Projects Scratch built "Gasser" 57 Vette
Discussion in 'The Hokey Ass Message Board' started by Utahvette, Jun 11, 2018.
  1. Steve Norton
    Steve Norton
    Might do that have quite a few pics that I saved. Will be at meltdowns to see how it runs
  2. jimdillon
    jimdillon
    Great see you there.
  3. moparnate
    moparnate
    from minnesota
    super cool vette, you've got skills!!
  4. Utahvette
    Utahvette
    For the steering I used a later model (63-82)Corvette steering box. It's smallish and fit nicely in the space available(and I had one).It did take longer to build the header on that side to clear the box. One small problem came up for the drag link. The oil pan was in the way of a straight shot. I built a dropped drag link from a old sway bar. I didn't have a way to bend a piece of tube but I could heat and bend a solid bar. Works great and looks good. DSCN2167[1].JPG DSCN2177[2].JPG
  5. Utahvette
    Utahvette
    Since I was using a T-5 and bellhousing out of a Camaro I thought I would try the Camaro hydraulic clutch set up also. I didn't have any of the original Corvette stuff and to buy it would cost hundreds of dollars. The Camaro stuff was about a hundred bucks for everything. With a reinforcement panel on the inside of the firewall the master cylinder mated up with the firewall nicely and the rod length was just right to the pedal. I mounted the remote reservoir by the brake cylinder. It fit really well. The pedal effort is so light you can easily push the clutch in with your hand. I made a heat shield for the header to prevent possible melting of the plastic hose. DSCN2183[1].JPG DSCN2185[1].JPG
  6. Steve Norton
    Steve Norton
    Great job. Well thought out. Do you still have the car
    kidcampbell71, Deuces and loudbang like this.
  7. Utahvette
    Utahvette
    Yep, going on 11 years now. Probably time for a change.
  8. Utahvette
    Utahvette
    For a radiator I decided to go with a griffin type aluminum. Once again choosing light weight and efficient. Corvettes use an angled radiator support originally and I wanted to mount the radiator vertical and closer to the engine for better cooling so I built my own . This also allowed me use a simpler fan shroud. DSCN2186[1].JPG DSCN2187[1].JPG
  9. Steve Norton
    Steve Norton
    One of the nicest g***er I have seen love the name
  10. nice overflow can!
    Deuces, Bowtie Coupe and loudbang like this.
  11. mkebaird
    mkebaird
    Before I installed a hydraulic clutch I basically blew out the firewall on mine. Ended up sandwiching the firewall between two pieces of aluminum plate. I used an aftermarket clutch mc - it's buried behind the brake mc. Also used the stock core support and built a fibergl*** shroud, works great!
  12. GASSERBOB
    GASSERBOB
    from USA
    You did a beautiful job. You should be very proud. Bob..............
  13. Utahvette
    Utahvette
    One of the final things I needed for this car was a working speedometer. I only had a chrome speedo frame and a lens with the numbers on it . I used a piece of black plastic with a piece of pin-striping tape to create the look of a real speedometer and needle. That looked good for a while but I wanted a functional speedo. I got on E-Bay and found a cheap GPS speedo. All it needs is 12 volts to work. It was $26. It works great! I cut a hole in the plastic and used some 3M tape to stick it in place. Comparing it to my GPS app on my phone it's dead on. It's pretty slick. No messing with gears or cables. DSCN2261[1].JPG DSCN2262[1].JPG DSCN2267[1].JPG
  14. 26Troadster
    26Troadster
    that is one fine looking machine.
    loudbang and 31hotrodguy like this.
  15. AmishMike
    AmishMike
    Son doesn’t want me to use digital gauges but love what u did
  16. Utahvette
    Utahvette
    Pretty cool , my 57 is featured in the latest edition of Traditional Rod And Kulture Magazine. I think these are the nicest pictures taken of this car to date . Just Beautiful. And I'm a published author now too. I wrote the entire article and it doesn't ****!(too badly) It was kinda weird writing about myself in "third person" style, "Rex did this, Rex did that" but it came out pretty well. I think it's somewhat unusual to write your own story for one of these but I guess the photographer figured I knew more about the car than he did so why not. They could have edited the **** out of it but it went to print just as I wrote it. I'm flattered.:) CIMG1345.JPG CIMG1346.JPG CIMG1347.JPG CIMG1348.JPG
  17. porkshop
    porkshop
    from Clovis Ca
    Congrats..........
    kidcampbell71 and Deuces like this.
  18. Steve Norton
    Steve Norton
    What size are your rear wheels and tires
    Deuces likes this.
  19. VonWegener
    VonWegener
    Congrats. Well deserved. To me building a custom from parts the "Restorers" have given up on is the most noble part of our hobby. I am glad your efforts are noticed.
  20. nice....
    Deuces likes this.
  21. Don Moyer
    Don Moyer
    Fun read, will be starting on mine this winter!
    elgringo71 and Deuces like this.
  22. swade41
    swade41
    from Buffalo,NY
    Congratulations and it's still the only car I've seen where the ch***is is built on an upside car...lol
    OahuEli, Deuces, Thor1 and 2 others like this.
  23. Don Martin
    Don Martin
    from West Tenn
    Love it! I've wanted one for years. This didn't help that. Guess the old 57 sedan will have to do.
  24. Utahvette
    Utahvette
    Took a few shots the other night. Thought this one turned out pretty good. CIMG2502.JPG
    Oldstrk, 40two, Kan Kustom and 18 others like this.
  25. Deuces
    Deuces
    Very cool!... :)
  26. Great photo!
    Sorry, I had to. It was screaming for it.
    40two, chryslerfan55, Chucky and 5 others like this.
  27. Utahvette
    Utahvette
    I rounded up a couple of friends the other day and attended a local car show. My buddies ratty 56 stole the show. IMG_4991.jpg IMG_4992.jpg IMG_4995.jpg IMG_4996.jpg IMG_4997.jpg IMG_4999.jpg IMG_5006.jpg IMG_5007.jpg
    swade41, Shadow Creek, 40two and 17 others like this.
  28. Just Gary
    Just Gary
    Awesome Vette!:cool:
    Tell us about the interior- seats, doors, floor, etc.
    I can just make out period-appropriate diamond pleats in the magazine article. Got any bigger better pics?
    Thor1, chryslerfan55 and guthriesmith like this.
  29. elgringo71
    elgringo71
    @Utahvette, I can see why the ratty 56 stole the show. You never see a corvette like that anymore on the road, let alone at a show. If that car could talk it would be interesting to here the stories that it would tell. In a way it’s a time machine that takes you back to a different place and time.
