Hot Rods 57 Pontiac Drag Car Build
Discussion in 'The Hokey Ass Message Board' started by Todd553, Oct 21, 2017.
  1. RmK57
    RmK57
    Neat car! 558 hp at around 3600 lbs. should get you into deep 11's or high 10's with good suspension and careful tuning. I like it!
  2. bobbytnm
    bobbytnm
    Fantastic build!!!
    I really like what you're doing here
    Bobby
    Deuces and loudbang like this.
  3. Todd553
    Todd553
    Just a quick update. Motor and hydro are in the car. Working on the headers now. Still need to change out the valve covers. IMG_0228.JPG IMG_0229.JPG IMG_0238.JPG
  4. KoolKat-57
    KoolKat-57
    from Dublin, OH
    Looks awesome! The headers are probably a lot of work.
    Years ago I asked Jess Tyree if he ever did a set of headers for a '57 Pontiac, and if he had a pattern.
    He laughed and set he had done them and each were fitted to the car.
    He said there was not enough money to do another set at his age and just enjoy the car the way it was!
    Are you going to try to get to Bowling Green in June?
    KK
    kidcampbell71 and loudbang like this.
  5. porkshop
    porkshop
    from Clovis Ca
    Glad to see progress......
  6. Neat car x 2 here.
    Wondering if we're still using the old Hydro here. Modern trans and converter would be worth a a bunch of ET here, in my opinion.
  7. Todd553
    Todd553
    Hey KoolKat,
    You are right, the headers are PAINFUL. Thanks to my buddy John at JR's for all the work on them. I've never seen any headers for the 57. Unfortunately, I'm not going to Bowling Green but I should be ready for Meltdown.
    Thanks,
    Todd
  8. Todd553
    Todd553
    Marc,
    I Know I'd pick up some ET with a modern trans but I am using a rebuilt B&M 4 speed slant pan hydro. I think it will be fun and different.
    Thanks,
    Todd
  9. caseyajones
    caseyajones
    Wow. What a cool build!! I can't wait to see some footage of when you run it at the drag strip with that new motor. Impressive. Should be a blast!!
  10. jimdillon
    jimdillon
    Todd your build has been great. Can't wait to see it at the Meltdown. It may be easier to go the modern trans route but I believe it is pretty cool to go the direction you are going.
  11. Doctorterry
    Doctorterry
    It's refreshing to see a build like this. It gets us out of the rut of the typical hotrod builds. Not that there's anything wrong with model As and tri-five chevys, but this is just exciting!
  12. Super/Stock Poncho
    Super/Stock Poncho
    from Missouri
    Extremely KOOL Build!
    I Approve!
    57 Ponchos Rule!
  13. Mike VV
    Mike VV
    from SoCal
    Todd -
    Wow, that looks like a lot of work to get the header tube bends you want, nice work.
    Are you going to/did you do any sort of home made heat treating to try to "normalize" those tubes so they don't break from all the heat from the welding ? Seems like all that heat would crystallize the material and make it prone to cracking/breaking.
    Again, nice work.
    Mike
    Bowtie Coupe and loudbang like this.
  14. Todd553
    Todd553
    Had to make both front and rear cross members. Tried to use a stock 55 Pontiac cross member< per my B&M catalog but the motor and trans sat too low, not enough clearence for the headers. Had to raise the motor and thought it would be better to use the mounts on the side of the motor rather than the off the timing cover. 59 blocks have both. Also, bolted the hydro to the motor as well as all 30 bolts from the flywheel to the torus. Each bolt has to be sealed from the flywheel to the torus. IMG_0247.jpg IMG_0246.jpg IMG_0248.jpg
  15. loudbang
  16. Rocky
    Rocky
    Classified Editor
    I can't WAIT to see photos of going down the strip..
  17. Todd553
    Todd553
    Thanks Mike,
    I have not done any heat treating of the tubes. You make a good point. I've had other headers done this way and they've been OK over the years.
    Thanks,
    Todd
  18. 56sedandelivery
    56sedandelivery
    I'm STILL watching this build. Post up some video if you can when the time comes. I am Butch/56sedandelivery.
  19. Todd553
    Todd553
    Will do Butch, and thanks. Headers should be done this week. View attachment 3897072 IMG_0252.jpg IMG_0265 (1).jpg IMG_0263.jpg
  20. Todd553
    Todd553
    I decided to use Cal Trac bars. Unfortunately we had to make spring perches in order for them to work. Almost the exact same measurements a a 57 chevy but a very different perch design. Always something. IMG_0421.jpg IMG_0442.jpg
  21. Todd553
    Todd553
    Present from Jet-Hot. Headers are done!
  22. 1934coupe
    1934coupe
    Been following and it looks real good, keep up the excellent work and post some race times.
    Pat
    kidcampbell71, mad mikey and loudbang like this.
  23. bostonhemi
    bostonhemi
    love watching the progress
  24. Todd553
    Todd553
    Thank you guys I appreciate it.
    kidcampbell71, loudbang and Stogy like this.
  25. Todd553
    Todd553
    Changed out the valve covers and installed the headers. Right now I'm using the breathers from the 347 motor. IMG_0458.jpg IMG_0453.jpg IMG_0469.jpg IMG_0446.jpg IMG_0467.jpg
  26. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Impressive - Very Impressive.
  27. alwaysamopar
    alwaysamopar
    Thank God it's not a turboed LS motor! Very nice looking . Clean work man. That's definitely a car that'd make me walk back to the pits after watching it run.
    Sent from my SM-G900V using The H.A.M.B. mobile app
  28. 56sedandelivery
    56sedandelivery
    Call it the "******-Mobile"; that's what it does for me anyway. This car is absolutely one of the best builds ever! The car itself is so plain-Jane, just what I like. The running gear is not plain-Jane however. Headers turned out beautifully! I am Butch/56sedandelivery.
    Todd553, bchctybob, razoo lew and 5 others like this.
  29. mad mikey
    mad mikey
    Looks fantastic. The CalTracs should work really well. She should plant hard when you kick that beast engine into action. The headers are perfect. Love this car.:)
    kidcampbell71 likes this.
  30. Runnin shine
    Runnin shine
    I’d have a hard time not procrastinating on installing the rest of the front clip. Cause I would be drooling over the motors exposed beauty for days on end.
    Sad shame that I’ll most likely never see this subdued rocket ship in the flesh.
    Good luck and I hope you don’t rip too deep of ruts in any asphalt so that you drag the caltracs or header collectors. [emoji6]
    kidcampbell71, Stogy and Doctorterry like this.
