Projects My new ride - finally on the road
Discussion in 'Traditional Hot Rods' started by grdra1, Jul 9, 2018.
  1. grdra1
    grdra1
    I have just purchased this 5 window coupe here in Aus and will be re engineering to suit Aust street rod regulations for registration. Just wondering if anyone knows anything about this car. The chap I purchased it from new nothing of its history. Has SBC, 3 speed auto, 9inch rear, any info / history would be greatly appreciated. Glen P2200271.JPG P2200277.JPG P2200273.JPG P2200280.JPG P2200283.JPG P2200282.JPG
  2. aaggie
    aaggie
    Looks like a basic honest Hot Rod. Not a lot of bling but a fun ride. The smoke out of the exhaust is probably the typical SBC valve stem seals. Run a compression check and they are easy to change especially on a roadster.
    I read an old copy of the Australian rules book and it seemed like everything done from stock had to be signed off by a licensed Engineer.
    deadbeat and lothiandon1940 like this.
  3. lothiandon1940
    lothiandon1940
    That smoke might just be from the cold morning weather. Aren't those guys in Winter now down-under?
  4. Vic Walter
    Vic Walter
    Very cool ride. I am working on one similar. any chance you could post some close up pictures of the gas fill, hoses and tank ?
    Thanks
  5. grdra1
    grdra1
    That's correct just started car on cold day, but there was a smell of oil in the air. No smoke or vapor once warm. A licenced engineer has to sign off on the build, regulations are quite strict. I plan to convert to RHD, have to use a collapsible steering column, strengthen ch***is as no K member, plate ch***is over rear, strengthen all suspension mount points, burst proof door locks, intrusion bars in doors, retractable seat belts, cycle guards, window gl*** etc etc. The list goes on, but I have downloaded all regulations / guidelines and will build to suit. I plan to keep the car basically the same style, I'm not a fan of bling. I also plan to build a killer engine / trans combo to install for some drag racing duties then return to street trim for cruising. Watch this space for the build. Glen
  6. grdra1
    grdra1
    No probs, I will post many pics as I strip the car down for re-engineering ( I hope I don't rebuild as I tend to get carried away - check out my Topolino ). Glen
    lothiandon1940 likes this.
  7. Jalopy Joker
    Jalopy Joker
    Congrats - sounds like you have a solid plan for it
  8. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Man, no history but sure is a nice looking little rig. Enjoy it!
  9. brady1929
    brady1929
    Cool coupe. Congrats.
  10. cederholm
    cederholm
    Great looking car! What needs to be done for you to be able to register it?
    ~ Carl
  11. pigfluxer
    pigfluxer
    Nice car, looking forward to your build.
  12. RonBulmer
    RonBulmer
  13. rob-redm
    rob-redm
    congrats, can't help ya on history.. but looks like you have great ride there, make your own history with it !
    Ranchero59 likes this.
  14. EVL401
    EVL401
  15. jfh1959
    jfh1959
    Very nice,hope you have fun with it!
  16. catdad49
    catdad49
    Great looking piece, sounds like a bunch of ''reengineering'.
    nevrdun and OLSKOOL57 like this.
  17. grdra1
    grdra1
    Started build now, I have purchased new RHD vega steering box, collapsible steering column, new steering wheel, mini starter and a 32 grille shell so far. Also have ordered a so-cal deluxe front disc brake kit and new steering arms. Started stripping car, will convert to RHD first, set up steering etc. Will need to pull body off later to strengthen ch***is and I will re-mount the 9 inch rear with a triangle 4 link setup and add disc brakes. Check out pics, more to come, Glen P3020289.JPG P3020293.JPG P3020294.JPG P3020290.JPG
  18. grdra1
    grdra1
    Thanks for advice, will investigate. Glen
  19. Deuces
    Deuces
    Yes! Ask me how I know..... :(
  20. Deuces
    Deuces
    Without looking at the weather in N.S.W., I'd say it's probably around 55°F there this time of year.... ;)
    I'll go look.....:rolleyes:
    I was close...... 51° in Sydney..
    I lived farther south in the lake illawarra district.. probably a bit cooler....
  21. grdra1
    grdra1
    Some more pics, started mounting column, will purchase a new brake booster and move to right side, will make trans mount removable once I strengthen ch***is, removed exhaust and will need to fabricate a new system when 4 link completed. Also started removing interior etc as I will take body of soon. Will make a bolt in roll bar / hoop to mount seat belts and also make a small hoop under dash to mount steering column. Glen P3030297.JPG P3040301.JPG P3040303.JPG P3040306.JPG P3030299.JPG P3030300.JPG
  22. tub1
    tub1
    from tasmania
    x38 is on the money with them steering boxes , get your self a good old holden one
  23. Avgas
    Avgas
    Steel body, original ch***is, just rock up to rego & see how it goes, I would
  24. grdra1
    grdra1
    I had a engineer look at car before purchase, he stated that if ch***is could be proven to be original, car could obtain full Vic rego. If I cannot prove ch***is is original and is a reproduction then it must go on street rod limited rego. How can I determine if ch***is is original, what do I look for, there is a ch***is number on ch***is Left side on bottom of rail between engine mount and A pillar..Engineer stated it is possibly a reproduction ch***is. I will go with a HQ steering box as per recent advice but will ask those who sold me the vega box why they are selling inferior steering boxes to Aust market and ask them to explain there rational. Thanks for all comments, negative or otherwise, I am willing to listen to others as long as there is a rational behind advice. I plan to make ch***is comply with street rod guidelines and be safe to drive for all my family members to use on a daily basis ( wife and 2 adult children ). I appreciate all comments / advice - either positive or negative. Glen
  25. grdra1
    grdra1
    Furthermore it was always my intention to convert car to RHD and to add 4 wheel disc brakes, regardless of registration requirements. As previously mentioned I plan to build a high horsepower engine for this car. Glen
  26. grdra1
    grdra1
    I understand that they will try to to defend themselves, but if the product is inferior then they need to put the safety of all road users before profits. Thanks again for advice. Glen.
  27. belair
    belair
    Nice car, I like your choice of steering wheel. As for your search for a rationale for the sellers, greed is # 1, ignorance is # 2.
  28. 41rodderz
    41rodderz
    from Oregon
    Congrats. Way :cool: car.
  29. Sactownog
    Sactownog
    from SAN DIEGO
    were the frame rails put into the cab?
  30. grdra1
    grdra1
    A few pics of latest progress, I have purchased some roll cage tube and plan to make a weld in unit that will tie to the ch***is at the rear, I will mount cage as close to the body as I can yet still have body lift of over it. I would prefer a weld in unit to help strengthen ch***is for drag racing purposes. I can make it bolt in but only if I have to. I plan to start making cage and having it tacked in before taking body off. I will at this stage keep the shocks mounted in the same way but just strengthen area with fish plates and have cage attach this area. As previously mentioned the rear will have a triangulated 4 link setup. Ch***is will receive a new beefier K member and I will make trans mount removable and add a tailshaft loop. P3120307.JPG P3120312.JPG P3120316.JPG P3120318.JPG P3120320.JPG P3120321.JPG Glen
