Projects 1964 Chevy II "Flak Magnet"
Discussion in 'The Hokey Ass Message Board' started by LTKMUNN, Feb 6, 2018.
  1. southcross2631
    southcross2631
    Nice shoebox . A little tip for your rear ******* bars. Extend the front until they hit the front spring eye.
    It makes them work better and that way it won't bend the front of your springs when you launch it.
    Ran a Chevy 11 like yours in super stock years ago with a 283 4 barrel 4 speed . Very nice cars.
    catdad49, loudbang and LTKMUNN like this.
  2. LTKMUNN
    LTKMUNN
    from New Jersey
    Yeah I know haha, when I put them on they were a little short, and was going to get longer ones because I didn't like how far back the snubber was sittings since it wasn't centered on the spring eye.
    catdad49 and loudbang like this.
  3. bobss396
    bobss396
    Great tip on the spring-eye thing. It takes all the lever out of things... all fulcrum. My bars are set up away from the spring-eye, I'm not putting out enough HP to tweak my main leaf.
  4. LTKMUNN
    LTKMUNN
    from New Jersey
    Figured I would update the project. Motor is in the car and wired up, this weekend the trans is going in. Tin work is basically done just need to polish the tubs then clear coat them. then finish the fire break above each tub. Trying to get the motor fired up soon before the cold weather starts. _DSC0015.JPG _DSC0020.JPG _DSC0022.JPG _DSC0018.JPG
    swade41, AHotRod, catdad49 and 4 others like this.
  5. Fuelaltereds4life
    Fuelaltereds4life
  6. LTKMUNN
    LTKMUNN
    from New Jersey
    Long Due for an update, as for the car, motor is in, runs nice. not under its own power yet. Was mocking up the aircleaner. I needed to message the hood alittle for fitment. will be putting a tunnel ran style scoop on from speedway. changing some things up with the plumbing on the front brakes, then putting the trans back in the car and getting her fitted for a driveshaft. IMAG0046[1].jpg IMAG0047[1].jpg
  7. LTKMUNN
    LTKMUNN
    from New Jersey
  8. LTKMUNN
    LTKMUNN
    from New Jersey
    Some update shots from the last cruise, still babying the car till its gets some miles on everything.
    upload_2019-11-28_10-47-29.jpeg upload_2019-11-28_10-38-33.jpeg upload_2019-11-28_10-39-55.jpeg
    swade41, catdad49, loudbang and 3 others like this.
  9. loveoftiki
    loveoftiki
    from Livonia,Mi
    Looks like a bad *** little car
  10. LTKMUNN
    LTKMUNN
    from New Jersey
    Very cool! I always liked wagons, unique! What was the combination you were running?
  11. LTKMUNN
    LTKMUNN
    from New Jersey
    IMG_5757.jpeg IMG_6809.jpeg IMG_5754.jpeg IMG_6707.jpeg IMG_6723.jpeg IMG_6722.jpeg Figured I would post some updates on the car. Changed to the correct year grille last summer and added some cal trac bars with a few other small odds and ends.
  12. LTKMUNN
    LTKMUNN
    from New Jersey
    IMG_8225.jpeg IMG_8224.jpeg IMG_8227.jpeg Found some vintage 70s centerline front runners, added some new rubber as well. Eventually Ill get a matching rear.
  13. patsurf
    patsurf
  14. deathrowdave
    deathrowdave
    from NKy
    I had 2 , 66 Models growing up . There isn’t a lot of metal holding the front of the car together anyway .
    LTKMUNN likes this.
  15. LTKMUNN likes this.
  16. DDDenny
    Yeah, the first and second gen. Nova/Chevy II's were pretty soggy, I'd either plate those cutouts or do some sort of shock tower struts to tie them together (or both).
    Made this arrangement for my 67, also extensive front suspension upgrades.
    LTKMUNN likes this.
  17. LTKMUNN
    LTKMUNN
    from New Jersey
    Yeah, they do have delicate front ends. I do eventually need to weld up the towers. Im coming up with a design that gives me more header clearance. Im running some stahl fenderwell headers.
  18. oldiron 440
    oldiron 440
    Looks like 1980 all over again :)
    LTKMUNN likes this.
  19. LTKMUNN
    LTKMUNN
    from New Jersey
    Thanks! Its a very fun car!
  20. 57Fury440
    57Fury440
    I am not big on patina, but that car looks good the way it is. Nice job. I love old drag cars, that's why I still drive mine.
    LTKMUNN likes this.
