Technical 1930 model a pickup doors
Discussion in 'Traditional Hot Rods' started by insinna, Jul 23, 2018.
  1. insinna
    insinna
    I have a 30 pickup that I'm struggling with and could use some help.... currently I only have the cab on a stand...so here's my questions....new to model A's.... trying to get my doors to fit, could someone post a pic of how the hinges go?.... I'm currently missing the header panel, should I wait until I get it and the roof sides on first?.... should I wait until it's on the frame?.....the doors are pretty rough and are going to need alot of work, so I was trying to get a jump on them while frame was getting worked on....and finally I'm planning on around a 3"chop...I'm ***uming that I want everything to fit good before I chop it?..... Any help would be greatly appreciated..... thanks
    Sent from my Alcatel 5085C using The H.A.M.B. mobile app
  2. drtrcrV-8
    drtrcrV-8
    Suggest make sure your frame is straight & square, then mount the body to it. Next true & square the body on the frame & mount & align all available parts BEFORE you attempt any repairs or "chop". The modifications will never be better than the original alignment that you do, so take your time & get it 'square' & 'right' first, & don't be afraid to re-check several times! When you finally finish the vehicle, you'll be very happy you went to all the alignment trouble first, as your work will be a lot easier if it's all square at the start. I think some of the major "builders" will join in & comment!!
  3. insinna
    insinna
    Thanks, that's kinda what I had figured, just eager to keep project moving.... having frame professionally built by a friend...he does it for a living... Guess I'll just have to sit in it and make engine noises till the frame is ready....putt putt putt...vroooom ..... thanks again
