Projects 26 T Roadster Pick Up build Thread
Discussion in 'The Hokey Ass Message Board' started by Blue One, Mar 27, 2010.
  1. Blue One
    Blue One
    from Alberta
    I forgot I’m gonna put the battery in it’s mount and run the battery cable up the frame to the starter first :D
    loudbang and Crazybillybob like this.
  2. F-ONE
    F-ONE
    from Alabama
    That's the cats *** right there, good job!
    This helps me a lot on my F1. Years of having make do stuff.....now is the time to do it right. Thanks.
    brad2v, loudbang and Blue One like this.
  3. Blue One
    Blue One
    from Alberta
    Brake lines are wrapped up to the rear brakes.
    Not having any brake lines mounted on the quick change itself worked out well and looks clean.
    Fluid and bleeding soon.
    AA95319E-5978-4284-97AA-37B07584CDCC.jpeg B6CE68F5-F487-4291-95C9-CF72A1FD316D.jpeg 0C360584-B1B9-4766-8328-16A59F67C991.jpeg
    ccain, DaPeach, tfeverfred and 6 others like this.
  4. Dick Stevens
    Dick Stevens
    That's what good planning gets you, clean appearance on completion!
  5. brEad
    brEad
    Simply beautiful. Clean, not over done, but quality all the way. Very nice!
    Blue One and loudbang like this.
  6. Tim
    Tim
    from KCMO
    Anything new?
  7. Blue One
    Blue One
    from Alberta
    Not lately taking care of other more important things right now.
    Still planning to complete this thing this summer.
    RICH B, brad2v, 26 T Ford RPU and 2 others like this.
  8. Blue One
    Blue One
    from Alberta
    Well back to it. I spent the day making battery cables and mounting them.
    That involved drilling two 5/8” holes into the frame and welding in threaded bungs for the grounds one at the rear and one up front.
    Of course then the frame paint had to be touched up :)
    While the paint was drying I put a set of gears in the quick change and added the gear oil.
    I also installed the rear coil overs.
    Then came brake fluid and bleeding the brakes.
    Leaks?
    Only 2 on the pipe thread ends of the 10 lb residual pressure valves that I looked at and wondered if they would leak.
    I should have put some pipe thread sealant on them when I thought about it :oops:
    All of my ni cop flares done with my eastwood flaring tool are perfect, leak free.
    Moving forward :cool: and now I’ll be able to stop :D
    Budget36, brad2v, Tim and 9 others like this.
  9. tfeverfred
    tfeverfred
    Thanks for the update.
    26 T Ford RPU and Blue One like this.
  10. 26 T Ford RPU
    26 T Ford RPU
    Doesn't some progress make ya feel good.:cool::D JW
  11. Blue One
    Blue One
    from Alberta
    Had to crimp the lugs on the battery cable and then seal the lug ends with glue lined shrink tubing.
    The cable is all mounted using the same made for you clamps I used on the brake and fuel lines.
    I used a little Hot rod heat sleeve heat insulation on the cable where it p***es over the exhaust.
    So the full system including the ground for the engine is 1/0 battery cable.
    I’m still debating removing the starter and painting it black.
    594391A2-0EB4-4922-B480-D80EAE7C355E.jpeg ED8658F9-E270-449E-90CC-541F8CFA701F.jpeg D7C73727-489A-4F13-ADB5-6E1EDD5E3725.jpeg CD3ED94C-6051-4DCB-AAF5-4140FCAAE72D.jpeg A266561F-6F1C-4950-B7E3-B6452F15CBDC.jpeg A7935389-F655-45B5-A4A1-1DDFE04C7AA0.jpeg 315B3336-C448-4AB9-90F0-4BF94C29A2E9.jpeg 8458789B-9B41-4E8B-AD37-463E21993E30.jpeg 07D1C7C1-9840-490F-B05F-2E14159B3337.jpeg
  12. atch
    atch
    That sounds like a very good plan.
    Blue One, 26 T Ford RPU and loudbang like this.
  13. loudbang
    Man this build of yours is SHOW QUALITY. :) What a beauty.
    I agree darken the starter. But try it first in case you have to return it. :rolleyes:
    Tim, Blue One and 26 T Ford RPU like this.
  14. 26 T Ford RPU
    26 T Ford RPU
    X3 on the starter. JW
  15. Crazybillybob
    Crazybillybob
    from Ohio
    Paint that starter!
  16. Blue One
    Blue One
    from Alberta
    The starter is perfect, it’s been tested and works flawlessly
    :D Okay guys I’m painting the starter :D
    Stogy, tfeverfred, loudbang and 2 others like this.
  17. Blue One
    Blue One
    from Alberta
    Step one painstakingly mask off what you don’t want paint on.
    Step 2 self etching primer for the aluminum bits......:D
    Stogy, tfeverfred, Tim and 2 others like this.
  18. Blue One
    Blue One
    from Alberta
    And then there was this :cool::D
    biggeorge, Stogy, 01mikep and 10 others like this.
  19. brEad
    brEad
    Much better!
    Blue One, loudbang and OFT like this.
  20. Dick Stevens
    Dick Stevens
    Good choice to paint it!
  21. atch
    atch
    Good choice.
  22. I agree looms better painted, but I probably will go body color on mine
    Sent from my SAMSUNG-SM-J320AZ using Tapatalk
  23. 26 T Ford RPU
    26 T Ford RPU
    Gone is the sore thumb. :cool:;) JW
    brad2v, Blue One and loudbang like this.
  24. bobbytnm
    bobbytnm
    Oh yea, the starter is much better in black
  25. Blue One
    Blue One
    from Alberta
    I wanted to mount my intake and I also wanted to block off the center exhaust ports to the intake so that it won’t burn the powder coating on the manifold.
    I took the gaskets and gently pried out the sheet metal insert around the center ports
    Then I cut a couple of small squares of 1/16” stainless and carefully Tig welded (20 amps)
    them in at the 4 corners.
    Placing them back into the gaskets and tapping the lip back down did the trick. :cool:
    Blocked off and my intake will stay pretty :cool: :D
    A49CD980-7721-4FDA-9B6F-302D15182BDD.jpeg C25662F8-A45E-4A10-9918-8D156E233888.jpeg 89A5533E-628C-4685-A4F0-AFEF34D3C1A3.jpeg 1A72194A-5D66-4CD4-997C-4994599E3748.jpeg
  26. K13
    K13
    Looks really good Larry! I got the pleasure of seeing Larry's build in person yesterday as Larry did some aluminum welding for me. It looks even better in person.
    Sent from my SM-G950W using The H.A.M.B. mobile app
    brEad, Stogy, brad2v and 2 others like this.
  27. Blue One
    Blue One
    from Alberta
    Thanks Ian.
    Stogy and loudbang like this.
  28. Blue One
    Blue One
    from Alberta
    I spent today wandering around one of our best self serve wrecking yards a short way east of the city and reminded myself of why I like the place so much.
    I’m plumbing my PCV and transmission vacuum lines and I want to keep it clean and neat,
    Searching through all the different vehicles I came up with a wide variety of pre formed rubber brake booster hoses and vacuum hoses some of them pre formed with 90 degree bends and other creative angles and shapes.
    I came home with a bag full of all different sizes :cool:
    Along with that a bag full of those spring type clamps in ***orted sizes.
    A fun day :cool:
    brEad, tfeverfred, loudbang and 4 others like this.
  29. Blue One
    Blue One
    from Alberta
    I came up with a technique to make custom vacuum hoses in 1/2” and 3/8” for both ends of my PCV system.
    I’m using an inline PCV valve that is originally for a 60s Ford truck with a 292 YBlock.
    Old stock Deutsch 131.
    The making of hoses involved the formed hoses I gathered during my wrecking yard day and a little modification.
    First you cut the hoses and arrange the bends to suit where you want to go with the hose.
    Then using some Loc***e 404 Industrial super glue you glue your hose together.
    After that you slide the hose into a length of dual wall (glue lined) heat shrink tubing, I used 1”.
    You shrink the tubing and presto you have a custom hose.
    Because my Edelbrock intake sits over top of the Mummert valley pan’s baffled PCV outlet I also had to cut down and modify a stock Yblock
    PCV valley pan outlet to fit.
    Turned out nice :cool:
    E9C8EC9A-B9F6-4AA7-BD3A-1894EC746144.jpeg ECAFD06C-AE7F-49F5-874D-A4CF7BE36781.jpeg 867364E4-3F0D-47F5-BEFA-1FDF38592233.jpeg
    brad2v, AndersF, loudbang and 5 others like this.
  30. Blue One
    Blue One
    from Alberta
    And then the beauty shot ;) :D
    32Dan, tfeverfred, brad2v and 6 others like this.
