Technical Engine won't turn!
Discussion in 'Traditional Hot Rods' started by Tank65, Jul 5, 2018.
  1. Tank65
    Tank65
    from Arizona
    I just rebuilt a SBC 350, everything is standard except for the stage 2 cam.
    Once ***embled and still on the stand. I can turn the motor with the starter (high torque) and by hand, but once I put spark plugs in it won't turn. I have checked and adjusted the journals, bearings and caps for size and torque. Everything seams fine but still nothing. I have even changed batteries, thinking that ight of been a issue.
    Anyone ever see this? Any ideas.
  2. squirrel
    do you have the correct spark plugs? not long reach, are they?
    but it sounds like fun to figure it out, we don't know how much torque it takes to turn with the plugs out, so we can't really say what's wrong.
    1934coupe likes this.
  3. manyolcars
    manyolcars
    Does it turn freely with just one sparkplug? Two?
  4. Bleach
    Bleach
    Sounds like the push rods are missing.
  5. Tank65
    Tank65
    from Arizona
    -Spark plugs are correct.
    -Even with one sparkplug in it will turn until that cylinder starts compresion.
    -I will have to check how much torque it takes to turn with no plugs.
  6. saltflats
    saltflats
    from Missouri
    Cam timing correct?
    jchav62 likes this.
  7. jchav62
    jchav62
    Or the timing chain.
  8. Beanscoot
    Beanscoot
    Weak battery?
  9. porkshop
    porkshop
    from Clovis Ca
    Bad Ground. Can you turn it over with a breaker bar with the plugs in? I ran into this on a car I did not build. Had Battery in trunk, ground cable to frame, No ground cable to engine from frame. would turn over with no spark plugs then quite soon as you put them in. Drove me nuts for a bit....
  10. Tank65
    Tank65
    from Arizona
    Yep cam timing good
  11. Tank65
    Tank65
    from Arizona
    Tried a new one, still same
  12. Sounds like the valves are staying closed or something is hitting
    Pull the valve covers and look to see if things are moving up in there
  13. Fuzzy Knight
    Fuzzy Knight
    from Santee, Ca
    Pull the heads and see if still does not rotate!!!
    olscrounger likes this.
  14. Tank65
    Tank65
    from Arizona
    cam timing is good
  15. Johnny Gee
    Johnny Gee
    from Downey, Ca
    That would be something. But I'm not perfect either. Took my 2 hrs to realize I left the rotor out after a tune-up. o_O :confused: :( :oops: :mad:
    czuch and Unkl Ian like this.
  16. Mr48chev
    I'd go for bad electrical flow, you might have to clean a few coats of that nice shiny engine paint off from under where the ground strap goes or from under what the ground strap bolts to to make good contact. A lot of 350's have the ground strap bolt to the alternator bracket and if you painted the block and intake up real pretty and then painted up both sides of the bracket you may have a very minimal ground contact.
    dirt t, Unkl Ian and King ford like this.
  17. greybeard360
    greybeard360
    I am still trying to figure out the "adjust the journals" part.
    If it turns with plugs out, still turns with one plug in until it comes up on compression stroke it sounds like you need something longer than a 3/8 ratchet, a better battery and a big bowl of spinache.
    clem, Unkl Ian and saltflats like this.
  18. sunbeam
    sunbeam
    I told you 19 to 1 is to much compression. Check voltage at the starter when cranking
    Beanscoot likes this.
  19. Mr48chev
    Quick test is when you try to crank it does one or the other of you cables or battery posts get hot real quick? That would mean a resistance in the system. That could be at the connection at the battery post, where the ends go on the cable, too small a cable to handle the load ( I don't give a rip what the self styled experts say bigger cables equal better current flow as you are moving amps not volts, the volts push the amps. ) Bad contact at the starter end of the cable or where the ground connects to the engine.
  20. swade41
    swade41
    from Buffalo,NY
    Are you sure the plugs aren't to long, causing the rotation to stop once the piston runs into the plug ?
    1934coupe and Unkl Ian like this.
  21. Unkl Ian
    Unkl Ian
    Everything is "good", except that it isn't.
  22. Unkl Ian
    Unkl Ian
    What the hell is a "stage 2 cam ?
    Bandit Billy likes this.
  23. Let's break down some before we get to three pages of SWAG's
    Do you mean it's very hard to turn over under compression, using a breaker bar...or (big difference here) it stops dead with the first plug? Second? Third? and so on and so forth?
    rpm56 likes this.
  24. dragey
    dragey
    from Brisbane
    Tappets need adjusting maybe. The new cam might have thrown your tappet gap out so the exhaust duration is lagged not letting the chamber decompress on time. Had the problem on a Toyota once nearly blew the head off when I cranked it over. Rookie mistake.
    Nailhead A-V8 likes this.
  25. Bleach
    Bleach
    I could still turn over a 22:1 compression ratio engine by hand using a socket wrench. It was a diesel.
    Truckdoctor Andy and Unkl Ian like this.
  26. Tank65
    Tank65
    from Arizona
    Yes, very hard to turn over under compression, with a breaker bar or with a high torque starter.
  27. That's it then...It's got Sealed Power "racing rings" from a catalog;)
  28. Tank65
    Tank65
    from Arizona
    Engine is on stand, battery is hooked directly to starter and ground to engine.
  29. BJR
    BJR
    Have you looked at the plugs to see if the pistons are hitting them?
  30. Bandit Billy
    Bandit Billy
    upgrade from Stage 1, no where's near the Stage 3 which is also referred to as a 3/4 race.
    dvsz28, Tank65 and 26Troadster like this.
