Technical Cylinder head Removal
Discussion in 'The Hokey Ass Message Board' started by The Hyena, Jul 7, 2018.
  1. greybeard360
    greybeard360
    I am thinking the rocker shaft bolts are also the upper row of head bolts... Pull the rocker shaft off.
  2. The Hyena
    The Hyena
    The rocker bolts dont hold anything as a said i took off the other side.
    also who said its not the original head ? and why do you say that ??
    ps. it is upside down at the moment haha and nothing
  3. Hydraulic jack.
    The Hyena likes this.
  4. alchemy
    alchemy
    The head is a totally different color than the block (head is rust and red, block is blue). Caddy didn't paint them separately.
  5. Deuces
    Deuces
    You remove that head yet????
  6. ididntdoit1960
    ididntdoit1960
    from Western MA
    I have a feeling this is going to end up like the guy that couldnt open the door on his pickup.......come to think of it, whatever happened with that? LOL
    VANDENPLAS, King ford and Deuces like this.
  7. gimpyshotrods
    gimpyshotrods
    I ***ume he got stuck inside, and died.
  8. X-cpe
    X-cpe
    If you have a porta-power go between the valley and the top of an intake port and apply a little up pressure ("a little" being the key). Then tap around the head with a plastic, br*** or deadblow hammer. The problem with rubber mallets is the absorb too much of the force you are trying to apply. If you don't have a porta-power you can construct a couple of jacking devices using all thread, a McGyvered arm to reach onto the ports and some nuts to apply up pressure. If bumping it with a hammer doesn't pop it loose then you need the thinnest putty knife you can find. Sharpen one side (because longways it will flex too much when hit) and try driving it into the gasket gap starting on the intake side. Keep moving around. Once it starts to move add more up pressure and go to a thicker, sturdier putty knife. Eventually you will create a gap big enough for a screwdriver or pry bar. The problem with chisels and screwdrivers is their wedge is too blunt when you are trying to go into a space that is measured in thousandths. Finesse, even with a hammer, and patience are your best friends.
  9. Deuces
    Deuces
    I like the idea of using jack screws!!!!...... We make our own at work by using 1/2-13 thread stock and nuts... They work great for lining up a fixture plate on a tomb stone for a horizontal machining center... ;)
  10. Have you invited a second person over to look at the problem? Some times were are too close to something.
    Charlie Stephens
    powrshftr and dogwalkin like this.
  11. KJSR
    KJSR
    from Utah
    Those bolts look a little long not to go into the block........
  12. LM14
    LM14
    from Iowa
    4th of July is just past. Might be ale to pick up a bunch of M-80's on the cheap. Load the cylinders and set them off! 45-50 should be about the right number. Be sure to put a couple head bolts in loosely for safety reasons.....
    SPark
    egads likes this.
  13. King ford
    King ford
    from 08302
    Crickets......
  14. farmalldan
    farmalldan
    from Duncan, OK
    My research confirms what Charlie is telling you. Cad 429 has 17 head bolts per side with the top 4 doing double duty as rocker shaft bolts. My question is: how the hell did you get the other head off without removing the rocker shaft?
    Farmalldan
    Should have acknowledged KJSR's contribution. My apologies to him.
    powrshftr and The Hyena like this.
  15. 56sedandelivery
    56sedandelivery
    I also see an "overheat ****on" on the end of the head; those are placed by rebuilders for warranty purposes. They don't warranty overheating damage. I am Butch/56sedandelivery.
  16. Jesse Bailey
    Jesse Bailey
    Sure looks like the rocker shaft bolts go clear through.
  17. 1946caddy
    1946caddy
    from washington
    Get a O/A torch and neutralize the flame, snub it out and fill each cylinder with the gas mixture and put plugs back in with a few head bolts, use remote starter from down the block and turn over engine. :D
    VANDENPLAS likes this.
  18. 1946caddy
    1946caddy
    from washington
  19. Also , the rocker bolts line up with holes in the head gasket. Imagine that.
    In answer to your question ..He didn't. We're being spun here..He bought somebody else's nightmare. indexrc.jpg
  20. The Hyena
    The Hyena
    YES !!! you guys were all correct rocker bolts were still tightened, GOD im retarded haha
    im learning thanks guys i promise I WILL have more really stupid questions, but hey i guess that how im gonna learn haha
  21. Deuces
    Deuces
    Your welcome!.... :D:rolleyes:
