Hot Rods THE INDUCTION THREAD
Discussion in 'The Hokey Ass Message Board' started by mad mikey, Dec 9, 2016.
  1. loudbang
    Note the twin injectors
    loner2, Stebo27, loner1 and 10 others like this.
  2. RichFox
    RichFox
    Pretty interesting looking injection. Looks like EFI throttle bodies much modified to become stack injection on the Chrysler.
  3. j hansen
    j hansen
    If I remember correctly (2006) he took the EFI throttles from one of the smallest Mazdas,so he had to find 8 of them!
  4. loudbang
  5. loudbang
  6. LAROKE
    LAROKE
    Managed to find a smallblock Chevy Latham axial flow supercharger setup to adapt to my '54 Buick 322 nailhead.
  7. Deuces
    Deuces
    Very Kool!!!!...... :cool:
  8. loudbang
  9. loudbang
    Early proponent of TURBOS
    Mallicoat
    loner2, Stebo27, loner1 and 9 others like this.
  10. topher5150
    topher5150
    anyone know anything about this setup? From what i see it looks like a injected SBC, but i'm not sure about the rest of it....looks like it would be pretty cool.
  11. Bandit Billy
    Bandit Billy
    Note to self, before I plug in engine bay accent lighting, make sure air cleaners are installed correctly.
    loner2, Stebo27, loner1 and 8 others like this.
  12. Fordors
    Fordors
    The Mallicoat Brothers ran a draw through system, there are two AFB’s under that sheet metal shield in front of the engine. The carbs are mounted to a plenum feeding the turbos which in turn are ducted to the Rochester injection plenum/manifold. They only used the Corvette manifold and f.i. plenum to get the air/fuel mix into the engine, the Rochester mechanical injection was not used.
    There was a time the NHRA rules required a shield like that over carbs, by the mid ‘60’s when they ran this car it was no longer in the rules but I wonder if they found they needed the shield. Could there have been reversion or back firing when the throttle was backed off?
  13. topher5150
    topher5150
  14. loudbang
  15. Deuces
    Deuces
    Sweeeeeeeeeeet!...... :cool:
  16. loudbang
  17. Flatred53
    Flatred53
    from Sweden
  18. Flatred53
    Flatred53
    from Sweden
  19. loudbang
    some of these get HUGE and would make a great computer backround
    For A Time, The Cammer Popped Up In Many Drag Racing Cl***es. One Of The Most Famous And Consistent G***ers Was “Ohio” George Montgomery’s Torrid 1933 Willys Coupe, Which Evolved Into This Cammer Version With Ford SOHC power
    posted by me here:https://www.jalopyjournal.com/forum/threads/ford-427-sohc-engines.761572/page-13
    Mercury SOHC
  20. 1947knuck
    1947knuck
  21. 1947knuck
    1947knuck
  22. 1947knuck
    1947knuck
  23. 1947knuck
    1947knuck
  24. Deuces
    Deuces
    Cool.....
    loudbang and 1947knuck like this.
  25. Fordors
    Fordors
    AE1ED63F-8E35-46CD-A2F9-8C0809D0DD98.jpeg That’s Ray Brock, he was a tech editor at Hot Rod, he’s checking an early pre-production cammer in a ‘64 Galaxie. What makes the engine pre-production are the heads with the low positioned spark plugs. Also, just peaking out from the air cleaner you can see a Holley with the LeMans style fuel bowls.
  26. Deuces
    Deuces
    I think Holley started making those fuel bowls again.... Along with the floats and hardware...
    Hope I'm not wrong....
    chevy57dude and loudbang like this.
  27. loudbang
  28. Deuces
    Deuces
    Your on roll this morning L.B. ;):cool:
  29. chevy57dude
    chevy57dude
    Deuces - Carl's Ford parts lists them at $180 each.
  30. Deuces
    Deuces
    Ouch!...... :confused:
    Bowtie Coupe, enloe and loudbang like this.
