Projects 1955 Cadillac Sedan Build
Discussion in 'The Hokey Ass Message Board' started by HermanMunster, Mar 9, 2017.
  1. gatz
    gatz
    lookin' good
    nice craftsmanship
    HermanMunster and Bowtie Coupe like this.
  2. chstitans42
    chstitans42
    It looks even better since you have the smaller 54-55 bumper ends/exhaust ports. In my opinion it wouldn't look as good with the wider 56 ones that I have. Awesome work
    Bowtie Coupe likes this.
  3. HermanMunster
    HermanMunster
    Thanks again all for the kind words. It’s been slow progress, but progress none the less [​IMG][​IMG][​IMG]
  4. mike bowling
    mike bowling
    Real nice- that FLOWS................
  5. philo426
    philo426
    Looks great!I hope he used the same gauge steel as original for durability's sake!
  6. HermanMunster
    HermanMunster
    I started watching some random YouTube videos and came across a guy named Ron Covell doing some amazing metal working. I saw him build a fender from scratch using a wooden die and used that concept for the last piece, it worked great! And took maybe 5 minutes to beat out the rough shape. Might have to redo some of the other side
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    kidcampbell71, Stogy, treb11 and 7 others like this.
  7. mike bowling
    mike bowling
    Fits in perfect with the exhaust outlets
    kidcampbell71 and Bowtie Coupe like this.
  8. HermanMunster
    HermanMunster
    We pulled the Caddy and trailer out to the front of the house to take some pictures. it's pretty awesome to see the car out of the garage and to step back and look at the progress. It's going to be fun taking the trailer out when they're both done
    [​IMG][​IMG]
  9. Rolling Daddy
    Rolling Daddy
  10. bobss396
    bobss396
    Packard lights are purely amazing. Really cleans up the back of the car.
    kidcampbell71 and chryslerfan55 like this.
  11. HermanMunster
    HermanMunster
    Thanks fellas! I’ve been making progress, but mainly around the air suspension. Sounds like that stuff is a gray area to post though
  12. wraymen
    wraymen
    Just found this. Nice work! Nothing like a 50s Cadillac.
  13. Peanut 1959
    Peanut 1959
    Yeah, off-topic (OT) suspension/drivetrain/electrical mods are sure to get you a stern talking-to!
    [emoji12]
    Keep up the good work!
  14. HermanMunster
    HermanMunster
  15. HermanMunster
    HermanMunster
    Haven't been able to make much progress but I did finally mount the rear shocks, paint everything, and now I'm getting the trunk back together
    [​IMG][​IMG]
  16. HermanMunster
    HermanMunster
    Been stripping paint and getting ready for some body work. Small rust patches to do here and there [​IMG]
  17. bobss396
    bobss396
    Good progress, this is a great build!
    HermanMunster likes this.
  18. The car is greatthose taillights fit perfectly
    Should of left the factory like that !
  19. HermanMunster
    HermanMunster
    Finally got the body sealed in epoxy primer
  20. sdluck
    sdluck
  21. HermanMunster
    HermanMunster
    Progress! All 4 doors in primer and sifted through the boxes of stuff to find the door hinges/strikers/handles etc. Got the Packard taillights back from the chrome shop too. Got them done at Speed and sport chrome plating in Houston, it was a great experience. They came out freakin awesome despite their ****py condition. They had to do 3 copper dips on one of them haha totally worth it though.
    The huskies approve
  22. Peanut 1959
    Peanut 1959
    Lookin' sharp! Congrats on the progress. Sorry if I forgot, but did you already reveal your paint plan?
  23. HermanMunster
    HermanMunster
    Thanks man! I actually just painted some test panels a few weeks ago. I’ll be doing the original mist green on bottom, and a dark green flake top. [​IMG]
    The one in the middle is a silver metallic base, a .015” green flake in an interstage clear, and then 9 coats of a green candy. I didn’t quite get the flake ratio right yet. The one on the right is the flake on top. And the left is just the silver base. I like the middle one
  24. Knghtcadi
    Knghtcadi
    In my experience a silver mini and medium flake size mix under the kandy will make it sparkle way more and give it more depth. Just my 2 cents [emoji1303]
  25. HermanMunster
    HermanMunster
    I may have mentioned that I’m building this car to drive off at my wedding in. The wedding is coming up on March 30th, so I’ve decided not to try and paint it before so that I have a realistic chance of making the wedding. But I’ve finished the last of the body work and have it all in primer at least
    [​IMG][​IMG]
    I’m running a 700r4 behind the original 331, so I was able to mock it up and get the transmission crossmember modified to fit. Had to lengthen my driveshaft as well. [​IMG]
    [​IMG][​IMG]
  26. HermanMunster
    HermanMunster
    Decided to retrofit a dual circuit master cylinder, while still maintaining stock pedal geometry. Worked out pretty well utilizing stock master cylinder bolt holes and making a bracket out of 1/4" plate.
    Modified a bolt to connect original pedal hardware to new MC
    And I'll be able to use a remote reservoir for both front and back.
    Also upgraded to disks in the front. I used a kit from caddy daddy. It worked out very well, it's a nice complete kit that uses a spacer on the spindle to clear the rotor of the caliper braket, and fits inside the stock wheels.
  27. bobss396
    bobss396
    Some progress... looking like a car now...
  28. HermanMunster
    HermanMunster
    15 days to go until the wedding and I still haven't cranked the engine over, I'm getting a little nervous haha
    [​IMG][​IMG][​IMG]
    kidcampbell71, 40LUV, BigO and 4 others like this.
  29. Peanut 1959
    Peanut 1959
    Just keep swimming, just keep swimming...!
  30. Apenaut
    Apenaut
    Was watching Gearz and saw you and the '55!
