay and subtract 0.100". Difference is clearance to be milled. If this is a big thickness it may not work as you may strike water!!!!
  10. krooser
    krooser
    Okay..If I strike water, how far 'till it's drinkable?!??!
  11. moose
    moose
  12. krooser
    krooser
    .040 sounds about right. Thanks to all who've helped answer this question.
  13. HEATHEN
    HEATHEN
    from SIDNEY, NY
    My 1952 copy of Hot Rod Your Car says .070 for Mopar sixes in its head milling chart.
  14. krooser
    krooser
    Really! I guess I would have stopped at .040...I'll have to check clearances and see...Thanks.
  15. years ago I ran a 230 with .060 off the head. Never had any problems.
  16. Back in the 60s, .060" was the rule of thumb for any flathead motor.
  17. sufoowt
    sufoowt
    Back in the 60's we cut a 46 plymouth six head .125. Didn't hit water but smashed the **** out of the plugs and had to use washers under the head bolts. .040 should give you what you want.
    fred
  18. BloodyKnuckles
    BloodyKnuckles
    I've been told .070 would be fine but an old timer by the name of George Asche has been messing with these engines for a long time told me to take .090 off. I would be inclined to do it.
    Good luck on your decision.
    ******Knuckles
  19. kenagain
    kenagain
    from so cal
    In earlier post I mentioned alcohol with hi compression
    and the lower end I know for a fact you cant get the lower end to hold up if it is stock running gas and hi compression I have had stock bearings in vw running 16 to 1 compression with hilborn fuel injection on menthanol and lower end held up fine= went away with gas plus had lottsa cooling problems hope this clears up alcohol wont help lower end
  20. when it comes to Mopar flathead sixes, if George Asche says "go .090"
    I'd go .090
