Projects My first Av8
Discussion in 'Traditional Hot Rods' started by deluxester, Jul 4, 2018.
  1. WTF really
    WTF really
    Chop chop get to it. Lol
  2. deluxester
    deluxester
    E89E4040-D5C9-4900-AEE7-4EDBC135906E.jpeg 799AF2FB-1D83-491E-A303-3FC7A69F4C42.jpeg 04DDA13E-FDFF-41BD-A96B-AB5AFC24747B.jpeg 582DABD4-00EA-4578-A170-72C1536A1D4A.jpeg More work on the steering..
    I shortened the steering column and the housing as well. I also had to torch the pedal ***embly a bit to gain some clearance. (before shot)
    1947knuck and dwollam like this.
  3. deluxester
    deluxester
    EDCD7029-C64D-4F0B-942F-3710F406A60E.jpeg AD4B2D6C-4F0E-457B-917F-D3B29474211D.jpeg
    The clutch lever was also shortened in order to line up with the pedal ***embly. The other one at the top of the photo was too short. I’m not sure what either of these are from, though. I just went to a parts pile and selected one that looked like it would work.
    ‘39 transmission
    1947knuck, barrnone50, j-jock and 2 others like this.
  4. deluxester
    deluxester
    6C1A7F09-292B-441A-B079-C89ACB6BA6FE.jpeg 76D9E2BC-0C25-4EF2-9270-571BBA97F7EF.jpeg Then dis***embled the frame... Again. ..To clean up and paint.
    1947knuck, dwollam and WTF really like this.
  5. deluxester
    deluxester
    I caught my five-year-old daughter pretending to drive to Disneyland
    1947knuck, rpm56, Jet96 and 15 others like this.
  6. lodaddyo
    lodaddyo
    Priceless! Great picture.
    I am about the same stage in my build as well. I have all my frame and suspension ready to paint. Hopefully shoot it next week. Keep up the good work!
    deluxester likes this.
  7. deluxester
    deluxester
    Sealed up that torque tube and installed the front bearing and speedometer drive
  8. deluxester
    deluxester
    F348E7C4-AD47-42BA-B79C-A76500EA08EB.jpeg 51AA5723-0494-41D3-911F-13A2C4EEC157.jpeg With the ch***is re***embled, and the body back on the frame, I started on a straight forward homemade harness using cloth wire whenever practical. I’m not a fan of the modern nylon crimps, but I figured I could get away with it if it was hidden under the bench seat. No one will ever know, (unless they’ve read this thread)
    I decided to hide most of the components beneath the seat frame to help keep the engine compartment clean looking.
    Oh, and I made some plywood floors.
  9. deluxester
    deluxester
    I opened up the holes on the stock instrument panel to accommodate some better gauges. I also made an adapter for a cool shift knob that I found.
    98E94501-0EDD-46F6-AC6F-DA18514F564D.jpeg DBB1A593-174E-4C4A-92D1-7D7BEAB44C51.jpeg 3A501172-C7F8-4BBD-8892-9565EF71D446.jpeg
  10. deluxester
    deluxester
    613CDAF9-19C1-4C13-9559-518DE11A2858.jpeg 47BE1850-D0C9-487B-BBE6-36DE8DC3DCC6.jpeg 83BB9575-DFF0-44B7-B249-63E198157B3B.jpeg 3D6A616F-6C48-48CF-9E75-DA817DE0D8E7.jpeg Just before putting the body back onto the frame, I also plumbed up some new copper alloy brake lines
    And I had replaced that reverse eye model A spring for a Model T profile to lower the rear a bit more
  11. deluxester
    deluxester
    E34CC06E-C785-4407-90F5-AF21DFD1BF1A.jpeg B1EF81C7-0CEC-4759-B1A0-20B37F5692F7.jpeg 1EEAEEF4-760D-4405-83F7-C35842498BCD.jpeg I decided to go purest.. 100% traditional by installing a modified 80’s minivan bench seat just like they did after World War II ! A local hamb member gave me this minivan seat but it was a little too big for the roadster ****pit. So, I cut it down to fit the stock seat riser and reinstalled the cushion springs.
  12. deluxester
    deluxester
    And made some ugly brackets to support the back of the same minivan bench seat.
    1947knuck likes this.
  13. deluxester
    deluxester
    I torched up some F1 shock mounts to tighten up the curve at the bottom
    And then I shortened them quite a bit to accomodate pete/jakes type tube shocks.
    6A8E16D6-36D1-471C-974E-4DA1E8DA3184.jpeg D5FD6D3F-5793-4594-9F28-FEE809582474.jpeg
  14. deluxester
    deluxester
    To avoid having my neigbors call the police, I had the exhaust welded in so that I could begin breaking-in that new Schneider cam and tuning carbs.
    This is pretty much how the car looks today. I’ll keep everyone posted on my progress moving forward!
    bymanr, 1947knuck, Adam M. and 12 others like this.
  15. WTF really
    WTF really
    I just ordered one of them rear springs from speedway I'm hoping it drops about 3 inches.
  16. brEad
    brEad
    Great build, glad you started a thread. Subscribed.
  17. Roadsterholic
    Roadsterholic
    Great build, engineering and workmanship!
  18. lodaddyo
    lodaddyo
    Did you end up stepping up the rear frame to lower it? Looks great
  19. Fitnessguy
    Fitnessguy
    Looks like you're having fun and doing a great job along the way. Nice work!
  20. Squablow
    Squablow
    Really excellent work so far and good choice of parts to use. Looking forward to seeing more.
  21. deluxester
    deluxester
    No, I didn’t have to cut the frame or Z. I used a model T, reverse eye spring for the rear.
    dwollam and lodaddyo like this.
  22. deluxester
    deluxester
    Thanks everyone for the compliments and feedback. Looking forward to driving it very soon!
    Stogy likes this.
  23. WTF really
    WTF really
    This is awesome news to me. That's where I want mine to sit. Thanks for the info.
    deluxester and lodaddyo like this.
  24. lodaddyo
    lodaddyo
    I agree. I didnt z mine im running a stock model t rear spring with 3 leaves removed and it doesnt sit as low as that. Where did you get the spring?
  25. deluxester
    deluxester
    That’s exactly what I did. I removed a few leaves from a stock model A. Then I rebuilt the spring pack with a reversed eye main. Still not low enough, I used a Model T Spring that fits a model A crossmember. I’ll see if I can find a link. But I still removed a few leaves from the new spring pack. I’ll take some better photos when I get home later this week. Not sure how many I pulled.
  26. lodaddyo
    lodaddyo
    lol, that's Exactly what I did. its not a speedway medium arch spring is it?
  27. deluxester
    deluxester
  28. deluxester
    deluxester
    No, it is a model T profile, so the car ends up sitting quite a bit lower
    dwollam and 100% Matt like this.
  29. WTF really
    WTF really
    I just bought one of these last month. Not even close to ready for it. Just collecting parts. I'll be watching to see how to get this ride height. Thanks guys.
  30. Mart
    Mart
    You're doing a very nice job, this is almost a "text book" build. One (hopefully constructive) comment: It's not a good idea to support the rear of the car by the axle shafts (when the hubs are off) there is a seal inside there and the axle will push against the upper side of the seal.
    Other than that I look forward to seeing more great progress.
    Mart.
