Projects My first Av8
Discussion in 'Traditional Hot Rods' started by deluxester, Jul 4, 2018.
  1. deluxester
    deluxester
    Thank you for the instruction - that makes clear sense. I’ll definitely remember that... maybe I should have been less concerned about scratching the paint on the dif housing or used a rag or something.
  2. Really nice work, this is going to be a very cool car.
    deluxester likes this.
  3. deluxester
    deluxester
    Thanks
  4. deluxester
    deluxester
    Ok, Back home today and took a few more photos to better convey the current ride height. I think my last photo was a bit deceptive on account of the low camera angle so hopefully these will help. Again, this is the aftermarket model T spring, advertised here, with a few leaves removed and a reverse eye main:
    https://www.jalopyjournal.com/forum...-in-american-made.961937/page-2#post-12637172
    Also, Great build on your av8 roadster! Beautiful job, your work has been a great reference for much of my own build. Thanks for sharing!
    A64E1493-C2F2-4930-849E-03EA86BC3D07.jpeg D7A1BEBF-8964-48F4-ACF5-16976B6CCAC1.jpeg 86FD2EEB-46C6-48A1-AC4C-0FB27C75FD43.jpeg 13BED347-2FD0-4F17-9BE4-6AACB44F4E45.jpeg
    1947knuck, dwollam, brEad and 5 others like this.
  5. deluxester
    deluxester
    Thanks for the comments! I can’t wait til its finished
  6. deluxester
    deluxester
    Thank you!
  7. deluxester
    deluxester
    For the moment, the hose vents air straight out the breather tube (same tube that is venting air back into the crankcase), and connects to the intake manifold. I have not yet decided to drill a hole into the bottom of the manifold to hide completely, or to make a hard copper vacuum line to replace that rubber hose. But either way I need to 86 that ugly hose once I confirm the system is actually working.
    1947knuck, dwollam and brEad like this.
  8. WTF really
    WTF really
    Thanks that picture from the back under the car shows a lot on where I should be when I'm ready.
    48fordnut and deluxester like this.
  9. lodaddyo
    lodaddyo
    Thanks for the pics. The way it sits is perfect. How does it ride? Any bottoming out?
    Thanks for the compliments! glad it could help you. Hopefully ill get my ch***is ***embled soon.
  10. louisb
    louisb
    Dude this build is awesome. Thanks for sharing.
    ---louis
  11. deluxester
    deluxester
    I have no idea how it rides, but I can’t wait to find out. I have a su****ion that the front end will bottom out before the rear, and that I’ll find myself re-inserting leaves to compensate. I’ll keep you posted!
  12. deluxester
    deluxester
    Anxious to get my car on the road, I started on a straight forward headlight bar today.
    I started with a slightly mangled modelA crossbar, cut each end off and straightened, to my abilities, the center section.
    I made some new holes along the frame rails after settling on an ideal location. I want the option of pulling the ***embly off when(if)ever I participate in some of the several exposition races turning up across the country. I only recently discovered these awesome step drillbits.
    Bolted in and torched to an acceptable radius. Next step is to cut and prep the ends for welding on that cross bar.
  13. deluxester
    deluxester
    Thank you!
  14. deluxester
    deluxester
    Lightbar finished.
    16AD7AC9-A43E-4BCC-8A13-BAE852E260B1.jpeg 5F56ED85-36CD-4829-8786-03C8BFFF6FBA.jpeg BBB5F001-C1A0-4CE4-A82B-A9298262D8FD.jpeg
    Always surprised to see where Henry decided to leave a stamp.
  15. deluxester
    deluxester
    I made a bracket for a brake light switch I picked up from the local parts store. I’ll weld in a makeshift dog-plate to press against the switch.
    AE6D8FF7-98E8-427F-8F74-5CDE94147604.jpeg 667C5A8B-FFA4-460E-ABC5-3E7C505D856E.jpeg AEA442A2-828C-4A1C-9B5B-84D3C2F5A5C9.jpeg C8DFB92A-3CD8-484D-B5F5-C9E90BFF6948.jpeg
  16. deluxester
    deluxester
    Louis, thanks again. I just found your build thread.. great work on that 29! I’ll be following along as you finish it.
  17. lodaddyo
    lodaddyo
    Nice job on the brake switch. Those little pressure switches dont work worth a damn sometimes
  18. goldmountain
    goldmountain
  19. Tim
    Tim
    from KCMO
    Love it, looking to be a fun hot rod!
  20. deluxester
    deluxester
    Good point. I located a waterproof one on line. I’ll likely replace it
    brEad likes this.
  21. deluxester
    deluxester
    Thanks Tim, I’ve been enjoying your tudor build! And digging on the fendered look lately.
    Tim likes this.
  22. deluxester
    deluxester
    Thanks! What will you use for a switch on your build?
  23. Great build, lovely planning, fabricating, and welding. Subscribed.
    Bob
  24. lodaddyo
    lodaddyo
    Well i was gonna use one of those ****py pressure switches, but now im just gonna steal your idea:D:D:D
  25. 100% Matt
    100% Matt
    Shameless self promotion but I have lifetime guaranteed brake light switches in the cl***ified [emoji4]
  26. x77matt
    x77matt
    AWESOME build! Great detail- thanks for sharing!
    Matt
  27. deluxester
    deluxester
    Matt, thanks! I’ve been following your progress on the ‘32. Excellent work!
  28. deluxester
    deluxester
    My thread is your thread.
    ...and thanks again for your help w the rear spring.
    100% Matt likes this.
  29. fortynut
    fortynut
    Your balance of function and form speaks pure hot rod to me. And, man, this one is going to be one hell of a time warp. You're going to make old men, who were in the hobby, cry like babies, because they'll be saying,"It's just like old times!" Wail brother! You've got it on the downhill slide. Going to be one sweet little ride. Only thing I can see, is like Baskerville said of P-Wood's Speedster. "The welding is too nice." But, I ain't complaining. Wish I could do it that well. Good Luck on it, and here's a warning about daughters; some grow up to drive the wheels off stuff. They watch and learn. Get my drift.
    brEad and deluxester like this.
  30. HellsHotRods
    HellsHotRods
    I disagree - there is nothing worse than jamming a stud into a corroded hole that wasn't cleaned only to start a crack that would create a worse problem. Everyone I know runs taps into block threads to clean em up and then uses high temp thread sealant to prevent problems.
