Projects 5wKy33: another coupe build thread
Discussion in 'Traditional Hot Rods' started by ls1yj, Jan 15, 2017.
  1. 34Larry
    34Larry
    So 33 you make me wish I'd have taken more pictures during my build. I was always to anxious to get to the next step, or to engrossed figuring out why things weren't what I wanted, or re-engineering, to stop and run get the camera.
    Really nice work, makes me almost want to do it again. Almost, but the old body is giving out. Keep the pic's coming, brings back great memories to this old man.
    loudbang and ls1yj like this.
  2. ls1yj
    ls1yj
    from Kentucky
  3. ls1yj
    ls1yj
    from Kentucky
    Had a small misconbobulation on the stainless piece I made yesterday. I transposed last 2!numbers on sketch, and one hole and overall length are off quite a bit... so, some sectioning is in order
  4. ls1yj
    ls1yj
    from Kentucky
    Tim_with_a_T and loudbang like this.
  5. ls1yj
    ls1yj
    from Kentucky
    loudbang and Tim_with_a_T like this.
  6. ls1yj
    ls1yj
    from Kentucky
    brEad, loudbang, Shadow Creek and 2 others like this.
  7. loudbang
    The "dimples" in those plates look good.
    brEad and ls1yj like this.
  8. ls1yj
    ls1yj
    from Kentucky
    Thanks loudbang.
  9. ls1yj
    ls1yj
    from Kentucky
    Got another box plate tacked in... now on to fitting crossmembers
  10. ls1yj
    ls1yj
    from Kentucky
    cretin, brEad, loudbang and 3 others like this.
  11. Roothawg
    Roothawg
    Looking good.
    deathrowdave and ls1yj like this.
  12. ls1yj
    ls1yj
    from Kentucky
  13. ls1yj
    ls1yj
    from Kentucky
    Lined the x-member pieces up to fit the sheetmetal dimples where stock pieces were, and saw that fronts are a little long, and rears come up just a bit short... gonna need to do some t******* and tacking here and there
    loudbang, cretin and brEad like this.
  14. ls1yj
    ls1yj
    from Kentucky
    Pulled rails apart to fix some short flanges before I weld cross members in... added some pieces to front horns, to even them up
    brEad and loudbang like this.
  15. ls1yj
    ls1yj
    from Kentucky
    Got flange for steering box welded on, and smoothed out some
    brEad, loudbang and Shadow Creek like this.
  16. ls1yj
    ls1yj
    from Kentucky
    Dad jumped in and made some plates to mount the shocks... one step closer
  17. ls1yj
    ls1yj
    from Kentucky
    Shadow Creek, loudbang and brEad like this.
  18. ls1yj
    ls1yj
    from Kentucky
    Picked up a set of good side curtains from a fellow hamber (thanks Mark!)
    Someone had cut a hole in driver side for steering box... made a filler piece, and got ‘er welded and hammered in this morning
  19. ls1yj
    ls1yj
    from Kentucky
    Doing some cyphering.... trying to figure out where to put the solid brace under trans tail section... I’m estimating where motor position is, based off a spare 365, but I don’t have a fan mounted... so not really sure how close I can estimate without one in hand...
  20. ls1yj
    ls1yj
    from Kentucky
  21. ls1yj
    ls1yj
    from Kentucky
    Starting to take the shape I want... just gotta trim a little, and finish weld
    brEad, Roothawg and loudbang like this.
  22. Roothawg
    Roothawg
    That spring will never work like that.... :)
    loudbang, ls1yj and brEad like this.
  23. andyapplegate
    andyapplegate
    i like this car! Good luck
  24. ls1yj
    ls1yj
    from Kentucky
    Only in reverse :)
    Roothawg, loudbang and brEad like this.
  25. ls1yj
    ls1yj
    from Kentucky
    Thanks Andyapplegate... one piece at a time
  26. ls1yj
    ls1yj
    from Kentucky
    @Roothawg, I’m contemplating adding a piece inside the rear cross member, to pull the T spring against... there’s several inches between the arch for A, and the smaller radius of the T
  27. Roothawg
    Roothawg
    Interesting.
  28. ls1yj
    ls1yj
    from Kentucky
    Gonna take a small break from fab today and cypher out getting this Ducoil to fit the cad motor
  29. ls1yj
    ls1yj
    from Kentucky
    Couldn’t resist
    Ground and welded some on center support... almost got it
  30. ls1yj
    ls1yj
    from Kentucky
    Made template to clamp in windshield pocket, and starting lining up the A pillar areas
