Art & Inspiration Just Louvers////////
Discussion in 'The Hokey Ass Message Board' started by Stogy, Aug 1, 2016.
  1. loudbang
  2. curbspeed
    curbspeed
    Oh, I'm hoping this wasn't a mistake. I put red plexi in my roof insert to keep any rain I might encounter off my head. Drip tubes will drop into rear window drip tray and out the floor tube. Yes, those are valve stems in it. It will be look like an aquarium when has water in it. Dirt will be a problem too. I guess I'll just have to drive fast. IMG_0904.JPG
    1947knuck, gonmad, loudbang and 6 others like this.
  3. hotrodman303
    hotrodman303
  4. Stogy
    Stogy
    Its a bolt in so removal to separate is possible...time consuming and undesirable yes but if you have too you could...the valve stems are the drains correct?
    Your colors for this project are fantastic.
    Plexi is a great material for this discussed issue...period correct and visually appealing. Oh...and nice Louvers...all of them...;)
    Lastly Curbspeed how are those studs attached to the insert...they are not visible from outside.
  5. curbspeed
    curbspeed
    I welded a framework of 1/2 strap around the perimeter and drilled and tapped studs into it. Then I think I welded the back side of the studs. Can't remember. I removed the little black tabs shown in the picture as they did interfere with fit. Made the insert stick up too much. It's still not as flush as I would like but it's ok.
    loudbang and Stogy like this.
  6. hotrodman303
    hotrodman303
  7. Stogy
    Stogy
    1947knuck, putz, 509garyd and 5 others like this.
  8. Stogy
    Stogy
  9. Stogy
    Stogy
  10. loudbang
  11. loudbang
  12. loudbang
  13. loudbang
  14. loudbang
  15. loudbang
  16. loudbang
  17. loudbang
  18. Dean Lowe
    Dean Lowe
    Like to see him get out of that one without burning the **** out of his legs!!
    Speedwrench, Stogy and loudbang like this.
  19. loudbang
  20. Shadow Creek
    Shadow Creek
    1947knuck, Dusty-NZ, 509garyd and 2 others like this.
  21. Shadow Creek
    Shadow Creek
  22. hotrodman303
    hotrodman303
  23. hotrodman303
    hotrodman303
  24. hotrodman303
    hotrodman303
  25. ct1932ford
    ct1932ford
  26. ct1932ford
    ct1932ford
  27. hotrodman303
    hotrodman303
    1947knuck, tb33anda3rd, Stogy and 3 others like this.
  28. loudbang
  29. Stogy
    Stogy
    Credit to Photographer, Owner
  30. Stogy
    Stogy
    Checkered Flag Louvers in a Beautiful
    Hotrod of an Unusual Mix
