9.375 ford rear question
Discussion in 'The Hokey Ass Message Board' started by thintin, May 10, 2006.
  1. thintin
    thintin
    i have a 9.375 ford rear .......the axle flanges are bigger in diameter than my other 9 inch ford stuff....does anyone know what over the counter disc brake rotors might work with this deal......i hear maybe mid 70's lincoln continental.......input appreciated......thanks
  2. Bugman
    Bugman
    Maybe check Lincoln Versailes(sp?) I believe some of them came with disks stock, along with the 9 3/8". Also, if you can find the right length, standard 9" axles are a direct swap.
  3. kenagain
    kenagain
    from so cal
    I know 76 lincoln continentals came with those vesailles had 9 inch ones the outside measurments seemed to big for most early applications also gears were 2.50's or so very tall parts are expensive did cut down one side and run 2 of the short axles but gearing killed it limited gear ranges for it
    Ken
  4. tjm73
    tjm73
    9 3/8" Fords came in 70-71ish era Thunderbirds and lincolns of the same chasiss family. They also came in a few trucks.
    There are about 4 ratios available and they are not very easy to find. 2.50 (very common), 3.00 (also very common), 3.50 (very rare) and 4.10 (extremely rare from I've gathered). My brother has a traction-lok (super rare) 4.10 9 3/8" center housing. Internal parts are the same as a 9" (just all the bigger HD 9" stuff) and they are 31 spline.
  5. Brad54
    Brad54
    from Atl Ga
    If it's a complete rear end, from drum-to-drum, and you like the gear ratio, run it as-is.
    Otherwise, it's a white elephant. I paid $100 to a racer back when I was 17 (which was HUGE money then!) for one of those centersections, before I knew enough about them. It took me a while, but I finally ended up eating it and just hauled it to the dump. When you find parts (gears, limited slip) they're really expensive.
    Reider Racing is a good source of info on these, and may have some stuff for them.
    The Versailles rear is a 9-inch, and is pretty narrow: fits in a '67-'69 Camaro, '55-'567 Chevy, etc. It's about 52 or 53 inches flange-to-flange if I remember correctly. I have one under a '56.
    -Brad
  6. jetmek
    jetmek
    i pulled one out from under a 65-66ish galaxie500 a few years back. imagine my suprise when it wouldnt fit the 73 towncar housing i was using. some serious headscratchin was happenin.
  7. Bugman
    Bugman
    I think I have a Trac-Loc for one laying around, I'll have to double check.
  8. 286merc
    286merc
    from Pelham, NH
    Used across the full FOMOCO line in the 70's when having a 460 in a full size boat, plus some F150's. I dont know of any in 65 Galaxies that came stock. Most common ratio is 2.75 and performance choices are next to nil.
  9. willowbilly3
    willowbilly3
    from Sturgis
    What differentiates it from a 9 inch?
  10. Bugman
    Bugman
    The ring gear is 9 3/8", not 9" The carrier is slightly larger physically. The housing and axles are interchangable with standard 9" stuff. You can put a 9" in a 9 3/8" housing just fine, but you eill need to grind a 9" housing for ring gear clearance to put a 9 3/8" in a 9" housing.
