Hot Rods Save of the day!!(single seater)
Discussion in 'The Hokey Ass Message Board' started by rusty rocket, Mar 14, 2017.
  1. rusty rocket
    rusty rocket
    Thanks man, I dont know about the workmanship (photos hide a lot of ****).
    Its has been fun, not many rules to follow.
  2. alchemy
    alchemy
    That pipe is going to take a lot of sanding before chrome. You are a glutton for punishment.
    brEad and Doctorterry like this.
  3. rusty rocket
    rusty rocket
    Started working on a front motor mount , I had a chunk of angle iron laying in the metal pile so I did some cutting and grinding. This is what I came up with. IMG_2943.JPG IMG_2944.JPG IMG_2945.JPG
  4. Looks exactly like the stock one! (-;
    Very inspirational project, been following since the git go and still read every post.
  5. plym_46
    plym_46
    from central NY
    Are you going to use the floating power pieces???
  6. rusty rocket
    rusty rocket
    No I cant use that because I have to run the 57-9 car water pump (to lower the fan)and it takes up the same space as the motor mount. I have rubber biscuits that will be used. They are the same ones that I am using on the bell housing mount.
  7. plym_46
    plym_46
    from central NY
    Did your water pump pieces arrive and solve the problem?
  8. rusty rocket
    rusty rocket
    Yes,I got a pump, lowered housing, generator mount front motor plate, timing cover and water pump pulley. Still need to get crank pulley but have found one from a guy in Canada. Where does a guy get gaskets and crank timing cover seal? Bernbaums?
  9. KenC
    KenC
    Last time I looked, Rock Auto had most everything for the flathead Mopars.
    Greenblade, chryslerfan55 and Stogy like this.
  10. rusty rocket
    rusty rocket
    Damn Dude thanks for the info, just looked at rock auto and they have the gaskets I need.
  11. Nothing cookie cutter about this build. Your attention to detail is evident everywhere , this is a great build to follow!
    Stogy and sodakmini like this.
  12. atch
    atch
    Anyone else besides me get "Bernbaums"?
  13. rusty rocket
    rusty rocket
    Bernbaum is the guy for Lhead 6 mopar stuff. Sort of like Schniders is for Model T-A
  14. BigO
    BigO
    Nice work Stogy, looks good.
  15. BigO
    BigO
  16. BigO
    BigO
    Use the lense that says STOP, just a thought.
  17. rusty rocket
    rusty rocket
    I have those stop lens on
    on my T. Will be doing something different on this one.
  18. rusty rocket
    rusty rocket
    Have the motor sitting in the frame without the aid of wood blocks under the oil pan.:) IMG_2949.JPG IMG_2950.JPG IMG_2951.JPG
  19. plym_46
    plym_46
    from central NY
    What is that extra bit on the fuel pump??.seen them with aux vacuum pump for wipers but that's about 3x bigger. Brake booster???
  20. rusty rocket
    rusty rocket
    I have no idea but it must not work because it was unhooked and had an electric pump plumbed in when it was still in the cube van.
  21. plym_46
    plym_46
    from central NY
    If you decide to go back to mechanical, avoid Airtex if you can. Their fulcrum pins like to walk out. You are better off rebuilding that one then getting theirs. Now and Then has kits for most Mopar stuff.
  22. rusty rocket
    rusty rocket
    Thanks for the info. I will be running a mechanical, probably not this ugly thing though.
  23. rusty rocket
    rusty rocket
    Have the pinion angle set tonight and my nerf/wishbones tacked together. IMG_2957.JPG IMG_2958.JPG IMG_2959.JPG
  24. rusty rocket
    rusty rocket
    Messed around with the exhaust pipe a bit more. IMG_2961.JPG IMG_2962.JPG IMG_2964.JPG IMG_2965.JPG
    brEad, brad2v, chryslerfan55 and 7 others like this.
  25. Champscotty58
    Champscotty58
    I love this thing!
  26. rusty rocket
    rusty rocket
    Thanks, Its been a fun little project.
    Doctorterry and chryslerfan55 like this.
  27. plym_46
    plym_46
    from central NY
    That is calling out for a balogna cut at exit I think!
  28. rusty rocket
    rusty rocket
    I'll have to think about that one. I'm wondering how the ole girl is going to sound thru a 3" straight pipe.:)
  29. curbspeed
    curbspeed
    I think you should name it "Stink Bug"
  30. plym_46
    plym_46
    from central NY
    What are you doing for the intake side?
