Technical Auto Electrical Houston
Discussion in 'The Hokey Ass Message Board' started by MUNCIE, Jun 23, 2018.
  1. MUNCIE
    MUNCIE
    from Houston
    Can anyone recommend a place to take my 64 C10 too for a wiring issue here in Houston? Tired of chasing an issue and need help.
    Thanks,
    Mark
  2. brady1929
    brady1929
    Have you tried discussing your problem here? Lots of smart people here.
  3. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Lots of not so smart ones, too. LMAO
    Engine man likes this.
  4. MUNCIE
    MUNCIE
    from Houston
    I agree and agree. No I have done enough troubleshooting on my own and asking around, Better to just go to a someone that specializes in the field. Just need it fixed and done right. Seems like finding a good Auto electrician is not so easy these days. Still looking if anyone might have a person or shop in mind.
    Thanks,
    Mark
  5. HighSpeed LowDrag
    HighSpeed LowDrag
    from Houston
    Where you at in houston? Problem?
  6. MUNCIE
    MUNCIE
    from Houston
    Central Houston off of I10. In a nut shell front directional signal lights work as they should but back do not. Both blink when activating turn signals.
    Added extra grounds, cleaned existing ones and even ran a ground wire from neg battery post all the way to the rear and tied it into the frame. Taillight housings also have been grounded. Also not sure but I think electrical system might be drawing amps when all is off. Something might be crossed somewhere or maybe grounding out?
    64 C10 LWB.
    Thanks,
    Mark
    Woogeroo likes this.
  7. treb11
    treb11
    United Speedometer and Electric located at 290 & Bingle. Hot rod friendly.
    Sent from my SM-G950U using The H.A.M.B. mobile app
    Woogeroo and MUNCIE like this.
  8. MUNCIE
    MUNCIE
    from Houston
    Thank you sir.
  9. HighSpeed LowDrag
    HighSpeed LowDrag
    from Houston
    Cl***ic cars of houston. Belaire. Talk to jeff.
  10. Engine man
    Engine man
    from Wisconsin
    I think you made the right choice. If you aren't comfortable doing it. Find someone good at it.
