Technical Yeah, Its got a Hemi/41 shop truck
Discussion in 'The Hokey Ass Message Board' started by Bandit Billy, Jun 29, 2018.
  1. Bandit Billy
    Bandit Billy
    So, whilst snagging a 57 t-bird from her resting place for the last 47 years I happened upon a motor the PO had planned on using as the birds drive train. I offered a modest sum and backed my parts getter up and loaded up the dis***embled motor. I have hauled it around in the back of my truck until I had time tonight after work to unload it.
    The mill is a 56 Desoto hemi. The block was magnafluxed, ridge reamed, tanked, new cam bearings installed and painted then bagged for the last 20 years.
    The PO had used masking tape and paper to seal it up and the residue lingers on the mounting surfaces. the cylinders are stock bore and lightly rusted on the surface. A light ball honing ought to improve that and I need to clean off the tape residue.
    While I was taking inventory tonight I found the spark plug tubes and head bolts
    A cleaned set of std pistons with new wrist pins.
    Cleaned and ***embled rocker arms
    A box of pulleys, motor mounts, pumps, bolts and stuff I have no idea what they are. Yes, the harmonic balancer is there with the mounting bolt.
    A complete felpro gasket set and a nice little holley
    A cam in a box labeled only RV2 and a crank in a bag labeled std rods and mains, nicely polished like it was done yesterday. A new oil pump as well.
    A full set of push rods, new main bearings, new rod bearings, new rings, new lifters, new timing set
    And two nicely machined heads, ***embled with new valves and springs.
    Valve covers were there but no wire covers, oil pan filled with bolts and the old timing set. no timing cover or distributor but I found the hold down and old fuel pump.
    Seems the OP was all ready to re-***emble but never got around to it. Kinda sad but I will take it over for him from here. I found a receipt in one of the boxes for the bearings/gaskets/lifters/etc, it was dated 1987.
    It is stamped S23, a 56 Desoto 330 hemi and I did find the 2 bbl intake that was mounted on it. I think a re-***embly is in order after a thorough cleaning. What a unique find. Makes you wonder what is in the shop/barn/garage you p*** by daily.
    Now what to do with it?
  2. Max Gearhead
    Max Gearhead
    from Wisconsin
  3. Gotgas
    Gotgas
    from DFW USA
    Congrats! Cool engine. You gonna put it in the Tbird?
    I have a pair of Desoto 'FIRE DOME' wire covers if you're looking for some.
  4. 41rodderz
    41rodderz
    from Oregon
    Think I might be jealous:D Nice score
  5. 41rodderz
    41rodderz
    from Oregon
    I had a 291 in my 40 Plymouth business coupe. There big heavy ****ers.
    Hombre and loudbang like this.
  6. Bandit Billy
    Bandit Billy
    PM sent
    Hombre, lothiandon1940 and loudbang like this.
  7. Bandit Billy
    Bandit Billy
    I have paid more for a good bottle of Bourbon. I am surprised it is this complete and ready to ***emble. You never know.
  8. Stogy
    Stogy
    Go Billy go...yeehaww!!! Oh and one of these...;)...I must visit the other thread with the receiving end of this powerhouse.
    chryslerfan55, Hombre and loudbang like this.
  9. Just Gary
    Just Gary
    Cool project!
    Hoodless prewar Ford roadster, or maybe a coupe since you're in a rainy clime. :rolleyes:
    Fenders are up to you. Blackwall bias plies mounted on 16" steelies. Single stage paint in a stockish 1950's color like '56 Chevy sierra gold or dusk plum.:cool:
    So far, so good?:)
  10. 392
    392
    Nothing like a Hemi. Good score.
    Hombre, CudaChick1968 and loudbang like this.
  11. hotrodA
    hotrodA
    Scoring that 'bird was a steal but you really hit it with this!!
  12. Hombre and loudbang like this.
  13. Bandit Billy
    Bandit Billy
    upload_2018-7-1_21-3-7.png I cleaned up the block tonight. It was machined in 87 according to the receipts.
    I ran there ball hone through the bores with plenty of oil. cleaned up nicely. There is a ridge but is minuscule.
    The slight surface rust I removed using only 10/40 and emery paper.
    Should I be concerned with this groove in the cylinder wall?
  14. Put it in the T-bird, then sit back and listen to all the screeching/weeping from the restorer crowd.
    RDE, aussie57wag, Hombre and 9 others like this.
  15. Stogy
    Stogy
  16. vtwhead
    vtwhead
    the groove will fill up with carbon they used to say:rolleyes:
    Nice score by the way.....
    Hombre, loudbang and czuch like this.
  17. Way to go Billy, and I'd stick it in that Bird also. If the rings are Cast Iron that little mark wouldn't bother me at all. Even if they are a Cast/Chrome and that's the only one, I wouldn't loose any sleep. What machine shop did the work on it?
    The Wizzard
  18. Deuces
    Deuces
    Nope! Don't sweat that small ****....
  19. Bandit Billy
    Bandit Billy
    No idea on the shop. I would ***ume someone in Salem, OR where he used to live. The receipt for all of the parts was from Californy, $650 bucks worth even back then.
    Gotta stop by the auto parts house and grab some plastigauge and set the crank in it tonight. Fun project this week.
  20. Deuces
    Deuces
    Please post plenty of pictures....
    Thanks bud!..... :)
  21. belair
    belair
    Cool score.
    Hombre, loudbang and kidcampbell71 like this.
  22. Bandit Billy
    Bandit Billy
    One thing, what would you guys use to clean out the lifter bores? They have the same little rust build up from sitting this long that the cylinders had. I don't have a hone that small. Ideas?
  23. Gerrys
    Gerrys
    wheel cylinder hone should do the trick.
    RDE, loudbang, Stogy and 2 others like this.
  24. Deuces
    Deuces
    Yep! What he^^^^^sez......
  25. treb11
    treb11
    The same outfit that makes ball hones for cylinders makes 'em for shotgun barrels.
    Sent from my SM-G950U using The H.A.M.B. mobile app
    Outback, Atwater Mike, Deuces and 3 others like this.
  26. 25.00 will get you a little ball hone to fit right in the lifter bore. Different grits too.
    chryslerfan55, loudbang and Stogy like this.
  27. Bandit Billy
    Bandit Billy
    On it. Thanks.
    loudbang and GordonC like this.
  28. ago
    ago
    from pgh. pa.
    If the front damper is original? don't use it, rubber dry rots. There is two threaded oil galley plugs in the rear under the bellhousing. One is smaller than the other. Don't forget the inner one. You might want to adapt BB Chevy water pump, Shortens motor 4". but you loose mechanical fuel pump.
    loudbang, Stogy and Bandit Billy like this.
  29. Bandit Billy
    Bandit Billy
    ^^^I saw that timing cover on Hot Heads site that uses the chevy water pump, tricky. Ill go home and check those plugs in the galley.
    Damper is original and likely quite old.
  30. Block has been machined to take cup style freeze plugs too!
