Hot Rods Which brand aluminum 9" Ford case should I buy
Discussion in 'The Hokey Ass Message Board' started by papastrk, Jul 16, 2018.
  1. papastrk
    papastrk
    I am thinking of buying an aluminum third member case for a street rod build, but know nothing about what brands are out there. Can some of you comment on what I should consider. I want a good quality case, but at a reasonable price. Thanks in advance
  2. Torana68
    Torana68
    from Australia
    Strange , I have one looks to be cast and machined nicely. There are many Chinese ones about that look as good but the strange one isn’t that much $$$ I didn’t want any odd machining errors but seems to be a lot of people using the ones from China.
    Fordors likes this.
  3. DDDenny
    Yup
    Strange
    Right after I got this one they came out with one for high horsepower apps, link below.
    Bare cases are at bottom of page.
    https://www.strangeengineering.net/hd-pro-center-sections-and-cases/
  4. krylon32
    krylon32
    from Nebraska
    I've sold a few from John's with no problems to date. I have no idea if he makes his own or gets them someplace else?
  5. papastrk
    papastrk
    I don't think I would need a through bolt HP case. I'm not familiar with "John's". Just trying to cut down on sprung weight and improve on looks.
  6. swade41
    swade41
    from Buffalo,NY
  7. Torana68
    Torana68
    from Australia
  8. mgtstumpy
    mgtstumpy
    Is it for aesthetics? Currie, Strange, Yukon, MW or Moser are known brands, bolt through (I note you don't want this style) or not, daytona or OEM pinion? Lots of variables and prices; 28, 31 or ?? spline, open or not. RWHP would be a determining factor and usage and then cost. The bitterness of poor quality remains long after the sweetness of low price is forgotten
  9. papastrk
    papastrk
    The aluminum case is something I have wanted for a good while. I want to change gear ratio, so now is my best chance to justify the added expense. Through bolt is not a top priority. Stock ring and pinion, open carrier, 28 spline will be used. Bitterness of poor quality is well noted. Looking for quality at an affordable price here. "Made in USA" would be great. "Made in China" and a quality part I can live with. "Made in China" and a piece of junk I can't!
  10. southcross2631
    southcross2631
    Sounds like you could have your stock case powder coated aluminum color and save the money.
    If you are that concerned about changing it for looks , put a quick change in it. Much better for your ego. More show points.
    I always use Strange engineering parts.
    INVISIBLEKID likes this.
  11. Gregg Pellicer
    Gregg Pellicer
    The aluminium case will not change sprung rate. It will change unsprung weight. I doubt you will be able to feel any differance in handleing at all. As far as looks yes the alloy one looks better but who can see it unless you get on knees and look under car. It's your car so do what you want not trying to critisize. I can just think of alot of other places to spend money
  12. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    I was going to go aluminum for the 9" in the '32, but wound up swapping in the "N" case instead. I probably still will as it makes swapping to 35 spline axles easier later. The weight savings wouldn't make much difference on the street, but 15 lbs is 15 lbs!
  13. papastrk
    papastrk
    Greg is correct. The aluminum case lessens unsprung weight. The rear coilovers have such limited travel, I thought reducing weight here might give them better control.
  14. LM14
    LM14
    from Iowa
  15. papastrk
    papastrk
    This little upgrade looks to be turning into a money pit. The center section is just the beginning of the expenses, lol. Once again, Greg gave good advice. I think I will stay with what I have a while longer. Thanks to all for posting.
  16. Gray Ford
    Gray Ford
    from Illinois
    I too agree with Greg... WAY back when I was building my first fat fender car, I was REAL concerned about how the ch***is was going to look ...An older guy told me ..." Someone is going to be on their knees to see it ...That puts them in the proper position to receive your answer to any criticism "...
  17. papastrk
    papastrk
    Lol! That'l do.
  18. DDDenny
    I wasn't trying to impress anyone but myself, they will have to lift my trunk floor to fully appreciate what this cost.
    Have an all aluminum engine too, you don't even want to ask what it cost.
    Mr T body likes this.
  19. yellow dog
    yellow dog
    from san diego
    Just to quantify I have two Moser aluminum units w/ aluminum spools both at 52.5#. My iron open unit
    weighs 70.5#. With a 200# (housing, center section, 1/2 shocks/suspension) and another 100# tires and wheels
    an 18# saving may not be worth it for street
  20. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    Oddly enough, it costs less to build an aluminum pumpkin than a factory nodular. And yes, they look cool too.....
  21. DDDenny
    I had an N case in my race car about 1976/77, bought it used, it had one or two stripped cap bolt holes, so I drilled/tapped all four oversizese then made new bolts and sent it to Jack Crisman and had it machined for big bearings, that was not cheap.
    oj likes this.
  22. glrbird
    glrbird
    This one came from Summit.
  23. DDDenny
    House brand?
  24. 19Eddy30
    19Eddy30
    from VA
    I run Mark Williams Enterprises Modular 9" 40 spline
    Blown Altered,
    Strange also good manufacture
    Just use a stock ford case ,paint correct aluminum color as mentioned before ,
    Reliable and strong , You will be Happy
  25. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    The cross-sections at the failed holes is thin, but something way beyond "normal" made the case and pinion pilot bearing do that.
  26. oj
    oj
    I am a Strange dealer, if you decide to go with them shoot me a PM and I'll give you HAMB special pricing below mailorder etc.
  27. papastrk
    papastrk
    Wow! Now that had to be pretty violent when it let go! What type of pinion support was in this case?
