Projects Building a foldable, stowable Roadster top
Discussion in 'The Hokey Ass Message Board' started by wstory, Jul 3, 2018.
  1. wstory
    wstory
    I love my Roadster and have logged over 100K miles of ******* fun in it. I've been froze, snowed, baked and drowned to the amu*****t of my cruising friends. Never have I considered giving up the fresh air, sunshine and vistas that top-down cruising avails. However, age and the dermatologist's warnings say, I gotta do something before melanoma ends the good times.
    A removable stowable top that I could "erect" for sun protection seemed the answer. However, anything I could buy was outta my price range and the stowable part meant that placement in the trunk was on the diagonal. And since I could not find beer or luggage in triangular packages, that was the deal breaker for a store-bought top.
    So I set about designing and building a minimal top that provided some sun protection while allowing some semblance of open air cruising. And further, the package when folded, had to store efficiently and squarely in the trunk.
  2. wstory
    wstory
    I started to visualize a top in late 2016 and did a number of of PhotoShopped images to visualize a goal. Decided on a direction that was sorta Porsche Speedster like. Note the high point projected by the angle of the window opening. Not the final solution but, a direction I liked. At this point I had no idea how it would work so I set about figgerin how to pull it off.
    All this measuring and mocking up stuff helped to "zero in". Used up a whole buncha EMT conduit. Much of the initial stuff went in the trash but I've found it's a good way to sneak up on a design solution.
    I made the tube bender, copied from a conduit bender but with a tighter radius
    Found this trick hinge that allowed me to do the folding thing with the bows.
  3. wstory
    wstory
    I might add as a point of reference, the ****pit is extended and the top terminates at the deck lid opening.
  4. lothiandon1940
    lothiandon1940
    I'm liking where you're going with this.:)
    Hnstray likes this.
  5. L. Eckart
    L. Eckart
    looking good so far, keep it coming
  6. Flatheadjohn47
    Flatheadjohn47
    from Lewes, DE
    CFC4BD85-7C2C-41E3-84EF-366B9F5643D5.jpeg Part of the problem with a roadster is how to stow the top when it is “down”. My 32 cabriolet has several advantages a roadster doesn’t possess;when the weather is cold or rainy,I simply roll up my windows and the roadster owner has to “snap on” side curtains to keep the nastiness out. A cabriolet has a “well” behind the driver that allows the folded up top to sit in when not in use and is near flush with the trunkid. A roadster top “down” adds 8-12inches of top hovered above the decklid and is not too pretty. Flatheads Forever!
    48fordnut likes this.
  7. GordonC
    GordonC
    I like where this is headed!
  8. Roadsir
    Roadsir
    Well thought out. I like those barrel hinges, those are a nice find!
    lothiandon1940 likes this.
  9. More please?!
  10. louisb
    louisb
    So far I like it. Want to see how you finish it.
    —louis
  11. GTS225
    GTS225
    I'll be watching with interest, too. And if you would, please include a sidebar on the construction of that tubing bender. It appears to be an aluminum/plywood sandwich with a piece of angle bolted along one edge. Did the conduit collapse or kink at all?
    Thanks.....Roger
  12. continentaljohn
    continentaljohn
    My roadster has a beautiful top but haven’t been on more then once or twice because of it size. I love the idea of a portable top you can toss in the trunk just in case.
    Love the roadster and I really like your plan and where its going .. I have a small machine shop so if I can help I would love to build such a top and great look
  13. woodiewagon46
    woodiewagon46
    from New York
    Very nice work and engineering. Be careful not to share too much info, someone will steal your idea and start selling the top. Ask me how I know.
  14. X-cpe
    X-cpe
    I've got a channeled coupster on a frame with with an eight inch Z in the back, gas tank behind the seat, and battery in the trunk. My idea for the bows was copied from from an MG Midget I had. The bows were made in two halves with one end swaged to slide into the other. The primary bow fit into a socket in the body with the secondary bows hinged off of it. What I'm interested in is how you are going to handle the header. That is my hold up. My trunk doesn't have enough linear space in any direction to fit the header as a one piece unit.
    P.S. Where did you find those cool hinges?
  15. SquintBoy
    SquintBoy
    Your top is well thought out. Keep the pics coming.
    For reference, here are 3 pics of '56-'58 high bow Porsche Speedster tops. '54 & '55 had slightly sleeker low bow tops but they didn't have enough headroom. You can see that these are very simple 2 bow tops. That's not counting the windshield bow and the horizontal rear bow that stays affixed to the body. I also had a Big Healey with an erector set top frame that stowed in the trunk. It was easy enough to use but I was 50 yrs younger. The Speedster top goes up or down with one hand at a stoplight! 20180704_103402-1.jpeg 20180704_103459-1.jpeg 20180704_103430-1.jpeg
    Sent from the red phone
    dana barlow, Tim, Hnstray and 2 others like this.
  16. wstory
    wstory
    If someone copied my top design, I'd be complimented. However, it's so labor intensive, it'd probably cost $6-7K :eek:
    jimmysweden, dana barlow and brEad like this.
  17. wstory
    wstory
    Started by using a conduit bender from Home Depot. 1/2" EMT is close to 5/8" OD which served for the mock-up. I had decided to use heavy wall 5/8 aluminum tube for the final so I copied the conduit bender in order to get a slightly tighter radius,...roughly 5". That's as tight a radius as I could get without the tube kinking.
    As you noted, the center of my bender was built up of a coupla layers of MDF to get 5/8" to match the tube. There is a strap at the beginning if the radius to hold the tube much like a brake line bender. The aluminum "cheek" plates discourage the tube from flattening on the ID. The angle you mention is just for holding the bender in the vice. IMG_9487.JPG Img_7680.jpg
  18. wstory
    wstory
    Google Soss Hinges. Very cool. Usually ***ociated with wood working. Got mine from Grainger.
    dana barlow, lothiandon1940 and OFT like this.
  19. Andy
    Andy
    Fantastic!! I am inspired to work on my top again. Thanks!
  20. wstory
    wstory
    Header was the next thing I was going to cover. Not meaning to offend,...I hate the headers that look like a 2 x 4. I wanted something with a bit of a visor and had a "crown" across the top. Developed an arc that raises 5/8" over 36" (another Google find) and made a template to mockup the header just to visualize what I had imagined.
    Got the first round of bows bent and attached in the profile I was attempting and ,..doah! Img_7661.jpg
    I'm 6'2" and the ****pit has been stretched and the seat lowered. A little tight I'd say. More conduit in the s**** pile.
  21. louisb
    louisb
    Thanks for sharing your mistakes. I am the same height so I am following closely.
    —louis
    nunattax likes this.
  22. Dirty Dug
    Dirty Dug
    topframe3.jpg topframe1.jpg This is how I made mine.
  23. H380
    H380
    from Louisiana
    Look through this guys vids.
    Adam F, dana barlow and louisb like this.
  24. wstory
    wstory
    More fussin and bendin and 20-30 more feet of conduit in the trash and I'm where I wanted to be. The view approaching from the driveway makes a statement I really like.
    Decided to do a "virtual" t******* of the bows now that their configuration is pretty well fixed. I'm a bit of an amateur at PhotoShop but the second pic really gets me hot! Note that the backlight is open and there is a mesh indicated as the center panel of the top. This goes with the initial parameter of minimal interference to fresh air and vistas.
    This image has stuck in my head for about 6 months now as I've plodded through myriad details to make it work. Recently some changes have been required however, non detrimental to the goal.
    dana barlow, Jet96, wicarnut and 15 others like this.
  25. GTS225
    GTS225
    Oh, HELL YEAH! I won't claim to be any type of designer, but that is really looking good. The off-setting color helps, too.
    I suspect your "followers" just got a bit more dedicated, at least to this thread.
    As a sidebar, I found a slightly different type of hinge in the boating world, for bimini tops, made of stainless, but they start at 3/4" and get bigger, in case someone wanted something like that.
    http://www.baselinemarine.com/shopdisplayproducts.asp?id=162&cat=Stainless+Steel+Tube+
    Roger
    a boner and kidcampbell71 like this.
  26. wstory
    wstory
    Regarding the header, a buncha 1x pine was glued up and the contours transferred from the mockup. The ends were cut off and pinned so that they could be hogged out to accommodate the hardware attaching the header to the windshield posts. The header at this point is cut in half and hinged to address the "stowable" goal. Img_7878.jpg IMG_8026.JPG Img_8145.jpg Img_8156.jpg IMG_8226.JPG
    Got these neat "push to release" pins to lock the header to the posts, sourced from marine hardware supplier.
  27. Fuzzy Knight
    Fuzzy Knight
    from Santee, Ca
  28. nrgwizard
    nrgwizard
    from Minn. uSA
    Thanks for the how-I-did(am-doing)-it. I really like the large back window area, but the mesh center is where it's at, for me. Put a serious smile on me, just thinking about how that'll feel going down the road. Should be quick to cover up, when you have to have a top on. Consider this idea fairly appropriated... :D . Same for the fold-it-in-half gig. You also ended up w/a very nice form to the top. Hard to do. Can't wait to see this through to the finish. Good on you!
    Marcus...
    Hnstray likes this.
  29. wstory
    wstory
  30. nrgwizard
    nrgwizard
    from Minn. uSA
