Technical Crank Won't Turn - New bearings/pistons/rings
Discussion in 'The Hokey Ass Message Board' started by yycyak, Jul 2, 2018.
  1. yycyak
    yycyak
    Hi all,
    So I have a problem with my current Ford 300 build: the crank won't turn. Here's where I'm currently at (head is off, just working with a bare block here):
    - mic'd all the crank journals, and they all mic'd within spec;
    - ***embled crank bearings (dry), plastigauged them. Clearances were about .003;
    - lube + re***emble everything. Torqued main bearings and rotate ***embly. It mostly rotates freely - needs about two fingers of firm pressure to rotate (note: Camshaft and timing gears are installed, so might be a bit of extra resistance from this.)
    - install new pistons and rings. Didn't break any rings (yay!)
    - install rod bearings and caps (dry). Plastigauge bearings. Clearances show about .0008 to .0015-ish, which is within spec;
    - Lube everything and re***emble. Torque to spec (40ft/lbs);
    At this stage, nothing will rotate. I have a 1/2" drive ratchet on the block, and it won't move at all. If I loosen off the rod bolts a little bit, things will turn with the "usual" effort on the ratchet.
    Has anyone seen this before? As far as I know, all the caps are on correctly, and the bearings are non-directional. But the last thing I want to ***ume is that because everything mic's/plastigauges within spec, I can just go ahead and fire things up. Not being able to turn the rotating ***embly by hand is freaky.
  2. egads
    egads
    Take the rod cap's back off. Replace and torque them one at a time ,rotate crank after you do each rod cap.
  3. Engine man
    Engine man
    from Wisconsin
    Did you dip the pistons in oil or oil the pistons and cylinder bores?
    Unkl Ian likes this.
  4. 1934coupe
    1934coupe
    What he said and try to go backwards to the last one you torqued before it stopped turning. (did I say that right).
    Pat
  5. Unkl Ian
    Unkl Ian
    Check the thrust clearance, and the side clearance on the rods.
    zuke and moparjimd60 like this.
  6. Unkl Ian
    Unkl Ian
    Any chance one of the rod caps is on backwards ?
    woodz, Atwater Mike, ottoman and 5 others like this.
  7. 55Green
    55Green
    As mentioned above. Make sure pistons/rings/bores are well oiled and then do one rod at a time till you find the issue. Could be something as simple as a rod cap on backwards or that rod could be well out of spec on the big end. Don't rule out wrong over/undersize bearings. Can always swap them to another rod to confirm before you order replacements.
  8. Blues4U
    Blues4U
    from So Cal
    You mean "on the crank", right? You would have been turning the crank while installing pistons/rods, was it getting tighter to turn as you installed them? Or did it just lock up with the last set?
  9. squirrel
    I always install one piston at a time, and torque the rod nuts, then turn the crank a few revolutions, and get it in position to install the next rod/piston. If you do this, then you can see how it feels each time you add a part.
    As for the rod bearings being "directional", the rods and caps are matched, the bearings have a tang, the rods and caps have notches for the tangs. The tangs and notches are supposed to be on the same side. And the rod/piston ***embly should have a "front" side, although on an inline it's not as critical as on most V8s.
    But yeah, take it apart, put it together slowly, see what the problem is.
    reagen, big duece, Hombre and 2 others like this.
  10. buffaloracer
    buffaloracer
    from kansas
    You sure need to start again with the rods. Bearings and bores need to be lubricated. As has been said, you need to turn the crank after each rod is ***embled. Bearings are directional. Rod caps are matched and directional. .0008 to .0015 may be within specs but is tighter than I'd want things.
    Pete
  11. saltflats
    saltflats
    from Missouri
    Ring end gap?
    What did you use for lube?
  12. woodiewagon46
    woodiewagon46
    from New York
  13. I don't see how that would be possible. Normally, one would install the crank and bearings, check the end play, torque the mains, and then spin the crank to check that step, and then turn it for each piston and rod ***embly.
    egads likes this.
  14. 1934coupe
    1934coupe
    Unlikely if he was able to turn it over with two fingers of firm pressure.
    Pat
    studebaker46 and egads like this.
  15. Mr48chev
    I found out a long time ago that it is prudent to do just as Jim says he does in that install 1 piston, toque the rod bolts, rotate the crank a couple or few times, get the rod journal on the next piston to be installed at the bottom of the stroke and go again. It lets you know if you have a problem then and there.
    You keep saying that you put this that and another together "dry" did you pull the crank clear back out after you plastigauged the mains and lube all of the bearing? Did you lube both halves of the rod bearings after you plastigauged them ? Did you lube the pistons/rings before installing them as someone else asked?
  16. silent rick
    silent rick
    i've seen tight rings do it. a friend had file fit rings and was gapping them on the tight side.
    but that wouldn't explain why it will turn after loosening a few caps.
  17. thorpe31
    thorpe31
    from nor-cal
    As already said go back and do one thing at a time.
    If the crank was turned sometimes the journal radius will interfere with the rod & bearing chamfer
  18. pitman
    pitman
    No rod is bent? Otherwise Jim's one at a time, and test.
  19. southcross2631
    southcross2631
    I have a dumb question . I had a guy bring me a motor one time that he rebuilt and told me it would not turn over . I said did you use ***embly lube and he looked me straight in the eye and said yes I did , both sides. He had put ***embly lube on both sides of the bearings taking all the clearance out.
    Took it apart and cleaned the backside of the bearings and the caps and it turned over just like it should. You didn't do that ,did you?
  20. noboD
    noboD
    Are you sure you didn't switch caps from one rod to another?
    Atwater Mike likes this.
  21. sunbeam
    sunbeam
    Don't think it's pistons will turn with loose rod caps. If caps on backwards it would still plastigauge ok but would be tight at the parting lines. The non-directional bearing thing makes me wonder.
  22. Hombre
    Hombre
    Did you protect the rod "Bolts" when you installed the rods and pistons? The only time I ever had this problem was the first time I built a motor. I didn't know that you needed to slip a protector over the rod bolts. When I installed the rods one bolt barely and I mean barely nicked the crank. There was no way to turn that crank. I pulled it apart and could not believe that little tiny nick was the problem, but it was...
  23. Blues4U
    Blues4U
    from So Cal
    Believe it or not, I am in the process of writing up a failure ****ysis report of a Cat C27 (V12 diesel engine) that had spun 2 connecting rod bearings. The engine was rebuilt about 5000 hours ago (about 2.5 years). This is a short time for one of these engines. Depending on the extent of the rebuild you would hope to achieve at least 10,000 hrs. ****ysis of the bearings shows that something was applied to the backs of the rod bearings, creating a tight spot on the bearings, which is evident on several of the remaining bearings. My best guess is that it is oil or ***embly lube. It also could have been some kind of retaining compound, but I'm betting it was oil.
    Truckdoctor Andy likes this.
  24. ROD OFFSETS?
    I would double and triple check that right bank rods are in the correct orientation frontfacing/rearfacing, and that all left bank rods are also on the correct side and facing correctly.
    A simple act of putting a right bank rod on the left, or confusing front/rear facing can lock up a bearing by simply being slightly ****ed.
    A simple error such as "do the stamped numbers all face the cam, or all numbers face outward?" or all face to the right? can make all the difference.
    WHY BE ORDINARY ?
  25. squirrel
    300 six? or is it really a V8?
  26. you're right. I didn't notice "head" singular.
    I would still verify numbers facing right or left, just in case.
    I would also note the tiny weep-hole locations on the rod big ends.
    If there is one oil weep hole facing a different way compared to the other rods, that is a dead give away that one rod is facing wrong, or the wrong rod grabbed from the parts pile. Or a replacement rod used in the place of a bad rod in the past. Easy to overlook during hurried ***embly.
    WHY BE ORDINARY ?
  27. sliceddeuce
    sliceddeuce
    I`m still trying to believe a 300-6 actually wore out and needed a re-build.
    shivasdad likes this.
  28. shivasdad
    shivasdad
    from Texas
    I think sitting around for years and years is harder on those engines than running them for the same amount of time. I've found some rough ones at swap meets that I rebuilt instead of trying to clean and run.
  29. Ebbsspeed
    Ebbsspeed
    By torquing rods one at a time you'll figure out which one (or more) are causing the issue. When you find one that does it, loosen it back up and continue to check any remaining, as you could have a problem with more than the first rod that shows a problem.
    .0008 is the absolute minimum acceptable clearance. Any error in measuring, or a rod journal slightly out of round at this minimum clearance, will cause a nasty bind.
  30. Hombre
    Hombre
    You know guys, is this one of those post were a Poster asked a question everyone gets busy trying to figure a solution to "HIS" problem and we never hear from the cat again. I mean 30 post's and no response from him---Give me a break.
    rjones35, Unkl Ian, egads and 2 others like this.
