Projects 26 T Roadster Pick Up build Thread
Discussion in 'The Hokey Ass Message Board' started by Blue One, Mar 27, 2010.
  1. Tim
    Tim
    from KCMO
    Ok that’s pretty cool
    loudbang and Blue One like this.
  2. trollst
    trollst
    Looks ****en A man, so nice you'll be scared to drive it.
  3. The 39 guy
    The 39 guy
    Now that there is some good thinking! way out of the box and looks great!
  4. brEad
    brEad
    You always take it to the next level! Thanks for sharing that tip.
  5. Six Ball
    Six Ball
    from Nevada
    Looks really nice. The Ford engineers couldn't have done better, but wait they didn't!
  6. brad2v
    brad2v
    Pretty slick Larry
  7. tfeverfred
    tfeverfred
    Go, man! GO!
    Blue One likes this.
  8. Blue One
    Blue One
    from Alberta
    I have 2 different thermostat housings, one that tips the outlet off to the side and one that points up.
    Neither one is ideal, the one that points up is the best however it’s not far to the rad and it’s pointing at the sky :D
    So, I cut it apart and I’m changing it so I’ll be able to have a decent top rad hose.
    Stay tuned :D
    6469F5DC-5548-44AF-8413-8BD2454CFD52.jpeg 9AF1A7FB-B9C0-4F0D-B014-18370113DFCB.jpeg
  9. Blue One
    Blue One
    from Alberta
    So, here’s how a seemingly simple modification of one little piece can take up the better part of 2 plus days :D
    Cutting apart a casting made in the 50s was interesting to say the least.
    Welding it back together with nickel rod was challenging given that it constantly wanted to crack :mad:
    After 4 tries I finally got it done.
    The final solution was nickel rod welding followed by a slow cool wrapped in insulation and then a sandblast followed by a coating of handi flux for a coating of silver brazing alloy to fill in all the pits that kept coming up from the **** coming out of the old cast.
    Whew.
    Then I had to do something about the corroded byp*** hose tube connection.
    That involved removing it and tapping the hole out to 3/8 NPT and threading in one end of a br*** pipe ******.
    After all that I’ll at least be able to have a decent top rad hose.:cool:
    97FB0153-24B1-4414-A374-151BF6EA7762.jpeg B03541E6-D31D-46A7-A8EC-FB87AD92DCF7.jpeg 07302922-96B4-4CEE-B216-5B06A71CF1BC.jpeg
    The 39 guy, Tim, brEad and 11 others like this.
  10. atch
    atch
    Nicely done. Miles and miles above my skill level. However, it's comforting to know that I have friends capable of doing this so if I ever need it...
  11. Blue One
    Blue One
    from Alberta
    Distributor painted and installed.
    The 39 guy, brEad, loudbang and 7 others like this.
  12. bobbytnm
    bobbytnm
    Every time I check in on your build I am blown away!
    Thanks for taking the time to do***ent all of this. Great job
    Bobby
    loudbang, 26 T Ford RPU and Blue One like this.
  13. RodStRace
    RodStRace
    Yeah, when I saw you talking about modifying the neck, I knew that it would be a... booger.
    It would have been easier to 3D print a plastic replica of what you wanted and had it cast. Or fab it from scratch. Longer to final product, though.
    Looks completely 'at home' and part of the engine now, which is really the point, isn't it? Great job, as always!
  14. Blue One
    Blue One
    from Alberta
    Thanks, booger is putting it mildly :D
    I’ve done a lot of cast work over my career but this thing gave me fits.
    Who knows what they put in the casting but it was anything but quality :D
  15. Sparked
    Sparked
    Larry, The RPU is really coming along well. Washington blue is the perfect colour choice and the level of your attention to detail is top notch.
  16. Nicely done! That PCV system came out slick. Mine is set up the same way and it works great [emoji106][emoji106]
  17. Blue One
    Blue One
    from Alberta
    Installing my water pump pulley and the Mummert alternator mount has proven to be interesting because I had Tim Mcmaster put a custom harmonic balancer and pulley on the engine when he built it.
    That required a bit of adjustment of the water pump pulley mounting flange and also meant that I had to space the alternator mount a very small bit from the engine.
    I got a little technical in setting up my laser to confirm that I had the pulleys all lined up properly.
    Once I get it sorted out I’ll paint everything before I ***emble it for the final time.
    The 39 guy, Sparked, porkshop and 4 others like this.
  18. loudbang
    That is great. Who could have imagined even 20 years ago that a Hot Rodder would be using a laser building a Hot Rod. :)
    brad2v likes this.
  19. Blue One
    Blue One
    from Alberta
    I wrapped up the alternator installation, that Mummert alternator mount is really a nice piece.
    I painted the alternator just like the starter and I found that a handful of foam earplugs works well to plug up all the holes and keep paint out of the internals.
    A few trips to the parts store and I finally have the right size belt. :cool:
    A442A7FD-6B3D-4B23-AB04-91E656480EAC.jpeg 4AFEA99A-CE47-46D8-B4B6-43AEDEC4FBEB.jpeg BA464267-0556-44B3-86FA-538B74217E73.jpeg
  20. Larry,
    Looking awesome (as expected)!
    I think you need these! PM me if you’re interested.
    Allan
    VonKool13, loudbang, brEad and 2 others like this.
  21. Blue One
    Blue One
    from Alberta
    Thanks Al. I appreciate the offer, those are nice valve covers but I already have a pair of vintage Finned Edelbrock script covers waiting in the wings.
    C1671459-22AC-4139-8EA9-64DA1888B3CC.jpeg 942AB98D-7C4F-4BAF-9E5E-2BC618B0BEC6.jpeg
  22. 57 Fargo
    57 Fargo
    Looks awesome Larry, this and squirrel’s build are the top two on the H.A.M.B. in my opinion!
  23. tfeverfred
    tfeverfred
    I'm getting wood.:)
  24. Tim
    Tim
    from KCMO
    Ear plugs are a clever idea for “masking” the alternator. Looks like your getting pretty close
  25. Blue One
    Blue One
    from Alberta
    Yes I’m getting closer, all of the detail work takes up a lot of time.
  26. K13
    K13
    You don't say?:D
  27. Blue One
    Blue One
    from Alberta
    :D Yes Ian as you know well, hours and days go by and sometimes it’s hard to see the progress :D
    But it inches along ;)
  28. Blue One
    Blue One
    from Alberta
    I mounted the 1-5 psi Aeromotive fuel pressure regulator and then fabricated a bracket to mount the fuel log.
    Then I made the fuel line from the fuel pressure regulator up to the fuel log .
    Next will be the lines to the carbs.
    3BAAA939-38EA-49CB-9300-620266FD5E1D.jpeg B0B9D2A6-287F-4E9E-8932-FBD191A88BFD.jpeg 7346F4AA-D1BE-4EB4-9AFC-FE603E58CDFD.jpeg 02EB8420-AAD0-4A1D-BF65-22F378136DB2.jpeg View attachment 3979444 View attachment 3979445
    Foot, 32Dan, OFT and 9 others like this.
  29. Rice n Beans Garage
    Rice n Beans Garage
  30. loudbang
    Great looking bends.
    brad2v and Blue One like this.
