Hot Rods 40 Deluxe Grill Chin Pan
Discussion in 'The Hokey Ass Message Board' started by Strodder, Jun 29, 2018.
  1. Strodder
    Strodder
    Does anybody make or has made a skid pan to protect grill chin pan? I know almost every 40 Ford Deluxe I see has been dented in from hitting bumps or dips. 0627181206.jpg
    LOU WELLS likes this.
  2. 40LUV
    40LUV
    from Mid Jersey
    Not that it would help now, but I think Magoo's used to make them. It looked like a nerf bar and bolted to the front buggy spring U bolts.
    Strodder and lothiandon1940 like this.
  3. olscrounger
    olscrounger
    Always an issue with Deluxe 40's for me--I keep a couple of spares painted to match and change as needed. Have two done now for my 40.
  4. typo41
    typo41
    I remember awhile back, someone made a chin that had a wheel in a cutout that would take a hit and keep the rest of the grill from taking the hit
  5. Strodder
    Strodder
    It would be nice if someone would make something that works and can be bought. I'm thinking of making something. I just lowered the rear and I'll see if that helps a little.
  6. flamed40
    flamed40
    from NE Ohio
    I used to use wire ties to hold the chin on so when I hit something it would bend the rest of the grille! Finally raised it up some!
    RICH B and Strodder like this.
  7. chargin03
    chargin03
    My 40 standard is full of dents fixed it once and gave up on it after that .Can't see it unless I get under the car.
    OL 55 and LOU WELLS like this.
  8. Kan Kustom
    Kan Kustom
    I never really knew what the old saying "sometimes you have to take a few on the chin "meant until I got my 40's .
  9. LOU WELLS
    LOU WELLS
    from IDAHO
    Consider It To Be A Asphalt Feeler....Now You Know Where The Asphalt Is...I Just Leave Them With A Dent Or Two For The Experts To Judge... 26229578_1959031704421101_2495523594235657162_n.jpg
  10. Nitroholic
    Nitroholic
    from SoCal
    It seems like I remember years ago someone was making one out of a paintible flexible material similar to modern day bumpers. I've searched and come up with nothing.
  11. Strodder
    Strodder
    I decided to make my own from 3/8" metal sheet. First drilled the holes where front spring "U" bolts are. I slotted them so it will slide in. Then I drilled another hole for a 3rd bolt to screw into the front cross brace above the frame. The metal took a lot to bend so I made cuts half way threw and bent to shape. When I had the fit, I welded them up. Then ground down the lip on the frame so the skid pan will fit flush. Then ground the "U" bolt mounts to fit closer to tighten with the skid plate. Next I drilled and mounted 2 anchor bolts to connect to the chin. I think it will work. Got nothing to loose. I straightened the bent chin pan and reinstalled it. Just have a little t******* and paint it before I install it permanently.
    What do you guys think?
    0701181505a.jpg 0702181201.jpg 0702181201a.jpg 0702181202.jpg 0702181202a.jpg
  12. Strodder
    Strodder
    I heard of that too. Let us know if you find it. Good luck.
  13. RICH B
    RICH B
    Maybe someone could cast or 3D print some out of urethane.
  14. Strodder
    Strodder
    Here it is all done. Straightened and Repaired and painted the Chin Pan, and skid plate. Then installed it all. I hope it works, 0703181313.jpg 0703181313a.jpg 0703181622-1.jpg 0705180934.jpg 0705180935.jpg 0705180935a.jpg 0705180935b.jpg 0705180953.jpg
  15. Jethro
    Jethro
    I like it , but here's a thought. That front edge would catch on say a parking curb and rattle your teeth. What if you followed the grill centre bar with a piece of 3/4 cold rolled round bar and carried it under and weld it to your plate. It would help to ride up when you nudge something rather than stop hard. Looks bomb proof though , even if you hit something you won't break that!
    da34guy likes this.
  16. Baumi
    Baumi
    Good to know! I just bought a 40, thanks for the heads up!
  17. flamedabone
    flamedabone
    I'm not real worried about mine, it think it will be fine....
    Or maybe not....
    -Abone.
  18. Baumi
    Baumi
  20. The 39 guy
    The 39 guy
    Okay, now you have a strong plate . How about installing a small steel wheel that sticks through the plate just a 1/4 inch or so that will allow the plate to roll over that speed bump? I saw one installed on a Forty in a HAMB post a few years ago but I cannot find the post.
  21. verde742
    verde742
    Chip Foose, his Dad had a rolling wheel, in the chin, of his Forty
  22. Strodder
    Strodder
    You can't really see it much, but I ground the front of it at a little angle. I guess a little more wouldn't hurt.
  23. Strodder
    Strodder
    I thought of that too, but I think I would have to brace it a little more. Like up to the bumper brackets.
  24. Strodder
    Strodder
    I met Chips dad Sam a long time ago when I worked for Snap-On. I went to his house in Santa Ynez. He's in Arizona now. I wish I could talk to him now.
  25. The 39 guy
    The 39 guy
    I agree that the plate would need additional bracing.
  26. 19Fordy
    19Fordy
    That skid plate might work but, I fear it will just transfer the impact to the bottom
    of the radiator and the louvered grille side panels. Hope I am wrong.
    I have 4 1/2 in. clearance.
  27. OL 55
    OL 55
    I changed mine out a few times in the past, then I got tired of that and said "screw it"! So I left it as a sacrificial piece taking the hit for the team. It's getting pretty ugly under there!! :eek:
    Cincinnati Slim likes this.
  28. Uncle Bob
    Uncle Bob
    from Salado, Tx
    I'm with 19fordy, hoping we're wrong, but looking at the path of energy from the impact and it's still going right to the chin piece (and now the bottom of the radiator too)...……...plus you now have 3/8" less clearance (unless something else has changed). It will be interesting to see how it works in the real rather than theoretical world. Hope you're going to be happy with it.
