Technical i found a 454. ugh
Discussion in 'The Hokey Ass Message Board' started by Jim Lato, Jul 3, 2018.
  1. Hnstray
    Hnstray
    from Quincy, IL
    Yes, typically.....HD parking brake. Also, should have the 2.75 first gear ratio planetary set vs the std 2.48 T-400 first gear.
    Ray
    chryslerfan55, badvolvo and Jim Lato like this.
  2. Jim Lato
    Jim Lato
    gotcha gotcha, im guessing you are correct with the low compression. i wouldnt mind finding a 671 to slap on her always wanted one. since i just got this thing, pardon me for not knowing what im gonna do with it yet, so far collectively we are all building it right now lol
  3. Anything older that you get is a work in progress. Take your time this isn't a race, and even if it was we are still bench racing. I think you found yourself a good starting place. ;)
    chryslerfan55 and Jim Lato like this.
  4. Jim Lato
    Jim Lato
    hey i appreciate it man, ya i learned a while ago slow and steady wins the race when it comes to bench time. do it right the first time. i love building up stuff keeps me out of trouble.... kinda
  5. catdad49
    catdad49
    RV pic looks like the Road Kill guys got at it! Have fun, free is Good (most of the time).
    Jim Lato likes this.
  6. Jim Lato
    Jim Lato
    That’s where I got the idea!! Haha. It worked out great. Only thing is, rolling around a cherry picker on the dirt lol I’ll have to find some plywood
    chryslerfan55 and catdad49 like this.
  7. Hnstray
    Hnstray
    from Quincy, IL
    First Principle......“There is no such thing as a free lunch” :D
    ‘Free” in this case would be the engine/trans pulled from the RV by the owner and delivered to the OP’s home or shop at no charge. This isn’t a bad deal, but requires a fair amount of sweat equity.
    Ray
  8. catdad49
    catdad49
    Agreed Ray, just built a garden tool holder for one corner of the garage using 'free' wood. Lots of sweat equity though. It's all relative!
  9. Jim Lato
    Jim Lato
    Semi free, I did sweat a lot Saturday when it was 97 and farting around with it lol. And no beers [emoji482]
    chryslerfan55 and Hnstray like this.
  10. F-ONE
    F-ONE
    from Alabama
    The difference between a SBC and a BBC is a lot like the difference between beer and whiskey. Beer, you know where you are at. Whiskey, sneaks up on you.
    A small block will pull until it plateaus. The valves will float and she may pop but you definitely can feel the peak and there ain't no more.
    A big block pulls until it breaks.
  11. Jim Lato
    Jim Lato
    This is great. And I dig the booze reference so I can understand hahaha. I think we should make t shirts with this on it
    chryslerfan55 and F-ONE like this.
  12. squirrel
    I ain't broke one yet.
  13. Kan Kustom
    Kan Kustom
    Keep it up guys. I am really enjoying and learning from this thread. Your years of experience with these are priceless.
  14. F-ONE
    F-ONE
    from Alabama
    There is something special about the Mystery Motor.
    My brother had a 70 or 71 402 built to 411. It had some pepper in it.
    That dang thing had enough *** to light them up with 256 gears and a Muncie..... like a big S in the road. On the top end.... Da....ummm!
    454s you are good. 427s are the ones you have to really check out. The tall deck truck 427 is a different critter than the car 427.
    John Starr and chryslerfan55 like this.
  15. Jim Lato
    Jim Lato
    I have thoroughly enjoyed this thread so far. Learning about the rat. I’m pretty pumped to dive into this thing. Anyone got any cheap doner parts laying around ?? [emoji16][emoji16][emoji16][emoji16][emoji16]
  16. badvolvo
    badvolvo
    If you have to go too far, consider stroking to a 496, makes great torque, you won't need to see 6500. Rotating ***embly costs are about the same as a 454. I was going to do the 496 on mine, got carried away, ended up with a 10.2 dart block and 632". It won't be running till spring, because I am slow these days. 632 going into avatar
    swade41 and Tim like this.
  17. Jim Lato
    Jim Lato
    Holy balls. Well maybe I can go that route. Might as well [emoji23][emoji482]
  18. southcross2631
    southcross2631
    My 3700 lb. 70 Chevelle ran high 10's in NHRA Super Street and bracket's with a .060 over 454 12.5 to1 trw pistons ,stock rods with ARP bolts . .600 lift hydraulic flat tappet cam from Lunati. Home ported oval port heads single plane intake and Holley hp 950 carb. I had $2500 .00 in it . The block, crank and rods come out of a boat. The heads were 049 castings with a good valve job and isky springs.
    I put over 500 do***ented p***es on that motor before it pulled a rod journal out of the cast crank.
  19. Hnstray
    Hnstray
    from Quincy, IL
    Just yesterday a friend told me he is getting a factory stock 8.1L (496) with certified very low miles and complete. Would likely be willing to sell it within the budget you have mentioned in earlier post. If interested, I can connect you.
    Ray
  20. Jim Lato
    Jim Lato
    Now that’s impressive. Your worked her good for some time. This is exactly what I would like to do
  21. Jim Lato
    Jim Lato
    I may be! Let me know what comes of it. How far are you? Are you from wisco?
  22. Hnstray
    Hnstray
    from Quincy, IL
    West Central, IL....along the Mississippi....he lives about 85 miles south of me.
    Ray
  23. sunbeam
    sunbeam
    I always grin When I hear wow it's a 4 bolt. I know it's a Ford but Bob Glidden was ask about what block he ran. He said 4 bolt 351c blocks are to hard to find so I mostly run 2 bolt stuff and his motor made some hp.
    Kan Kustom, loudbang, egads and 2 others like this.
  24. Jim Lato
    Jim Lato
    I’m hoping I can say those exact words and grin then sip on my beer lol
    Deuces likes this.
  25. bobss396
    bobss396
    I ran a '66 big block in a Nova bomber car, 325 HP from the factory but I scored some better 454 heads for it and slipped an L88 solid cam into it. It would run 6300 revs at Islip, 6500 at Riverhead and was quite strong for the almost zero bucks I had in it.
    John Starr and Deuces like this.
  26. Jim Lato
    Jim Lato
    Damn. Well if I can get away with a killer build for next to nothing I’d be pretty happy. I mean I’m already on the up and up. Free nindy free
  27. Chappy444
    Chappy444
    John Starr, Deuces and Shadow Creek like this.
  28. Jim Lato
    Jim Lato
    Deuces likes this.
  29. squirrel
    I have 4 bolt blocks in both of my current big block powered rides. One started life as an LS-7 crate motor, the other appears to be a 1991 block, last of the Mark IV motors. My understanding is that they went to 4 bolts in the late 1980s on the last pickup/motorhome 454s they made, but most of them are 2 bolt.
    The tall deck medium truck 366 and 427 are a different story, they were all 4 bolts with steel cranks, and small valve heads, as far as I know.
    500 hp...you don't need 4 bolt mains. The main webs and caps on the 2 bolt blocks are over an inch thick, there is a lot of meat in there compared to most engines.
  30. Jim Lato
    Jim Lato
    Ya I was gonna say, I mean it would be sweet if I got lucky. But if not. Like you said there is a lot of meat holding that crank up. Once I get off work here at 3 I’m gonna head over there after I weld a caster on my cherry picker lol, and find a piece of plywood
    Deuces likes this.
