Projects 41 Ford pickup finally got it home and pictures pictures
Discussion in 'Traditional Hot Rods' started by joel, Jul 19, 2017.
  1. joel
    joel
    Today ,after turkey, I snuck out to the garage with Eric and set the dwell and reset the timing on the truck. Eric took me for a ride in it afterward. Over the last week, V8bob helped me with some info about FH ignition and a good vacuum advance for my Load a Matic. I didn't know about the internal resister coils and I had wired the stock 41 in front of the coil. It is a good Thanksgiving.
  2. joel
    joel
    Not much going on with the holidays and my cataracts finally needed to be done. I had to lay off body work and I could hardly see to do anything else. I cleaned up a spare column drop before the surgery and painted it. I ordered some new parts and ***embled it last Saturday.
    The detent screw in the last pic came out of a rusted POS 40 drop and it was all I could save.
    I found my voltage leak yesterday; it was the starter push****on with a path to ground, so I installed a new one. I ordered a turn signal switch and some wiring to add it to the truck. I didn't get to drive it a lot, but enough to know that I want turn signals. I should be back on the car after Christmas.
    Kelly Burns and PONTNAK123 like this.
  3. joel
    joel
    I've been doing odds and end on the truck while my eyes were healing ( cataracts) and I got the turn signals installed and tested. Great! I also bought a cowl vent operator from a man on the Fordbarn. It's a nice piece and he included the mounting brace that was cut out of my truck. I cleaned it up and painted the parts. IMG_0808.JPG IMG_0809.JPG IMG_0810.JPG
    I also rebuilt a 2g Rochester to put on a mercury manifold ( 4 bolt carb mount ) that I plan to put on the truck later this year.
    rkkoehler and The 39 guy like this.
  4. The 39 guy
    The 39 guy
    It is good to see you are getting some projects done while healing Joel. Are you going to be able separate that piece of cowl from the mounting bracket without screwing up your paint job?
  5. joel
    joel
    I could see the rivits on my truck on the fire wall and dash; I ***umed that was it.
    Good Ol Henry also spot welded the dash end and arc welded the firewall end on the inside. I have a stub on the truck sticking out about 1 1/2 in from the firewall. On the dash end, I can plug weld.
    Thanks for following along Sam.
  6. zeph4057k
    zeph4057k
    wow sweet truck !!!!! I would love to have that in my garage !!!!!!!!!!!!!!
  7. joel
    joel
    Thanks, I’m trying to keep it driveable and fix/improve it at the same time.
  8. Really nice truck. I am happy to know you are having fun tinkering with it at the same time keeping it on the road.
    Bob
  9. joel
    joel
    IMG_0822.JPG A little work on this project, while organizing the garage. I've installed the brace the cowl vent operator bolts to and checking the adjustment of the linkage. When this is sorted out, I can patch the hole in the dash. Yaaayyyy.
    stub left from the P.O. surgery.
    I cut the brace to match the stub and prepped for welding.
    I thought I might use the tig across the bottom but I couldn't get my head in a place to see ( with the hood on). Getting the mig torch in wasn't much better, but I finally got it s***ched together.
    Back to cleaning the garage.
    The 39 guy likes this.
  10. Dan in Pasadena
    Dan in Pasadena
    I’m a Chevy guy through and through but I just LOVE the ‘40-‘41 Ford pickup.
    If I ever sell my no-longer-HAMB-friendly avatar ‘55 I will definitely be looking for one. And I would want to do what I started doing on my ‘55 (before I got carried away) and what you are doing now, “Work on it while keeping it driveable.”
    Yours is SUCH a great truck - huge congrats. Watching and really enjoying.
  11. joel
    joel
    I have a working cowl vent!
    rjones35 and Hamtown Al like this.
  12. joel
    joel
    I finished up the cowl vent with a screen and an adjustment. I’m getting my parts for the supplied air pump Wednesday so I tacked in a patch for the hole in the dash.
    [​IMG][​IMG]
  13. joel
    joel
    I have been wanting to install the column drop/ignition switch that I rebuilt a while back because I have left the turn signals on after parking the truck. I also needed to tighten up the steering box free play and after buying a repo 40 steering wheel I found the column had been modified to fit the wheel it came with. I did that today, almost.
    I cut the column where it was welded before and you might notice that the steering shaft is laying against the steering column tube. As a consequence of this, the steering box had to be in a bind. I pulled the tube to recut the end squarely.
    I recut the top half of the tube also to square it and added a 3/4 in. piece to make the column the correct length. It's clamped up and ready to weld.
    The new drop with the shaft nearly centered.
    IMG_0933.JPG Ready to weld
    All welded back together and clamped in place. A little bondo, grinding, sanding and some rattle can black and the turn signals will go off with the ignition switch.
    Jet96, 40FORDPU and PONTNAK123 like this.
  14. joel
    joel
    Mission accomplished. I took it for a test drive; steering is much better. I rotated the signal stat up so the indicator lights would be more line of sight. IMG_0936.JPG IMG_0937 (600x800).jpg
    Next is the door gl***. The window regulators are rebuilt; I'm just waiting on the door gl***.
    Jet96 likes this.
  15. TomT
    TomT
    Door gl*** on 40-41 pickups (my experience is with these two years) is a bit of a bear. Unless the bottoms of the doors are rotted out and you can come from underneath (not trying to be funny - that's how I did one of my doors by installing the whole window mechanism first, I then fixed the door bottom), they slide in through the door window opening. Fun fun fun - have a friend nearby for a couple extra hands - you'll need them!
  16. joel
    joel
    Thanks for the info. When I took the gl***/regulators out, the gl*** was busted on one side and the regulator was not connected on the other side. I’ll be flying blind.
  17. Those little round lights with the conical lenses are a '50s-'60s aftermarket item. J. C. Whitney, Economy Auto, and Western Auto used to carry them.
  18. TomT
    TomT
    The gl*** needs to be in its channel first, then slid into the vertical door channels inside the door with felts already installed. That will somewhat hold the gl*** in place along with one hand. The regulator goes through the door access hole and is either fully up or down. There's an article on the Drake website about doing a coupe door window. The coupe had a much bigger inside door opening vs the small truck opening and there's the rub of trying to get the regulator rollers in the channel while holding the window - this is where the extra hands come in and the fun and games start. Have the regulator screws ready.
    I hope someone else can jump in to clarify things but I am also hoping your experience will be much less frustrating than mine was .... If you need window gl*** to channel positioning (left and right), I think the one gl*** I have not yet installed in my stalled 40 pickup project has it installed and I can give you some measurements if needed ....
  19. joel
    joel
    Thanks; I may need some dimensions. If I get frustrated, I can always go in the next room and sand on the coupe to relax.;) BTW. The drivers door does need a new bottom, but I can't go there yet.
  20. joel
    joel
    A little update. The gl*** install went pretty much like TomT described. After I got the gl*** in the channel, I used 2 pieces of 1x2 and a C clamp across the gl*** to hold it up.
    I don’t have any pix of that. I was doing the gl*** as a fill in while priming on the coupe and the gl*** went so well that I was done before I knew it.
  21. the-rodster
    the-rodster
    The bed looks FANTASTIC!
    Did you use a kit?
    Whose?
    How much?
    Thanks,
    Rich
  22. joel
    joel
    I bought a bed kit from Midwest Early Ford in Ohio. It was a little less than $2000 I think and that included the bed wood, steel strips, bolts.
    Every thing you need to go from bare frame to done except paint.
  23. the-rodster
    the-rodster
    My quote from them was 1300 bucks, did you get bed sides also?
  24. joel
    joel
    Here is the link and I also bought the tail gate. So, to answer your question, I bought the bedsides. There is not a single original bed part on my truck. Go to https://midwestearlyford.com/shop/ and search fo part # 81C-830000.
    I met up with them at nsra nationals north in kalamazoo mi. so I saved shipping. I had the help of a good friend who was experienced at riveting and that was the most time consuming part of ***embly.
    BTW, I will have some hour in body working things like spot welds, but much preferable to fixing rust.
  25. The 39 guy
    The 39 guy
    Money well spent Joel! It looks great. I have had my eye on 41 flatbed bed for years locally. Although the flatbed is very well done I would want to convert it to a pickup. I had figured the costs at more than that so I am glad to hear it can be done for less than I thought. Too bad I have too many projects ahead of me to pursue this truck project.. The picture is of my car club in 2008. We used to try to gather for a group photo at some point during the Rod Run we put on the last week in June for 34 years.
  26. joel
    joel
    I thought so, Sam. The new bed makes it easier to put up with the holes in the cab floor.;) The instructions that come with the kit recommend ***embling the bed parts on a raised platform or saw horses, some place you can work around easily. The bed sub-frame is pre-***embled and welded and is a good start. Long story short; a person could ***emble, paint and install the floor before you ever get the truck. :) Just a thought.
  27. The 39 guy
    The 39 guy
    So easy.......but I better not unless I want to live /sleep in the shop;)
  28. joel
    joel
  29. rjones35
    rjones35
    Looking good!!
  30. joel
    joel
    Thanks. It's going to be slow, but today I sent some $$ to a fellow hamber for a piece of firewall, a throttle pedal, and a set of seat springs. The new seat frame is coming from LeBaron-Bonney.
    I'll find someone to build up the seat over the winter; the rest will get done after the coupe. All is well and the HAMB is great.
    Thor1 and chryslerfan55 like this.
