Cadillac 331/365/390 Aftermarket Distributors
Discussion in 'The Hokey Ass Message Board' started by terd ferguson, Mar 7, 2011.
  1. pitfarm
    pitfarm
    from UK
    <TABLE cl***=tborder id=post2345301 cellSpacing=0 cellPadding=6 width="100%" align=center border=0><TBODY><TR vAlign=top><TD cl***=alt2 style="BORDER-RIGHT: #e5e5e5 1px solid; BORDER-TOP: #e5e5e5 0px solid; BORDER-LEFT: #e5e5e5 1px solid; BORDER-BOTTOM: #e5e5e5 0px solid" width=175>
    </TD><TD cl***=alt1 id=td_post_2345301 style="BORDER-RIGHT: #e5e5e5 1px solid"><!-- icon and ***le -->[​IMG] Re: caddy magneto
    <HR style="COLOR: #e5e5e5; BACKGROUND-COLOR: #e5e5e5" SIZE=1><!-- / icon and ***le --><!-- message -->This conversion is dead easy to do, and cheap !
    I run a warm 331 in my Allard (ancient US/UK Hotrod !). I had real trouble with mis-fires and bad running and changed just about everything except that old Delco dizzy. She had to go, but as you guys have been saying...mags are hard to find. I took a gamble and bought the first new cheapish Mallory dizzy on ebay, hoping i could make it fit........turned out to be perfect, because it was a bit bigger everywhere, so a lathe could do all the work. Here goes.......
    Mallory "25" series dual point distributor part# 2555101 H fits Ford 62-80 (ie common as hell) and is LH rotation.
    Strip the thing out so you can machine the separate components, and your old Delco job so you can measure everything.The locating shoulder below the main flange needs to be turned down a bit, to fit the hole in the block. (I threw an "o" ring away at this stage!!). The bottom of the main stem needs to be sawn off then faced up in the lathe to the same length as the Cad stem. (NB critical dimension...take care !). Then shorten the drive shaft and turn it down at the end for the Cad drive dog, and carefully drill the hole for the roll pin.
    Use the old dizzy to measure everything, and the distances are critical because when you clamp the dizzy to the block, there is a little curvy thrust washer between the drive dog and the bottom face of the stem, which needs to compress a bit but not go tight. Get it wrong and you'll either get sloppy drive, or a nasty squeeking sound and then sloppy drive !
    Do all that and enjoy whoppin' huge sparks on time every time and lovely quality spare bits till you're old and grey (if youre not already !)
    Toms Tech Tips
    <!-- / message --><!-- attachments --><FIELDSET cl***=fieldset><LEGEND>Attached Thumbnails</LEGEND>[​IMG]
    </FIELDSET>
    </TD></TR></TBODY></TABLE>
  2. terd ferguson
    terd ferguson
    Good info! Thanks Tom!!!
  3. terd ferguson
    terd ferguson
    Did you ever get a pic of this conversion?
    ls1yj likes this.
  4. Roothawg
    Roothawg
    Back from the dead. Any pics or memory of what distributor you used?
    warbird1 likes this.
  5. ls1yj
    ls1yj
    from Kentucky
  6. cretin
    cretin
    geez!
    ls1yj likes this.
  7. Great thread so far,thanks for all the info.
  8. ls1yj
    ls1yj
    from Kentucky
    I bought this off the web last week... it’s a Pontiac, but it has correct rotation, and does not look like it will be to hard to modify to fit into the cad block... just got to round up the right gear
    Edit: found a crack in the cap late yesterday... now on the hunt for a good cap to replace
  9. ls1yj
    ls1yj
    from Kentucky
    I finally got all the pieces to put the Cadillac dizzy together
    Jet96, cretin and 51box like this.
  10. Roothawg
    Roothawg
    Nice. Caddy distributors are made from unobtanium.
    ls1yj likes this.
  11. ls1yj
    ls1yj
    from Kentucky
    Roothawg
    You got that right... I had to buy 4 to get enough parts to build this one
  12. Roothawg
    Roothawg
    I just wish they made a new standard style distributor with hei innerds.
    ls1yj likes this.
  13. caddyguy
    caddyguy
    from canada
    There are hei distributors on ebay for sale for this motor.
  14. Roothawg
    Roothawg
    Yeah, but they are Charlie China stuff. I don't put a lot of faith in $39 distributors.
    I went out and looked and it appears that Pertronix has started making their own version. I wonder if it is just a rebranded China verdsion with a Pertronix Flamethrower II module?
    https://www.jegs.com/i/PerTronix/751/D170700/10002/-1
