Projects Model T Speedster....... my take on it
Discussion in 'The Hokey Ass Message Board' started by ottoparts, May 25, 2018.
  1. rwrj
    rwrj
    from SW Ga
    Man, this looks fun. Watching.
  2. Nice! This is definitely one of the cooler projects I've seen in a long time. Love the fab work you are doing. Good luck and have fun!
  3. 20170702_171530.jpg 20170702_161803.jpg 20170702_165112.jpg 20170703_170951.jpg 20170703_171001.jpg 20170708_184546.jpg 20170703_175638.jpg Well, this may be where I loose a few of you. With the Warford having a proper neutral and whether it's rolling in the driveway or running down the street.I need a way to make sure I can properly stop. Disc brakes seem like a simple solution. Please don't fear, this will be the only non-traditional T part on it. Let's get to it.........
  4. In the previous post you can see that I trued up the hub. Cut some aluminum round stock. Lipped it for the rotor to ride/seat and finally tapped the aluminum for the bolts to hold the rotor. In the next set of pictures you can see that the aluminum round stocks ID was increased to match that of the hub. Tapped the aluminum again for the lug studs. The studs come in through the inside holding the hub to the aluminum.
    20170703_191344.jpg 20170703_191350.jpg 20170703_200432.jpg 20170703_200512.jpg 20170703_200518.jpg 20170703_200643.jpg
    S1B, Stogy, scotts52 and 5 others like this.
  5. The37Kid
    The37Kid
    [​IMG] That vice thumb saver it really cool, guess you text on a cell phone.:rolleyes: Bob
    Stogy likes this.
  6. Tim
    Tim
    from KCMO
  7. jkski
    jkski
    got to see how this ends!
  8. With the hubs finished, time to make caliper mounts.
    20170717_194104.jpg 20170722_103340.jpg 20170722_103402.jpg 20170722_163240.jpg 20170722_163244.jpg 20170722_163812.jpg 20170722_163820_001.jpg 20170722_171814.jpg 20170722_182218.jpg
    S1B, Stogy and indestructableforce like this.
  9. In the previous post you can see that the caliper had to be clearanced a bit and each bracket is side specific (in the pictures you can see two dimples in the aluminum caliper bracket). Pressed in some new bushings, hone to fit, and time for a mock up. While at it, lets throw in a dead perch. 20170723_103153.jpg 20170723_103202.jpg 20170723_151536.jpg 20170723_151550.jpg 20170730_163601.jpg
    S1B, anthony myrick, Stogy and 5 others like this.
  10. flatheadpete
    flatheadpete
    from Burton, MI
    Crafty. I'm diggin it!
  11. Do the steering arms clear everything?
  12. Yes they do. More coming up on that later.
  13. No real build/clean up pictures of the Warford. However I took two and created a good one. The shift knob was sourced off of here. This is how the ch***is sits...............
    20171126_172002.jpg 20171126_172008.jpg 20171126_172027.jpg 20171224_160229.jpg 20171014_141628.jpg 20171014_141641.jpg 20171014_141659.jpg
  14. Dean Lowe
    Dean Lowe
    With those cool disc brakes I strongly advise beefing up the front wishbone. I know a couple of T guys that wished they did!
    Chili Phil and GuyW like this.
  15. Couple of block issues. New block acquired and a little machine work performed.
    20170511_182641.jpg 20170511_182744.jpg FB_IMG_1530081651746.jpg FB_IMG_1530081648094.jpg FB_IMG_1530081643455.jpg 20180114_095148.jpg 20180114_104426.jpg
    indestructableforce and AHotRod like this.
  16. The37Kid
    The37Kid
    I'm sorry, I owe you an apology, when you posted the first photo of this project I didn't think you knew what you were doing, I was very wrong.:oops: Bob
    Stogy likes this.
  17. DDDenny
    Dean
    I have zero experience with this combination but I am more concerned about those wheel spokes living with the grip from the disc brakes.
    Nice work Chris.
    Stogy and GuyW like this.
  18. No need to be sorry. I haven't performed all of this on my own. I have great friends helping!
    Stogy likes this.
  19. My disc brakes are a copy of my friends on his 26 T. He has many many miles on this set up. A book just came out about his T. 51WXUzTO3UL__SX258_BO1,204,203,200_.jpg
  20. GZ
    GZ
    from Detroit
    Amazing creativity and workmanship! You certainly know of the meaning of doing things right. Also, the timeline is incredibly impressive-you have accomplished more in a couple of months then most people accomplish in a couple of years. Having built at least a few T speedsters, I am extremely impressed. Well done.
    Stogy and The37Kid like this.
  21. 20170802_200400.jpg 20170813_131939.jpg 20170821_080715.jpg Time to go through the parts and evaluate the conditions. What to use, what to fix, what to toss. The last picture is of a 26/27 clutch drum turned down to fit my 25 and older set up. This drums has the updated availability to replace the lugs that the clutches ride on.
  22. seb fontana
    seb fontana
    from ct
    Engine oil system, I know its splash but don't see a scoops or dippers on the rods?[​IMG]
    Stogy likes this.
  23. There were none on that engine. The one I am building will have dippers.
    Stogy, brEad and 64 DODGE 440 like this.
  24. seb fontana
    seb fontana
    from ct
    So is there supposed to be dippers stock or the way ford made the rods was with out? Sounds like wish full oiling!..
    Stogy likes this.
  25. 492063.jpg No dippers stock.
    Stogy likes this.
  26. Sorry as I misunderstood what you where asking. No dippers from Ford.
    Stogy likes this.
  27. Dean Lowe
    Dean Lowe
    "Performance" T engine builders used Chevy 4 dippers on T rods back in the day. You have to drill a hole in the rod cap.
    Stogy and Chili Phil like this.
  28. Time for a little procedure called "aligning the transmission". True the end of the crank and transmission input shaft. Put a center dowel in. Stuck the together and checked for proper alignment.
  29. Crank then laid into the block, flywheel added and check many, many, many times for proper alignment.
