Projects Haulin' ass in fiberglass
Discussion in 'The Hokey Ass Message Board' started by Mr T body, Nov 1, 2017.
  1. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    Doesn't need a LOT of gusset, just properly sized and placed. Made up a harness mounting bracket so I can get a better idea where all the reinforcement goes. Not a lot of progress, but any time you can break out the oxy/acetylene and mig in the same weekend is a good time. :D
  2. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
  3. loudbang
    Ford Blue oval colored belts how appropriate :)
    1947knuck likes this.
  4. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    and tape on the steering column...
  5. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    It has eyes! Not the most stylish arrangement and placement, but there really is only one need for these...... to help be street legal.
  6. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    I found an aluminum Hamburger 10qt full pan so that'll be on it's way soon. Glad I found it because I wasn't thrilled with the current offerings and Hamburger doesn't make a full drag pan for a BBF any longer.
  7. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    Oil pan made it here. Old Hamburger full drag pan that's no longer made. A couple modifications need to be made...... clear the starter and relocate the dipstick to the right front. Dipstick now is right behind the left collector so it's useless. pan1.jpg
  8. saltflats
    saltflats
    from Missouri
    They trying to tell you something? :D
  9. loudbang
    Love the engraved COBRA JET on the heads. :)
  10. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    They're "SUPER" Cobra Jets ;)
    barrnone50 and loudbang like this.
  11. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    I would expect this on a hotrodder forum, but aren't discontinued parts "traditional" on the HAMB?
    JGYS:D
    barrnone50, loudbang and saltflats like this.
  12. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    Summer's over, temps are dropping and it's getting to be build time again. After the last month or so of household repair/remodeling after the washer level sensor ****ped out, this can go back on the front burner. We'll be back in the country the 2nd week of Oct so that means I'm mapping out the projects. Since the drive train is in it now it's a convenient time to make up short pipes off the collectors that'll go out the side under the frame rail. No room for mufflers so it might be a tad loud. I'll make a "street" setup later but these'll be fine for testing.
    The body's coming off so the firewall can be gl***ed in and the frame reinforcements welded in.
    It's almost fun time kids.........:)
    AHotRod, saltflats and tfeverfred like this.
  13. saltflats
    saltflats
    from Missouri
    Good deal. Get back to work, I need my go fast car project fix. :D
  14. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    Body's still not off, but doing what I can until it comes off. The upper corners of the trunk opening need to be modified so I can use the Quick Latches on the trunk lid. Might be wasting my time, but am trying using melamine panels as forms for the mods. Easy to form and a glue gun works well for joining panels. Only thing I haven't figured out is what I can use as a release agent when the time comes. Oh, and did I say what an absolutely ****PY fibergl*** body this is? Don't know who made it but they should be shot.
    Doesn't make sense yet, but hang in there.....
  15. AHotRod
    AHotRod
    Your doing a great job !
  16. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    Thanks. I really need to get organized and start busting *** on this thing. With as little available space as I have, I spend more time planning the work than actually doing it.
    loudbang and AHotRod like this.
  17. AHotRod
    AHotRod
    I have built roadsters in 1 car garages because I spent the time and effort to design the layout to maximize the floor space, hang everything possible from the ceiling and walls. When my project is in pieces, our living room becomes a storage / staging area. God Blessed me with a major "Car Girl" for a wife, she loves our Hot Rods!
  18. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    This might make it a bit clearer (or maybe not). The forms will be waxed then screwed in place and (hopefully) release relatively easily when I'm done laying it up. I'm cutting more out of the existing corners than the pics in the previous post show so I get a nicer corner and vertical surfaces out of it.
    droppedstepside, AHotRod and loudbang like this.
  19. Hombre
    Hombre
    If I may offer a suggestion, Nothing wrong with that form it should work very well. Never used melamine but it should work OK. You need to paint the form, I believe, and I mean several coats just to make it as smooth as possible. I always use Johnson Floor Wax as a release agent, not saying its the best thing to use but it works well. And you need to wax it a lot like 5 or more coats of wax. I have settled on five because it also seems to work, I know for sure that three is not enough, and five just seems to work for me.
  20. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    You can't see it in the pics, but the joints are sanded with 2000 grit so very smooth (though it doesn't look it). I've been playing with carnuba paste (had it around) as well as glaze. I'm trying to steer clear of liquids as I don't know how the composite backing will react (swelling?). The paste seems to seal the composite edge well, but it's going to take numerous coats.
    It won't accept paint because it won't adhere to the melamine, so we'll see how well the wax works alone. The 'gl*** will be primed and sanded so a perfect finish isn't necessary. Hoping for the best but do expect issues.
    Only one way to find out.......
    OFT, Hombre and loudbang like this.
  21. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    One kinda cool thing I read about today and tried tonight was heating and bending fibergl***. I was skeptical, but the upper drip rail was tilted up and needed to be flat so the corner would come out right. Took the heat gun to the edge, heated it and bent it into shape. Really kind of amazing.
  22. dumprat
    dumprat
    from b.c.
    We used to use Palmolive dish soap for release agent when doing plaster casting. Paint it on and let it dry. Nothing sticks to it and some hot water makes it go away.
    Soft on your hands too.......
    alanp561, Mr T body and loudbang like this.
  23. patterg2003
    patterg2003
    I could not find Johnsons floor wax that is a good release that I have used for making fibergl*** parts ions ago. I had to make a fibergl*** nose bowl for our homebuilt airplane. I made a male mock up that was the exact shape that was needed. Bondo was used to smooth out any spots on the mock up form to get the shape smooth. The mockup was coated it with Meguiars Cl***ic Gold carnuba wax for mold release. I made a female mold off the mock up and it released perfectly. I used the car wax as a fibergl*** to fibergl*** mold release as well. Getting the pcs smooth makes it better for cleanup afterwards as less roughness to hold the wax. Clean the area when done with a couple good washes with a good silicone and wax remover to get it off the car that way the wax does not spread around to interfere with the paint process. I always go over a car a couple times with the silicone and wax remover to make sure the car is clean before starting any paint work.
    Mr T body and Hombre like this.
  24. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    Did you wax over the bondo or paint over it then wax?
  25. HOTRODPRIMER
    HOTRODPRIMER
    When I had my gl*** roadster I would say it might not be real but it sure is real fun. HRP
    raven likes this.
  26. scottie
    scottie
    over here in the UK i use brown packing tape, resin doesnt stick to it
    AHotRod likes this.
  27. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    This car really only has to be one thing......scary fast.
  28. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    Interesting. Only down side I can think of is the edge of the tape leaving a line. Also read about people using Pam spray as a mold release.
  29. AHotRod
    AHotRod
    I made some modifications to my homemade 'gl*** Model A Coupe body recently and used Turtle Wax as my release agent, worked perfectly
  30. DDDenny
    I used K-Y jelly once!
