Technical Only starts when letting off ignition
Discussion in 'The Hokey Ass Message Board' started by jedy, Jun 23, 2018.
  1. You gotta have that starter "I" terminal wired to the coil. It's a must have item as important as can be.
    if it's not there, 99.5% chance the issue goes away after installing it.
    rfraze, jedy and prewarcars4me like this.
  2. Schwanke Engines
    Schwanke Engines
    The IGN. Wire is on wrong position on IGN switch.seen this a bunch of times.
    Sent from my Moto Z (2) using The H.A.M.B. mobile app
    swade41, clem, rfraze and 1 other person like this.
  3. jedy
    jedy
    As it turns out, getting to the solenoid was harder than I had figured. I don't have jacks or friends with jacks, so I waited until I had a second pair of hands around.
    It just so happened that Dad was visiting this weekend. We spent some quality time in the garage. There was a header right in the way, we ended up McGuyver'ing an extension for my socket wrench. After much effort and many words I wouldn't use in church, we finally got that ****er on there.
    Just like that... problem solved. No more starting issues.
    Today was a good day and I have this message board to thank for it.
    I'm grateful for all the responses. I especially want to thank prewarcars4me, much appreciated brother – If we ever cross paths, I'm buying you a few rounds.
  4. sunbeam
    sunbeam
    Jumper the resistor and see if it starts if it does add the wire if not check the switch. But I would still add the wire.
    jedy likes this.
  5. Engine man
    Engine man
    from Wisconsin
    Thanks for reporting what cured it.
    swade41, jedy, clem and 1 other person like this.
  6. rfraze
    rfraze
    Check your work by testing if the input wire to resistor (or coil+) is HOT with key in ACC position. Should not be. If it is, find the correct IGN pole on switch (gets HOT w/key on and stays HOT during cranking) to connect that wire to.
    jedy likes this.
  7. xracer40
    xracer40
    At some point I would remove that choke wire from your ign. wire and run it to a 12 volt source that is fused. The way it is now if your electric choke was to go bad and short out it would also ground out your ignition
    jedy and sevenhills1952 like this.
  8. sevenhills1952
    sevenhills1952
    I second that!
    Sent from my SM-S320VL using Tapatalk
    jedy likes this.
  9. sevenhills1952
    sevenhills1952
    Forgot to add...12 volts when key is on power.
    jedy likes this.
  10. rfraze
    rfraze
    Just checking to see if you did this test? result?
    jedy likes this.
  11. jedy
    jedy
    It's always important to check the work. Wouldn't want any issues.
    Took off the wire recently added wire from the coil and hooked it up to a multimeter. No volts with the key in the ACC position... 8volts (+/-) only when the engine is cranking.
    Thank you!
  12. jedy
    jedy
    Grounding out the ignition sounds bad. I'll look for another 12 volt source.
    Should I be looking for a 12v source that is always hot, or only when the engine cranks?
    Also, if there aren't any easy pickin's and I need to add a fuse, any suggestions on what volt that fuse should be?
    Thanks!
  13. sunbeam
    sunbeam
    Hot with key on
    jedy and rfraze like this.
  14. sevenhills1952
    sevenhills1952
    It's been discussed before but (***uming it's standard 12v negative ground) you want +12v to coil + when key is on and cranking only.
    So 12v from ign. switch on position to ballast resistor, other side of ballast to coil +. This coil + side goes to starter solenoid, small terminal that goes to ign. switch crank position.
    So when cranking resistor is byp***ed, coil + gets full voltage. Then key on, power goes through resistor.
    No power in accessory or off position.
    Be sure block is grounded to frame.
  15. Johnny Gee
    Johnny Gee
    from Downey, Ca
    In stock form the resistor byp*** is at the ignition switch in those day's and was "not taken from the starter solenoid". See Ignition 1 and Ignition 2
    Here's another view explaining when switch is only in on position (right upper arrows) and when switch is in start position (left arrow)........
    If stock switch has been replaced with a universal ignition switch. Then what other's have said before here. Go this route.
    jedy and mrharley51 like this.
  16. Ebbsspeed
    Ebbsspeed
    I really wish people would read entire threads before posting, as in many cases, including this one, there are people posting suggestions for a fix when in actuality the problem has been resolved.
    54vicky, swade41, jedy and 1 other person like this.
  17. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ I seen that. I still posted what I felt needed to be shared for future generations. :p :)
  18. sevenhills1952
    sevenhills1952
    You're absolutely right. That way whether through switch or starter solenoid the coil gets full power when cranking.
    I've seen so many friends old cars over the years that cranking coil + or on voltage would be like 5volts. They wondered why it was hard to start or low engine power.
    jedy likes this.
  19. jedy
    jedy
    Good point the electric choke is a separate issue, will start another thread to avoid confusion.
    Thanks!
  20. Truck64
    Truck64
    from Ioway
    That's crazy talk!
    54vicky and jedy like this.
