Customs 1949 chevy interior build
Discussion in 'The Hokey Ass Message Board' started by andrew namminga, Jul 7, 2016.
  1. andrew namminga
    andrew namminga
    IMG_1084.JPG IMG_1086.JPG IMAG2214.jpg Here is the build for my 1949 chevy interior and dash update..
    When I got the car it was ok... but not that good..
    Had the old S-10 plastic column and ok wheel... 1990's gauges... and a ****py stereo,...
    Also the seats were tired and electric windows were sad..
    Guys, i know white seats look great when the cars in the garage... and at the show... but the rest of the time they ****!!
    olscrounger likes this.
  2. andrew namminga
    andrew namminga
    IMG_0007.JPG IMG_0001.JPG IMG_0002.JPG IMG_0003.JPG IMG_0004.JPG IMG_0005.JPG IMG_0006.JPG IMG_0007.JPG IMG_0008.JPG IMG_0009.JPG IMG_0010.JPG IMG_0011.JPG IMG_0012.JPG IMG_0015.JPG IMG_0019.JPG IMG_0020.JPG IMG_0022.JPG IMG_0023.JPG IMG_0024.JPG IMG_0025.JPG IMG_0006.JPG so first step...
    Remove it all!!!
  3. andrew namminga
    andrew namminga
    Then i noticed that the floor had some really bad patches..... done with fibergl*** and tin foil..
    so that got removed too.. IMG_0017.JPG IMG_0034.JPG IMG_0035.JPG IMG_0040.JPG
  4. andrew namminga
    andrew namminga
    IMG_0007.JPG IMG_0035.JPG Took every wire out of the car...
  5. andrew namminga
    andrew namminga
    I sent the seats out to get recovered in Black....
    while I was waiting,,, i replaced all of brake components...
    Simple mustang @ stuff from speedway... easy to use and works great..
    I do think i should have gone to the bigger 11in disk.... these are the 9.5in... and they stop the car.... but a bit more grab would have been nice..
    I did end up swapping the booster... IMG_0013.JPG IMG_0046.JPG ... but that a different post..
  6. andrew namminga
    andrew namminga
    next step.... spend 500$ on dyno mat...
    then slap it everywhere.... IMG_0029.JPG IMG_0036.JPG IMG_0051.JPG IMG_0054.JPG
    Also, coated the bare metal with Por15 first... to prevent any long term rust...
  7. andrew namminga
    andrew namminga
    NExt......
    Wire her up!!
    I used a cool Fuse panel, from Centech...
    It had just what i needed is a super small box... and was pretty much plug and play...
    Bring your own wires...
    http://www.centechwire.com/PDP-1B-High-Tech-Fuse-Panel-PDP-1B.htm
    Mounted the brain in the truck, next to the battery and started pulling wires...
    it took a day to run the wires... then another day to terminate them... but its well worth it,... the wiring is clean, color coded, labeled... and hidden!!
  8. andrew namminga
    andrew namminga
    Really making progress now!!!
    I got all new gauges fro So cal speed shop...
    My dad helped me out and wired up the dash as a sub ***embly... It came out perfect!! I wish i took more pictures of it on the bench,..
    Also added a new steering column from IDIDIT, and a 40 ford wheel..
    Ranchero59 likes this.
  9. andrew namminga
    andrew namminga
    missed some steps....
    but added carpets, headliner, trim, chrome, sweat, tears,.. blood.... and ended up with this,
    This was my first full interior... and i learned a lot..
    _DSC5040.jpg _DSC5041.jpg _DSC5044.jpg _DSC5049.jpg IMG_2104.JPG IMG_2105.JPG IMG_2106.JPG IMG_2107.JPG IMG_2108.JPG IMG_2109.JPG IMG_2110.JPG
    little red 50 and Surfcityrocker like this.
  10. andrew namminga
    andrew namminga
    did a photo shoot...
    haha Photo credit to my buddy Rian! _DSC5020.jpg _DSC5010.jpg _DSC5015.jpg _DSC5020.jpg _DSC5025.jpg _DSC5027.jpg _DSC5031.jpg _DSC5033.jpg _DSC5038.jpg _DSC5040.jpg _DSC5041.jpg _DSC5044.jpg _DSC5049.jpg _DSC5053.jpg _DSC5057.jpg _DSC5058.jpg _DSC5062.jpg
  11. Dave Downs
    Dave Downs
    from S.E. Penna
    Tell me about your seats; rebuild the old ones? - I need some ideas
    And hoe bad was it doing the headliner?
  12. andrew namminga
    andrew namminga
    Hey Dave,
    the Rears are the original frames, but the fronts were from some 80's or 90's truck... maybe the same S-10 the steering came from..
    I had them recovered with the same vinyl Mercedes uses, so they feel really nice!!
    The headline was a total pain!
    I both the kit, from Ecklers... and its cut pretty close.... but the install is really tricky!
    the kit comes long.... so its a balance between gluing, stapling and t*******... There is only one point that u cut it short and had to make a little patch panel./.
    I also through out my back in the processes.... the odd angles and lots of in a and out of the car beat me up..
    but its way better then the 3- 5k quotes i got... all in the headliner cost me 300$ in material... so ill take that any day!
    I also found that the thinker the materiel the better for the headliner... The stuff i used was very thing and i felt like it would tear..
    Check out the link to this build... just started the post so i will keep it updated...
  13. Devin
    Devin
    from Napa, CA
    Nice Chevy! That gauge pod is pretty slick. Did you make that? Reminds me of spider eyes.
  14. andrew namminga
    andrew namminga
    it was with the car... I found some similar on sold only websites...
    its basically a disk with holes in it...
    the back is really cool and wired up as its own ***embly so it comes off with one connector!!
  15. Surfcityrocker
    Surfcityrocker
    from Austria
  16. motoandy
    motoandy
    from MB, SC
    Very cool!! Love it
  17. pat59
    pat59
    Nice job! where did ya get the steering column mount?
  18. andrew namminga
    andrew namminga
    Part of the column mount is stock chevy,, then i CNC'ed the bottom half and adapter.. i think i have one more if your interested.
  19. Jim636
    Jim636
    from Wyandotte
    Love the look of the dash.......
  20. i.rant
    i.rant
    Damn nice ride you have there.
  21. andrew namminga
    andrew namminga
    Started a new project... remove and update drivetrain..
    Picked up a 383 from blueprint and tore out the full drivetraina md brake system.. aslo adding back the sniper efi from holley
    little red 50 likes this.
  22. andrew namminga
    andrew namminga
  23. FrankenRodz
    FrankenRodz
    Really Nice Job! Well done!
  24. andrew namminga
    andrew namminga
  25. andrew namminga
    andrew namminga
    Busted knuckles club!
    Made good progress today.. motors is in and new trans corssmember 75% done.
    Cleaned out the gas take and added a fuel return for the efi system.
    Also rerouted a bunch of wiring to make it look gooooood
  26. andrew namminga
    andrew namminga
    [​IMG] [​IMG][​IMG]
    Brake system in!
    Efi in!
    Steering in!
    Still more to goo... save jt for next weekend!
  27. Fat47
    Fat47
    Great work. Where is the MC/booster/Proportioning valve from? What size is the Booster?
  28. andrew namminga
    andrew namminga
    The booster is the 7inch... hopefully has enough power! The mount kit and valve is all from speedway.. Its a new kit they have specifically for the 49 chevy... it went it very easily!
  29. Fat47
    Fat47
    Thanks. Hope you are making more progress. Great build so far.
  30. andrew namminga
    andrew namminga
    Much more done yesterday! Started the exhaust
    Found some flow master bends that fit and going with 26in cherry bombs!
    Summit basic h pipe balancer kit..
    Fitting nice and tidy!!
    [​IMG][​IMG][​IMG][​IMG][​IMG]
    Visited St Archers brewery! Brought home some fresh beers!! Helped make the job easier!
