Hot Rods Save of the day!!(single seater)
Discussion in 'The Hokey Ass Message Board' started by rusty rocket, Mar 14, 2017.
  1. rusty rocket
    rusty rocket
    Stock as a rock, I'm being a cheap *** on this build so I am using what I have. I do have a N.O.S. 1940s carb that I will use. The stock carb had all the choke stuff taken off it.
  2. alchemy
    alchemy
    I always thought this was a traditional solution. Rolled up chicken wire in the Garrick T.
    Greenblade, Flipper, brEad and 5 others like this.
  3. rusty rocket
    rusty rocket
    Ha Ha, Now thats a way to do it. I will have to keep that in mind.
  4. alchemy
    alchemy
    I'm gonna use a giant cotter pin to hold the chicken wire in mine.
  5. plym_46
    plym_46
    from central NY
    Cotter pin???? I think bailing wire or a bent wire coat hanger are more traditional! Especially with all that ford content.
    patmanta and chryslerfan55 like this.
  6. alchemy
    alchemy
    A big cotter pin like the one that hangs out of a flathead oil pan's bellhousing area. Very Ford-ish.
  7. rwrj
    rwrj
    from SW Ga
    I made this little baffle, but to be honest, the chicken wire looks good, too. I might roll some up and do a comparison test. Mine sounds a little like a tractor right now. I did drill some holes in the periphery of that end plate.
    brEad and chryslerfan55 like this.
  8. plym_46
    plym_46
    from central NY
    How is yours doing? Is it a daily driver yet?
  9. Stogy
    Stogy
    It's almost baffling all the things going on here...:D...remember install them after July 4...;)...budda bang...boom
  10. rwrj
    rwrj
    from SW Ga
    Mine? It's kind of a driver, but I wouldn't call it daily. We're in the dog days of summer here, rain almost every day. It lives under a blue tarp.
  11. rusty rocket
    rusty rocket
    Hey now that ford bash HURTs;)
    Stogy and chryslerfan55 like this.
  12. Stogy
    Stogy
    I say Upscale...Cotter Pin...keep em guess'n...:p
  13. rusty rocket
    rusty rocket
    I have one of the front shock mounts built and tacked on. Three more to go. IMG_2970.JPG IMG_2971.JPG IMG_2972.JPG
  14. Gavin Tittle
    Gavin Tittle
    Stogy likes this.
  15. rusty rocket
    rusty rocket
    Ha Ha everyones a comedian. Three more to do total(front and back)
    Stogy likes this.
  16. plym_46
    plym_46
    from central NY
    Clearance for steering stuff??
  17. rusty rocket
    rusty rocket
    Oh yeah tons of room, the pictures are deceiving.
  18. rusty rocket
    rusty rocket
    Have the exhaust ruffed out and built a pipe hanger that will secure the end of the tailpipe. I will make a bracket off the shock mount when my shocks show up and I can get the final placement. Still trying to teach myself how to tig weld I need more practice for sure! IMG_2987.JPG IMG_2988.JPG IMG_2989.JPG IMG_2990.JPG
  19. Stogy
    Stogy
    Great work Rusty a like doesn't say enough...a very cl***y period in racing and your capturing that essence...it's a pleasure to be able to witness this adventure. Thank you.
    Doctorterry likes this.
  20. Looks great!
  21. rusty1
    rusty1
    ...are you gonna rubber mount that exhaust clamp so it has some movement?
  22. rusty rocket
    rusty rocket
    My thought is- I have some black header wrap that I can wrap around the pipe, slide the clamp over it and just snug a bolt and castle nut/cotter key on it. I think it should allow enough movement
  23. 55Deso
    55Deso
    from Wyoming
    Awesome build so far! Between you, @rwrj , and attending the Hot Rod Dirt Drags last summer I'm afraid I'm going to end up with a build of my own before too long if I'm not careful!
  24. rusty rocket
    rusty rocket
    Thanks Stogy, You have done your part with all your photoshop skills. The other day I was in the shop mulling things over and started thinking I have been messing with this project for a year and four months. I wonder how long it would have taken a racer back in 1950 to get a car like this on the track.
    And you are correct it has been a fun little adventure.
  25. rusty rocket
    rusty rocket
    Have one rear shock mount tacked in, as usual its overkill. I also added a bracket off of the top of the shock mount for my exhaust pipe. IMG_2998.JPG IMG_2999.JPG IMG_3001.JPG
    brEad, Okie Pete, brad2v and 6 others like this.
  26. rusty rocket
    rusty rocket
    Okie Pete, Shadow Creek and Stogy like this.
  27. rusty rocket
    rusty rocket
    So I had a thought the other day, My head rest is a 46 Chevy pickup headlight pod when I got the bucket it still had the running light attached to the top. I had taken it off and hung it on the wall but I got to thinking what if I turned it around backwards, shortened it, recontoured it to the head rest and use it for a tail light/brake light? I am going to run a single light under the center of the frame right behind the rear spring also. Thoughts? IMG_3006.JPG
  28. Peanut 1959
    Peanut 1959
    Love it!
    falconsprint63 likes this.
  29. Doctorterry
    Doctorterry
