Hot Rods Who's running a Caddy in their Hot Rod ??
Discussion in 'The Hokey Ass Message Board' started by DeLuxe 32, Jul 9, 2018.
  1. Roothawg
    Roothawg
    I'm still trying to find a comparable aftermarket rod for my 390.
    DeLuxe 32 likes this.
  2. rexrogers
    rexrogers
    I did stretch the frame almost 2" to get the motor to fit without cutting the firewall. The owner of the car needs all the foot well room we can get.
    Rex Rogers
    The Forge
    Loveland, Co
  3. DeLuxe 32
    DeLuxe 32
    Incase you guys haven't seen, Matt from Gear Drive Headers is casting some 4 x 2, and 471 intakes for Caddy's !!!!!!!!!!
    warbird1 likes this.
  4. mikhett
    mikhett
    from jackson nj
    You TOO???
    jakespeed63 likes this.
  5. oldsman41
    oldsman41
    I had a 331 in a 37 ford pickup but somebody wanted it real bad and i sold it. I’m thinking of building another one after i finish my model a
    DeLuxe 32 and F&J like this.
  6. rod1
    rod1
    I don't see the blower manifolds for Cads....
  7. DeLuxe 32
    DeLuxe 32
    rexrogers, rod1 and jakespeed63 like this.
  8. jakespeed63
    jakespeed63
    Very tidy install
    Good job on A/C retrofit
  9. Hank37
    Hank37
    My 37 Ford with a 331 block bored and stroked to 400 cubes . Crankshaft Co. stroker kit , 12:1 compression , Crane ultra hi-rpm drag cam , Smith adjustable push rods , 57 tri carb. manifold , 57 heads ported and polished , Jacobs ignition , Scheifer 11" clutch , Muncie 4 speed wide ratio, Olds. 3.42 rear . First intake was a Horne 4 carb. second was a Hilborn Injection , third tri -power . IMG_2215.JPG
    winduptoy and DeLuxe 32 like this.
  10. DeLuxe 32
    DeLuxe 32
