Customs 1951 Chevy 6 to 8 conversion gas pedal
Discussion in 'The Hokey Ass Message Board' started by misterskiguy, Jul 19, 2018.
  1. misterskiguy
    misterskiguy
    Hey guys, I put a rebuilt first gen small block 327 in my 1951 Chevy Styleline. Holley 600cfm. Any help on the easiest/best gas pedal,throttle linkage would be much appreciated. Thinking old Camaro? Thanks in advance.
  2. goldmountain
    goldmountain
    If you aren't into fabrication, get something from Lokar. Otherwise, look for a throttle cable setup from a Chevy G van. Those things are sooo long that you can shorten them to fit anything. If you are running a TH400, look for a pedal with a kickdown switch.
    misterskiguy likes this.
  3. oldolds
    oldolds
    What was said above is correct. Go to the local pic-a-part and pull a cable set up off of about any GM vehicle with a carb on it. It might take a bit of looking as they are getting hard to find, even there.
    If you know somebody with a stash of stuff in the back field you might even get it for free.
  4. misterskiguy
    misterskiguy
    Thanks for the help. Running a 700r4 with a TV cable and cam setup from Bowtie Overdrive.
  5. fms427
    fms427
    I have used pedal , cable setup from a Chev S10, S10 Blazer on several cars. Are / plentiful in the s**** yard , have a nice flat plastic mount on the dash.
