** OFFICIAL ** hot rod clutch brake pedal thread !
Discussion in 'The Hokey Ass Message Board' started by 117harv, Aug 2, 2012.
  1. cretin
    cretin
    Right is 33/34. Left looks like F1.
    117harv likes this.
  2. ls1yj
    ls1yj
    from Kentucky
    Thanks ******
    cretin likes this.
  3. treb11
    treb11
  4. bct
    bct
    kidcampbell71 likes this.
  5. cadillacoffin
    cadillacoffin
    Anyone have some pictures of f1 pedals in a 32 ch***is?
  6. 40FORDPU
    40FORDPU
    btt..for a great thread.
    bct and 117harv like this.
  7. neilswheels
    neilswheels
    from England
    This is slick, i'll bank this one just incase my Hydraulic stuff doesnt work..
    ls1yj likes this.
  8. neilswheels
    neilswheels
    from England
  9. ls1yj
    ls1yj
    from Kentucky
    Got a question for you’s guys.... I’m gonna run 39 pedal set in my model 40 ch***is, and am in process of getting x-member cleared for clutch pedal to clear it when depressed... it looks like I’m going to have to heat and bend the arms, to clear the F1 steering column, and get in right spot.
    Question: is it bad to heat and ‘straighten’ the pedals out? They currently are kicked heavily (stock) to the left, and will need to get stood up some to get positioned around the column... will this raise them too high in the vehicle?
    Looks like the lever will get an inch or more longer when straightening them out some
  10. RoddyB34
    RoddyB34
    I have mounted my pedals in our Model A to the trans mission mounts in the correct position to enable the stock A pedals to be used ,,the chev steel bellhousing is using a clutch fork that is pulled backwards I added a lever to the pedal underneath and made a pull rod the pedal is spaced out about an inch further out on shaft to get direct alignment to the fork outer pivot ,a shaft support goes forward to the back of the engine mount ,,the brake pedal is stock and I will utilise the original cross shaft by adding a lever to push forward to a cross member mounted dual cylinder ,,not a good pic I know ,,can add more ,,clutch appears to travel far enough ,,as yet engine (Mercruiser 181)not running ,,brake link and mount is next ,I will do some pics as we go ,,I am trying to keep it simple using as much original parts as possible and making things to keep costs down ,,3 speed mustang type T/Loader adapted to closed driveline ,, image.jpeg
    ls1yj, dep5, 46Chief and 3 others like this.
  11. 1934x1934
    1934x1934
    33/34 Ford pedals with hydraulic clutch/brakes
  12. Here is a picture of the master cylinder mount in my AVATAR. No need to show the pedals since they are 100% stock. The original mechanical brake rod can be seen coming through it's original hole in the cross member. I bolted a plate to the back of the original K member using existing holes and welded a piece of square structural steel to it (to avoid welding to the vehicles original K member). I sized all of the levers to be the same as a '39 pedal ***embly so the leverage and amount of travel is correct. I incorporated a '39-'48 master cylinder. The master cylinder is in the correct location to use the battery box inspection plate to fill it. I made a mirror image bracket to mount the battery on the right side of the frame.
    Charlie Stephens
    kidcampbell71, bct and -Brent- like this.
  13. 1934x1934,
    Do you have any more pictures of the linkage to master cylinders, and how you pinned shaft to lever?
    I'm planning in using original pedals to run hydraulic master to hydraulic release bearing in my car.
  14. 1934x1934
    1934x1934
    Algoma56, I drilled through the grease fitting and out the other end of the pedal, then tapped the back side of it. I stuck a grade 8 bolt through it...I need a shorter one though.
    kidcampbell71 and ls1yj like this.
  15. cederholm
    cederholm
    Awesome thread! ...and I'm bringing it back.
    Anyone have a pic of a 40 setup on a 32 K member? Bonus points if it's in an A with a Ford top loader. I'm very interested in the clutch linage.
    Thanks,
    Carl
  16. bct
    bct
    ive seen pics. its not pretty. apples and oranges
    cederholm likes this.
  17. bct
    bct
  18. cederholm
    cederholm
  19. bct
    bct
    not sure how you would go about it. f1 used a tab on the bearing shaft and the 39 has an arm. did you see my ***embly a page or two back where I switch 38pedals around in a 32ish pedal box? its untested on the road but should work well. might help you situation.
  20. pecker head
    pecker head
    EB40C732-3511-41B2-85E5-1B891323CA1A.jpeg B600A6B0-B2E1-45F9-9978-D032DC8D2F71.jpeg 61E81C06-9736-4B65-868D-42BC96A9E683.jpeg 1E60275E-8E04-4226-B8B8-E3151E862E78.jpeg Weld on frame bracket I made to mount F1 pedals and early Mustang master cylinder to Model A frame.
    kidcampbell71, ls1yj, LAROKE and 2 others like this.
  21. pecker head
    pecker head
  22. DDDenny
  23. Mechman_22
    Mechman_22
    from Nc
    bump for some helpful info
  24. Lil'Alb
    Lil'Alb
    from brier, wa
  25. StrickV8
    StrickV8
    483024D9-17FB-439F-A235-3EC3B5C25789.jpeg 06B30C70-768F-42ED-9688-4EE99EF21E0E.jpeg 50C97C4A-1246-4DC6-83FD-C67E92415AB4.jpeg 348A6DEE-5247-480A-8164-C1B40874C80E.jpeg 8421C922-4FEF-45D0-BD3A-020D75739556.jpeg This modified brake pedal was in a 32 pedal box when I bought my 32 Ford ch***is. If anyone could use, let me know and I’m sure we could work out a deal
    Foxbasealpha likes this.
