Projects DRAG SNAKE "Vintage Terror!"
Discussion in 'The Hokey Ass Message Board' started by Deuced Up!, Oct 13, 2017.
  1. Deuced Up!
    Deuced Up!
    Yep...been there!
    Sent from my SM-G930V using The H.A.M.B. mobile app
  2. Deuced Up!
    Deuced Up!
    What I learned from the HAMB this week! Those floor pans and trans tunnel top cap are all cut from a 4x8 sheet of 3/8" thick aluminium.
    I got the sheet for free but it has just about wore me slick trying to cut it. First I bought a very expensive "metal" cutting blade for my skil saw. It promised to cut 1000 times longer than its compe***or. How ever even after soaping it and the cut path up, it only went about 9 inches.
    Next I tried a cut off blade in my grinder. It cut but wore itself down to nothing in less than 24 inches. Finally I settled on the jig saw with a fine tooth blade and cutting oil. It was very slow but at least we were cutting.
    Yesterday I searched the HAMB for cutting aluminum. Now I had heard about turning saw blades backwards but that was not the advice I received. They said get a carbide skill saw blade with at least 40 teeth if not more. I found one at Lowes that had 60.
    I really did not expect it to work but we shot the cut path with WD-40 and as instructed I started very slowly. The crazy thing cut like ****er...I mean it!
    kiwijeff, Swamp Rat 4, Sancho and 6 others like this.
  3. loudbang, Gammz and Deuced Up! like this.
  4. Deuced Up!
    Deuced Up!
    All of the final mold over runs are trimmed, including the grill opening. I am going to put an egg crate style grill in it (great article from popular hot rodding on building one and it was copied here on the HAMB as well.
    But the grill, to make them doable by shade tree guys like me, are simply meant to mount on the inside up against the opening. I am good with that. So last night we took the grill opening all the way flat (removing the mold over runs plus the flat area that would have been left to mount an original grill INSIDE the opening.
    I love the look! No hurry now to build that grill...lol
  5. Deuced Up!
    Deuced Up!
    Last night we also cut the extra slab sides on the front wheel opening. Spending some time this morning cleaning up by hand. Looking at lots of photos of the original cars I think they are very close...close enough for now anyway!
  6. oldolds
    oldolds
    What is the red stuff on the body? You are not using old fashioned lacquer spot putty? The new 2 part type work so much nicer.
  7. Deuced Up!
    Deuced Up!
    I use Dynalight filler. Really good stuff. I normally try very hard to really mix well and get rid of any air before applying it. But right there I got four little bubbles which of course didn't show up until the final sand etc. So yes your are correct...just a small amount of spot puddy before the epoxy primer...
  8. squirrel
    be sure you don't use any old type products on your period correct Cobra :)
    (it's a fine line...between doing a good job, and doing it how was done back then)
  9. Deuced Up!
    Deuced Up!
    Epoxy Primer is spraying pretty nice first couple of pieces are complete. Nice to see it any color other than gel coat white...
  10. Deuced Up!
    Deuced Up!
  11. DDDenny
    Now you're talk'n, 110% better.
    Still holding out hope you'll paint the top a different color than the body color.
  12. Deuced Up!
    Deuced Up!
    Well I am going to call it a night. After we got the body and pieces in primer (and just before dark) I turned what was left of my attention to the hardtop. It still did not have the mold over run cut out of the rear windows. So I spent about a half hour shaping them etc.
    I also applied reinforced filler to all the failed hinge holes...lol.
  13. Deuced Up!
    Deuced Up!
    Well you are going to get your wish there DDD! At least for the Meltdown Drags anyway. The epoxy primer is sort of a darker shade of gray...the car looks fairly ominous just sitting on the table. LOL
    Dad said a few minutes ago we should do the top in satin black for now...which I just happen to have!
    Actually I have been thinking about a black vinyl covering??? We shall see.
  14. Deuced Up!
    Deuced Up!
    Man am I really tired this morning. I am glad to be back at work where I can get a little rest! LOL
  15. Deuced Up!
    Deuced Up!
    Got the body back on just before sun down...digging the stance with the pumped up coil overs. Busy night tomorrow wirh the finishing touches then off to the Meltdowns!
  16. So *****in'!
    loudbang, Deuced Up! and enloe like this.
  17. Doctorterry
    Doctorterry
    Deuced Up! and loudbang like this.
  18. loudbang
    Dam we got us a SUPER SNAKE NOW. :)
  19. Deuced Up!
    Deuced Up!
    So here is little jewel. My Dad is notorious for not smiling in photos. It drives my Mom up the wall and has as long as I can remember. Yesterday while working on the hood my daughter said hey smile and I will take a photo. Dad struck this pose.
    After seeing the photo my Mother was furious that he had such an amazing smile. She said I just don't understand it. I said it is easy. That is a photo of him working on a Cobra...normally he is just standing next to you! LMAO. She didn't think that was funny.
    kiwijeff, LM14, enloe and 10 others like this.
  20. flt-blk
    flt-blk
    from IL
    looking good, any shots with the top on? or do I have to wait to see it at Meltdown?
  21. ROADSTER1927
    ROADSTER1927
    Does that make him a smiling Hoodlum? LOL Gary:p
  22. Deuced Up!
    Deuced Up!
    Give me time...heck I haven't even seen it with the roof on yet...LMAO! maybe tonight....
    chryslerfan55, Sancho and loudbang like this.
  23. Deuced Up!
    Deuced Up!
  24. DDDenny
  25. Nostrebor
    Nostrebor
  26. Deuced Up!
    Deuced Up!
  27. Deuced Up!
    Deuced Up!
    That might be a Cobra under there...lol
    Made it to the Meltdowns...long drive!
  28. shivasdad
    shivasdad
    from Texas
    Looking really mean just like it is. Watching.
  29. The suspense is killing me. Is that a 2020 Corvette under there?
