Technical Liquid Filled Fuel Pressure Gauge
Discussion in 'Traditional Hot Rods' started by mwhistle, Jul 12, 2018.
  1. mwhistle
    mwhistle
    from sacramento
    There have been a number of posts regarding the inaccuracies of liquid filled fuel pressure gauges. Apparently, unlike the non liquid pressure gauges, the liquid filled ones are very sensitive to atmospheric temperature and show inaccurate readings (like no pressure despite the engine running perfectly well). I've used both types of gauges and can attest to the problem. All that said, I noticed that Summit Racing advertises the Aeromotive fuel pressure gauge which is liquid filled, but includes a relief valve to ensure accuracy. These Aeromotive gauges are twice a costly ($47) as the usual ones from Summit or Earls, etc. Does anyone have any experience with these particular Aeromotive fuel pressure gauges as it relates to their accuracy. I don't mind spending the money if they are actually accurate under all driving conditions. Thank you.
  2. Bandit Billy
    Bandit Billy
    As previously posted, the fluid is there to stabilize the needle from vibration but it also keeps them form reading correctly at low pressure as I found out. Someone on here replaced the glyceride fluid with brake fluid if I remember correctly and it functioned better. I replaced it with a non liquid gauge with a 0 to 10 pound dial for a bit more accuracy dialing in my low pressure for my 97's. It isn't much to look at but it works very well.
  3. Hotrodmyk
    Hotrodmyk
    I too had a liquid filled (Marshall) gauge that would not read when the engine was hot. I replaced it with a non-filled gauge and it works perfectly.
  4. Deuces
    Deuces
    Those liquid filled gauges are pretty much made for off road trucks and buggies... Or if you have a car with solid engine mounts and a very lumpy camshaft.....:confused::rolleyes:
    Fitnessguy likes this.
  5. farmalldan
    farmalldan
    from Duncan, OK
    We used thousands of liquid filled gauges during my professional career with no problems. Of course, we opened the case vents per instructions after installation. You guys didn't overlook that, did you?
  6. The idea behind the liquid filled gauges is that they do not fail as easily due to vibration. There is an obvious remedy to the problem, actually two depending on how high tech you want to be. The high tech solution is to get an electric and mount the gauge on the firewall. The low tech solution is to set your fuel pressure then remove the gauge and cap the T.
    Here is something to think about, you seldom set your fuel pressure once you get the pressure set. If you took the car to a mechanic and had him set the fuel pressure he would use his gauge that he took from his toolbox, set the pressure and put the gauge back in his toolbox.
  7. Bandit Billy
    Bandit Billy
    ^^^^I am considering doing this cuz I don't like the look of that gauge on my flathead
    Chavezk21 and porknbeaner like this.
  8. rjones35
    rjones35
    I've got one of the aeromotive ones. It does work. I noticed the pressure was all over the place hot vs. cold when I first got it, THEN I remembered to use the pressure relief thing.
  9. rjones35
    rjones35
    Not a great pic, but you can see it. Not a big deal to release the pressure valve, and I've only had to do it once, when I first set everything up. The gauge, and their regulator, have been rock solid.
    porknbeaner likes this.
  10. 31 Chopped Coupe
    31 Chopped Coupe
    I can relate to this subject, I bought a K&N low pressure electric fuel pump for my flathead. I used a Safety Racing glycerine filled gauge at the fuel block on the firewall and have yet to see the needle rise up off the peg, even when I dial up the pressure on the regulator. I'm going to contact Speedway and ask for a refund for the gauge and try for a better quality.
  11. This is probably not the best time to mention this but when adjusting pressure you really want the regulator and gauge as close to the needle valve as possible. Sometime logistics over rides that but that is the best way to get a legitimate reading.
    @rjones35 that is a nice clean setup. :cool:
    rjones35 likes this.
  12. rjones35
    rjones35
    Thanks!!
  13. mwhistle
    mwhistle
    from sacramento
    There were no instructions that came in the box with either my Marshall or Earl's fuel pressure gauge. Two responders mentioned a gauge pressure relief valve. I don't see anything like that on either of my gauges. (Maybe I don't know what I'm looking for.) Can someone explain how one relieves the gauge pressure so that it reads accurately as described above by some of the HAMB responders? Thank you.
  14. Boneyard51
    Boneyard51
    We used liquid filled gauges in the Fire service with no problems, other than an occasional leak. Those were compound gauges that read vacuum and 600 pounds pressure. Might not be a liquid problem, maybe just a gauge problem. Ours were vented. There’s a lot of **** being produced across the pond now.
    Bones
  15. Sheep Dip
    Sheep Dip
    from Central Ca
    chevy57dude and kadillackid like this.
  16. mwhistle
    mwhistle
    from sacramento
    Sheep Dip, Thank you very much for picture and instruction. Even if I'm careful not to remove the plug as you suggest, won't some liquid seep out?
  17. Bandit Billy
    Bandit Billy
  18. rjones35
    rjones35
    The Aeromotive one has an actual metal valve you pull up to release then push back down. Not sure about the others, other than the rubber plug that seals it.
  19. mwhistle
    mwhistle
    from sacramento
    rjones35, Thank you very much for the explanation re: the Aeromotive gauge and relief valve operation.
  20. deathrowdave
    deathrowdave
    from NKy
    Used liquid filled gauges at work for 35 years . There are many ways around this as venting the gauge , a transducer mounted at the pressure point and a dry gauge where needed . An orifice in tap to slow the flow down will stop the wiggle in a dry gauge also and last , a pigtail curl in the tube or tap ahead of the gauge to slow flow will stop the wiggle . Vent it and forget it is best
  21. When do you vent these? straight after installation? What does the venting do, anyway? These look like glycerin filled Bourdon tube gauges, I am trying to understand why they need to vented. I always thought that rubber bung was to top-up the glycerine level. Are these supposed to have an air-gap at the top, or are they filled up completely? Thanks for the wisdom in advance!
  22. rjones35
    rjones35
    I'm definitely not the expert, but my understanding is when they get hot the fluid expands, builds up pressure and throws the reading off. I could be wrong. When the engine/fuel is hot, thats when to vent. I would ***ume that if they were totally full with no air gap, they would either explode, or have to be really sealed with no way for the pressure to escape,which I guess would cause other problems.
