Technical Yep, I Really Dropped the Grommet into the Brake Booster
Discussion in 'The Hokey Ass Message Board' started by 4woody, Jul 1, 2018.
  1. 4woody
    4woody
    Yes I did.
    Took out the check valve, and got the grommet going the wrong way and in it went. Doh!
    Looking for suggestions how to get it out. Do I even need to get it out?- seems like it wouldn't get in the way of anything rolling around in the bottom of the booster...
    I tried duct taping some flexible tubing to the shop vac nozzle, but got nothing. Bent coat hanger wire with a hook on the end: whole lotta nothing.
    Any alternative to taking the booster out and turning it upside down and shaking it?
  2. kidcampbell71
    kidcampbell71
    What is the application for the booster that you're referring to ? Any pictures ?
    Does the booster split ? Most of the boosters I've taken apart .... have their own series of tabs ... that when placed together, as two halves .... then twist into a locking position. There is a diaphragm and plunger, with ***ociated bladders, lock rings, and etcs.
    I can't see how you're going to get the grommet out without separating the booster into its individual pieces. Maybe someone else will be along with better info .....
    warhorseracing likes this.
  3. e z i
    e z i
    I'd leave it alone, Prolly won't hurt a thing.
    Randall likes this.
  4. BJR
    BJR
    Get a piece of fuel line and duct tape it to the shop vac hose so it ****s through the fuel line. Turn on the shop vac and stick the fuel line in the booster, aiming the hose toward the bottom the booster and see if you can trap it that way. Have a needle nose handy to grab the grommet if the hose trick catches it and use it to pull the grommet through the hole.
  5. X38
    X38
    You can do the same thing with a rubber magnet.
    kidcampbell71, Jibs, alanp561 and 7 others like this.
  6. mgtstumpy
    mgtstumpy
    Easiest is just unbolt the MC from booster and remove booster, turn upside down and let gravity do the rest. Use your little finger to hook it up and extract. Bolt everything back together after you've installed the grommet correctly. Or try using one of these flexible expanding jaw tools to grab the grommet and pull it through hole?
  7. pat59
    pat59
    Wow! a light, a grabber and a magnet.
  8. warhorseracing
    warhorseracing
    from cameron wv
    Yea, where did you get that at Mgtstumpy?
  9. pat59
    pat59
    If ya click on the pic, it'll take ya to the page.
