Projects Flat FED build
Discussion in 'Traditional Hot Rods' started by roseville carl, Jan 14, 2010.
  1. roseville carl
    roseville carl
    Na don't think Nitro is in it for me, Alky ok, besides what i don't use I can drink..............
  2. fenderless
    fenderless
    from Norway
    Yep Carl, it has gotten over here too ;) What could we do to get rid of it ?? ;)
    KBS
  3. roseville carl
    roseville carl
  4. roseville carl
    roseville carl
    Well another change......3/8 air vent
  5. roseville carl
    roseville carl
    well some days ya wake up and go wtf should I do today................. garage floor.jpg
    OahuEli, greaser, loudbang and 2 others like this.
  6. 64 DODGE 440
    64 DODGE 440
    from so cal
    Sold the race car?
  7. 51504bat
    51504bat
    You can come clean my shop anytime!
  8. roseville carl
    roseville carl
    Na its over at daughters house while we clean things up a bit...........as we are hopefully through with large projects, just the racecar left to futz with......
    64 DODGE 440, loudbang and greaser like this.
  9. roseville carl
    roseville carl
    Its a never ending cycle....... and da beat goes on
    loudbang and Gammz like this.
  10. 64 DODGE 440
    64 DODGE 440
    from so cal
    A lot going on there Carl. New injection?
  11. roseville carl
    roseville carl
    new linkage.............its a kluster ****..............
    OahuEli and loudbang like this.
  12. 64 DODGE 440
    64 DODGE 440
    from so cal
    It does appear to have many components going in several directions at once.:rolleyes:
  13. roseville carl
    roseville carl
    kinda like a rube goldberg arrangement sort of.............kinda like the hip bone connected to the thigh bone ect. ect. ect.....
    loudbang and 64 DODGE 440 like this.
  14. roseville carl
    roseville carl
    Well onething always leads to another...............exist tach wont work with mag so....
    then of course there is always the NHRA gettin into my pocket........
    belt recert time..........uggggg same belts 120 bucks later........not to mention what ya spend on the lap harness every 2 years.....................
    Oh also new fuel line to barrel valve.........
  15. 64 DODGE 440
    64 DODGE 440
    from so cal
    Hell Carl, just use some chain to hold the blower down.:rolleyes:
  16. roseville carl
    roseville carl
    not SFI approved Tom (they didn't pay off NHRA)
  17. roseville carl
    roseville carl
  18. Gammz
    Gammz
    from Lincoln Ne
  19. roseville carl
    roseville carl
    Thanks Gammz, but just an ol fart relivin his teenage years and enjoyin retirement..........
    Gammz and loudbang like this.
  20. roseville carl
    roseville carl
    Ug Monday morning Blues......
    And the culprit of all this ****............torque converter bolt................
  21. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Looking in the wrong place to begin with?
  22. roseville carl
    roseville carl
    na just doing regular maintenance and found it..................
  23. roseville carl
    roseville carl
  24. 64 DODGE 440
    64 DODGE 440
    from so cal
    Better to find it like that than having it come apart in the traps.
    OahuEli, greaser and loudbang like this.
  25. roseville carl
    roseville carl
    your right about that Tom, hope to have it fixed by next week, still a lot to do before Eagle!!!!!
  26. roseville carl
    roseville carl
    Well got a start on repairs and modifications to flex plate and converter nuts......... and da beat goes on an on an on an on
    20180824_190522[1].jpg 20180824_212603[1].jpg 20180824_212624[1].jpg 20180824_171212[1].jpg
  27. Hey Carl - how will you know that the faces of these nuts are all at the same depth and correctly centered as compared to the converter centerline? Just wondering how you managed to "true" everything? If it isn't true, can sure cause some issues . . .
  28. roseville carl
    roseville carl
    yea Dale that will require some precision but i think it is doable will post pics of it all later...............
  29. 51504bat
    51504bat
    When I saw the photos of the bolt failure I wondered what you were going to do to keep it from happening again. Now I know. Your abilities never cease to amaze me.
  30. roseville carl
    roseville carl
    Well got the nutz done now to put it all back together again, first had to make an adapter to mount flex plate to turntable, 20180825_193224[1].jpg 20180825_193340[1].jpg 20180825_195311[1].jpg
    Then center it all up.................
    Then after taking numerous measurements to locate all holes exactly viola...........
    After 8 hrs labor......
    Now on to bigger and better things I hope!!!!!!
    Tis da ****s when your an ol fart and cheap...........................
