Who has a STRAIGHT 6 in your HotRod? Come On, stand up!
Discussion in 'The Hokey Ass Message Board' started by AHotRod, May 25, 2004.
  1. 6narow
    6narow
    Sorry Fordfltrucknut, I didn't think about your truck being a 4X.
    If it was 2WD it would've been easier to fit in your truck.
    fordf1trucknut likes this.
  2. jimcintan
    jimcintan
    6 w blower.jpg I have a little 235 in my. 51 five window.
  3. raprap
    raprap
    from Ohio
    Thanks. They are Repro's of the Stelling-Hellings Helmut type from the 50's. Tom Langdon @ Stovebolt sells them.
    classiccarjack and loudbang like this.
  4. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    That's pretty. Tell us about the blower setup. 6:71? Underdrive/overdrive? cfm's?
  5. raprap
    raprap
    from Ohio
    Looks to be 4-71. Nice job! Nice front snout. Is it hard to get the belts lined up correctly?
    Looks like an oil line is plumbed into it.
  6. 64 DODGE 440
    64 DODGE 440
    from so cal
    Actually, looks like the fuel line going into a finned aluminum filter with the red plastic line coming out to the fuel block on the firewall. Always loved the red lines.
    Work In Progress and loudbang like this.
  7. jimcin
    jimcin
    The 4-71 is running a 35 top and 32 lower drive gear for a 8.6:1 under drive. The 94's feed about 400 CFM and the engine had the compression reduced to 7.5:1. Running a 5 speed with 373 gears in the rear. The whole thing makes for a comfortable highway run with the ability to cruise at 65-70 mph in 5th at 22-2400 rpm. When I need to p*** 4th gear is right there. Haven't had it dyno'd yet because I'm still trying to sort out some of the inevitable little issues that come with any build.
    Dyno Dave, 6inarow, BradinNC and 4 others like this.
  8. 64 DODGE 440
    64 DODGE 440
    from so cal
    Great looking truck!
  9. Twisted6
    Twisted6
    Vary Sweet looking Ride.
  10. 6narow
    6narow
    jimcin,
    You reduced the 235's cr to 7.5? I thought that was a pretty standard ratio for those engines through most of their life.
  11. gimpyshotrods
    gimpyshotrods
    I got this:
    I have to gather a few more parts, and finish the floor work, and then I will put it in.
    200-inch, 9.5:1 compression, final generation head (with a ton of port work), custom cam grind, no carburetor.
  12. 6narow
    6narow
    Nice work, Gimpy!
    So that engine features TBI? Who's did you use?
    6narow
  13. StarDiero75
    StarDiero75
    Not a hot rod but it's a good old original 65 Ranchero with a 3 spd column. I got another 200 I'm gonna hop up and fit with 3 Holley 1904 gl*** bowl carbs. I'm thinking of either sticking that in a falcon, fairlane, Ranchero or a sleeper model A.
    6narow and mcnally351 like this.
  14. gimpyshotrods
    gimpyshotrods
    I went with a little outfit that goes by the name: General Motors.
    6narow and loudbang like this.
  15. gimpyshotrods
    gimpyshotrods
    You know the distributor issue, right?
    mcnally351 likes this.
  16. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    jimcin, Nice, well thought out plan.
    Gimp, What vehicle is your six going in?
  17. Six Ball
    Six Ball
    from Nevada
    Truckee is close. I hope to see your pickup someday. Our Inliner club is doing our annual show the first Saturday in June in Minden. : "Rappin; to Minden" Come spend the day with us. Lots of nice inline engines.
    Countn'Carbs and loudbang like this.
  18. gimpyshotrods
    gimpyshotrods
    1960 Falcon, backed up by a T56, followed closely behind by an 8.8. The transmission and rear end are already in the car. I have just a little more tidying up on the tunnel, and a few holes in the firewall to fill, and then it will go in.
    I went with a "non-traditional" engine management (has spark control, too) system because my cruising range sometimes includes 10,000-feet of elevation change, will often include both 80-mph freeway jaunts, and long runs of bumper-to-bumper traffic.
    This is my daily driver, so "set it and forget it" is the name-of-the-game.
  19. jimcintan
    jimcintan
    I think when I was researching it, the compression for a 60 truck 235 was 8.25 or 8.5
  20. jimcintan
    jimcintan
    I saw that advertised just the other day. I plan on going. Thanks. Grew up in Santa Cruz so I knew Rick Peterson who was one of the founders. Hope to meet you there.
  21. 6narow
    6narow
    Jim,
    There's a famous song about your home town.
    Thanks for the info on the 235 cr. I never knew it went over 8:1. All stats I've ever seen say 7.5:1.
    6narow
  22. Six Ball
    Six Ball
    from Nevada
    I'll be looking for you. Rick was a friend and we miss him. I spent a lot of time in Santa Cruz my self. Though I didn't live there.
  23. JDDial
    JDDial
    I have a 292 with an S10 5speed in my 36 Pontiac. It has dual Carter Webers and Langdon dual headers.
    stoveboltswede, 6narow and loudbang like this.
  24. HotRodPunk
    HotRodPunk
  25. HotRodPunk
    HotRodPunk
    I’ve got a 1952 jaguar engine in my model-a coupe
    Fingers, AHotRod and loudbang like this.
  26. THE FRENCHTOWN FLYER
    from FRENCHTOWN
  27. FrankenRodz
    FrankenRodz
    My '49 Chevy with a '56 235.
    OG lil E, Fingers, 6narow and 4 others like this.
  28. 6narow
    6narow
    Sweet rides, FrankenRodz and Hot Rod Punk. =)
    FrankenRodz likes this.
  29. denbob10
    denbob10
    from Olympia Wa
    I'm currently building a 1932 ford roadster with a XJ6 3.4 liter engine,a moss four speed
    Manual ******, out of a 1952 Jaguar MK VII. Engine runs great, and am finishing boxing
    The frame and building the center crossmembers. I had to move the front cross member
    Forward 2" to accommodate the long engine.
    No photos yet, will post when ready
  30. Six Ball
    Six Ball
    from Nevada
    Waiting for the pictures. That sound neat.
    6narow likes this.
