Technical how did you paint that? fixtures and taping technics
Discussion in 'The Hokey Ass Message Board' started by tb33anda3rd, Feb 10, 2016.
  1. tb33anda3rd
    tb33anda3rd
    thanks, they are for a Packard
    Bowtie Coupe likes this.
  2. edcodesign
    edcodesign
    Great job & a very informative post, thanks !
    Bowtie Coupe and tb33anda3rd like this.
  3. 41rodderz
    41rodderz
    from Oregon
    I like the tips and tech. Thanks guys ;)
  4. tb33anda3rd
    tb33anda3rd
    used some plumbers strap, bolted to the part and screwed to the saw horse. it was strong enough to hold it rigid yet once it was filler primed on the face side, i could twist it over so i could paint the back side. DSCF0004 2.JPG DSCF0005 2.JPG
    brad2v, Bowtie Coupe, MP&C and 2 others like this.
  5. rusty valley
    rusty valley
    my rig for painting wheels. mostly made fore wire wheels, they are a bitch to paint. this rig runs at 5 rpm. you can thin the paint all you want so it melts into the bottom coat, and will never run, no dry spots, no orange peel, no skill required for a perfect job every time. bad news is its one at a time. good news is it also can be used to check the wheel for true. pull a pin, lift up the arbor and easily take off the belt and spin it by hand to watch it wobble! i have also used it for other small parts, really anything you want to spend time to mount it will come out perfect with no skill IMG_1217.JPG IMG_1218.JPG IMG_1219.JPG IMG_1221.jpg IMG_1220.JPG
    Truck64, rc57, ct1932ford and 12 others like this.
  6. tb33anda3rd
    tb33anda3rd
    to prime an A coupe i cut a piece of uni-strut to fit under the top boards, then bolted a couple eye bolts to the strut and hooked a chain to the trolleys . it was balanced so i could tilt it to prime the under side. DSCF0004.JPG
    Just Gary, ct1932ford, brad2v and 6 others like this.
  7. nunattax
    nunattax
    nice job
    brad2v, Bowtie Coupe and tb33anda3rd like this.
  8. nunattax
    nunattax
    nice to see someone doing a thorough job ted
  9. The37Kid
    The37Kid
    Just like the factory. Bob
  10. I bet your happy to be priming that one
  11. That's pretty slick!
    You could easily stick a stub out the other end and make it get 2 at a time ?
  12. That's a good one, I'll need to remember that. Thanks !
    tb33anda3rd likes this.
  13. tb33anda3rd
    tb33anda3rd
    thanks, chris.
    i am almost at the bottom of a gallon of epoxy [1 to 1mix] and am into my second gallon of filler primer [4 to 1mix] , including all the rest of the body parts.......
    were they dipped?
    you got that right. although i am waiting to get the tailgate back from the guru, who is riveting the hinges back on after i primed it..........it was supposed to get done while the gc waited......going on a week..............i should have just done it myself but the gc wanted him to do it...........
    camer2, Bowtie Coupe and MP&C like this.
  14. atch
    atch
    Very nice. Switch out the pulleys to run faster and voila! you've got a rim polishing fixture.
  15. RMR&C
    RMR&C
    from NW Montana
    My redneck rotisserie for priming all sides of my frame at once. Engine stand w/simple angle brackets slid into the frame horns up front....a long piece of 1" pipe clamped on and rolling on a saw horse in back. Worked really well!
  16. RB35
    RB35
    Woof! Thanks to all who shared. Car is blown apart, sanded waiting for weather, got to be done for the Jalopy Showdown and time is running out. After this thread, I think I can get it done!
    Thanks again!
  17. tb33anda3rd
    tb33anda3rd
    a few hours after the filler primer went on, i sprayed the underside, inside and all the "hard to get" spots DSCF0001.JPG
    Lil32, nunattax, ct1932ford and 4 others like this.
  18. tb33anda3rd
    tb33anda3rd
    i had painted all the edges of the windshield frame after i had primed it. i then assembled the glass and the upper hinge, trimmed the bedding tape. i then wet sanded it smooth and once dried i taped off the glass. i bolted the hinge to my paint rack in the position it sits on the car. i was able to "open" the window to get a final coat on hinge area. after the paint dries and before removing it from the rack i will install the outer seal.
    no chance of scratching the paint when installing the glass if the paint is still in the can................;) DSCF0005.JPG DSCF0004.JPG
    MP&C, ct1932ford, brad2v and 6 others like this.
  19. RMR&C
    RMR&C
    from NW Montana
    I stood my 9" housing on end and screwed it to a large square board. A single wire to the ceiling helps steady it.
    MP&C, jazz1, brad2v and 5 others like this.
  20. tb33anda3rd
    tb33anda3rd
    painting two colors. first, prep for paint, i decided to paint the whole thing black first. DSCF0008 2.JPG DSCF0001 2.JPG
    i taped off all the holes and covered the inside to keep any dust/dirt/sand still stuck in the nooks and crannies from getting in the out side paint.
    MP&C, brad2v, nunattax and 2 others like this.
  21. tb33anda3rd
    tb33anda3rd
    MP&C and Bowtie Coupe like this.
  22. tb33anda3rd
    tb33anda3rd
    the next day i sanded the areas that were to get the other color. i then cleaned it and used a plastic "fine line" tape on all the edges to be taped off. then i papered and taped all the parts that were to remain black. DSCF0001.JPG
  23. tb33anda3rd
    tb33anda3rd
  24. tb33anda3rd
    tb33anda3rd
    untaped after lunch.
    clem, safetythird, Lil32 and 10 others like this.
  25. ct1932ford
    ct1932ford
  26. The37Kid
    The37Kid
    Brewster N.Y. Fire Chief will want that, saw one of their trucks Tuesday Black top looked really nice. Bob
  27. RMR&C
    RMR&C
    from NW Montana
    Wow, that's different!. Post a pic of it when all together if you can.
  28. 340HilbornDuster
    340HilbornDuster
  29. clem
    clem
    Bungee cords hanging from washing line,
    - no decent trees around .......
    ( refer post 71 )
    MP&C, brad2v, Bowtie Coupe and 3 others like this.
  30. tb33anda3rd
    tb33anda3rd
    safetythird, Lil32, Mahty and 11 others like this.
